Old 04-20-2015, 05:11 PM   #15
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
Originally Posted by FRS Johnny View Post
I would have to disagree. Having a catted front pipe is quieter than having no cat.
ok. maybe verrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrryyyyyyyyyyyy yyyy little quiet.
Old 04-20-2015, 06:00 PM   #16
FRS Johnny
FRS Johnny's Avatar
Drives: 2013 FR-S Whiteout MT
It isnt similar in volume at all..
When I ran full catless it was ungodly loud. Threw on a catted front pipe and its fine. But thats just from experience. Maybe its different with other setups? O_o
When in doubt, throttle out!
FRS Johnny is offline   Reply With Quote
Old 04-20-2015, 06:09 PM   #17
MileHighBRZ
Drives: 2014 BRZ Limited
Would the berk catless front pipe alone be able to add major drone and noise? I added it and holy smokes the drone and awful sound. I'm hoping its a lose bolt and exhaust leak
MileHighBRZ is offline   Reply With Quote
Old 04-20-2015, 08:39 PM   #18
FRS Johnny
FRS Johnny's Avatar
Typically catless does do that. What is the rest of your exhaust setup? Any future exhaust plans/changes
Old 04-20-2015, 10:25 PM   #19
geruta
Just out of curiosity, what is your current exhaust setup?
geruta is offline   Reply With Quote
Old 04-20-2015, 11:45 PM   #20
MileHighBRZ
stock exhaust only the front pipe was changed
Old 04-21-2015, 12:49 PM   #21
geruta
So how much louder is an aftermarket catted front pipe over stock catted front pipe?
Old 04-21-2015, 02:25 PM   #22
Jyn
Noob
Jyn's Avatar
Drives: FR-S Mammogram
If you just want a straight pipe, no cats, no resonators, it's cheaper to just go to a quality muffler shop that's local to you and have them fab the part.
Jyn is offline   Reply With Quote
Old 04-21-2015, 03:35 PM   #23
FRS Johnny
FRS Johnny's Avatar
interested in this too actually.. stock has another resonator on it i think?
Old 04-21-2015, 10:02 PM   #24
stevo585
Drives: White 2014 BRZ
Originally Posted by 2016 Camaro SS View Post
The difference is one stinks, and one doesn't. You will find a negligible difference between both while N/A. Turbo is a different story. I say keep the cat to keep people behind you from choking and black crap forming around your bumper and exhaust tips. Also the cat helps with rasp as you upgrade the rest of the exhaust as it acts as a slight resonator.
I run completely catless and I have asked coworkers if they can smell my car while following me and they say "no". So must not be that bad...
stevo585 is offline   Reply With Quote
Old 04-22-2015, 07:24 AM   #25
geruta
Bump.
Looking for an answer to this:
Old 04-22-2015, 08:29 AM   #26
raven1231
Bump.
Buy one and find out. I don't think anyone has measured that. It's likely not a whole lot louder if it still has a cat.
Old 04-22-2015, 10:21 AM   #27
geruta
This is what I figured all along but it seems like most who posted above said to get a cat because it's the same loudness as a uncatted front pipe.
So ultimately, now I'm confused as to what is what.
So far I've heard catted and catless sound the same in terms of loudness.
And I've also heard that aftermarket catted sounds equally as loud as stock
By this logic, an uncatted front pipe is equally loud as a stock pipe which it's obviously not.
So what's really right then?
Old 04-22-2015, 10:28 AM   #28
raven1231
An uncatted pipe will be louder than a catted and an aftermarket catted pipe will be louder than the factory one. Reason being that there is less restriction. This is not considering resonated pipes .Overall however the cat back has the biggest impact on sound though
FS: Motiv Concepts Test Pipe (catless front pipe) $175 shipped s30series Engine, Exhaust, Bolt-Ons 2 12-03-2014 03:40 PM
invida catless over pipe and front pipe bnb kingkai23 NY / NJ / CT / PA 0 03-14-2014 07:32 AM
PTUNING Weekly Special: Invidia Catless Front-pipe / Test pipe $229 INSTALLED! Patrick@Ptuning Engine, Exhaust, Bolt-Ons 3 10-01-2013 04:16 PM
What is the difference between a Front pipe, a down pipe and an over pipe? liajet24 Engine, Exhaust, Transmission 5 09-19-2013 11:03 PM
Track pipe + catless front pipe diss7 Engine, Exhaust, Transmission 21 10-09-2012 02:10 AM
