Old 04-07-2015, 04:42 AM   #1877
Wayno
Wayno's Avatar
Drives: Toyota 86 GTS
That camera looks shit.
Old 04-11-2015, 08:01 PM   #1878
cbo305
cbo305's Avatar
Drives:
Hey guys. I had the ca-fi back up camera installed right by my license plate. It's pointed right at the ground basically. Did anyone else get the camera from ca-fi? if so, where did you install it???
cbo305 is offline   Reply With Quote
Old 04-14-2015, 10:56 AM   #1879
DC2R
Drives: 2014 Scion FR-S
I need to buy a camera but don't want to deal with shipping from Ca-Fi.
Time to pull the trigger. I forgot, what all do I need to do the camera? Most guides I read write for stock head unit.
Would like some suggestions for cameras under $100
DC2R is offline   Reply With Quote
Old 04-14-2015, 01:35 PM   #1880
im2lazy789
Drives: BRZ Limited DGM
Has anyone heard any rumors about Dashlinq5 coming out soon?
im2lazy789 is offline   Reply With Quote
Old 04-16-2015, 11:39 AM   #1881
navanodd
Drives: 2013 BRZ Sport-tech WRB
Does anyone run HERE maps with the data saved offline so you don't need a connection? I tried to search but "here" is a terrible name that just results in every second post in the thread.
navanodd is offline   Reply With Quote
Old 04-18-2015, 11:58 PM   #1882
dinoniel
Just finished my full install on a BRZ Limited! Thanks to everyone on this thread especially @SVXdc for super helpful wiring explanation in post #1645. I also successfully connected rear view camera, USB and aux ports. If anyone has any questions about any of these feel free to ask while it's fresh in my mind.
Question: I'm not that impressed with the audio quality. I know several of you have said the sound is better than stock. Could you guys post your EQ settings? I have the OEM audio+ system, maybe I need them to retune the amp?
dinoniel is offline   Reply With Quote
Old 04-19-2015, 08:42 AM   #1883
SilverlightPony
SilverlightPony's Avatar
Drives: '13 Subaru BRZ, '06 Toyota 4Runner
Yes, the OEM Audio Plus kit's DSP amp must be configured for the specific model of HU you're using it with for optimal sound quality. You'll need to send it back to them to have them reprogram it for the Dashlinq4.
The Dashlinq4 does sound better than the stock HU with the same speakers, but only a little. The jump in quality from stock speakers to the OAP kit is much larger.
SilverlightPony is offline   Reply With Quote
Old 04-19-2015, 01:21 PM   #1884
born2lose
Drives: Toyota GT86
yeap, i use HERE whenever i don't get good enough signal for waze. i really like it, when it comes to offline free nav software, it's the best by a long shot. i even like it more than waze, but need waze's alerts.
born2lose is offline   Reply With Quote
Old 04-20-2015, 08:58 PM   #1885
dinoniel
hey guys could someone clarify regarding the antenna adapter connection? I have the scosche LSAAB adapter with the black and white connector. I know the blue wire does not need to be connected. Does the black harness stay unplugged?
I ask because there is a white stock harness that connects to the adapter and the radio works. But then there is a small square green connector (see pic) that can connect to the black adapter and radio still works.
(image credit to SVXDC and AlexTheGreek)
Old 04-20-2015, 09:43 PM   #1886
Pwolf
Pwolf's Avatar
Drives: 2013 GBS BRZ Limited
The black plug is for older cars that use that style of plug instead of the newer white one. Leave it unplugged. I think that green plug is for the stock GPS antenna which can't be used on this HU.
Pwolf is offline   Reply With Quote
Old 04-20-2015, 10:46 PM   #1887
Kevlar119
Drives: 2015 Scion FR-S series 1
I'm also looking at getting this unit - with the current sale, I wonder if the model 5 is soon to be released. Also, why can't the stock GPS antenna work?
Kevlar119 is offline   Reply With Quote
Old 04-21-2015, 12:45 AM   #1888
dinoniel
No one knows when the model 5 will be released unfortunately. They briefly advertised a "Cartab" model of the dashlinq 4. It had similiar specs but no physical buttons but then they pulled it from the site a month later for unknown reasons.
The stock GPS is just a different connector and module. Since this unit comes with its own GPS module theres no reason to use the stock one.
Old 04-23-2015, 11:37 PM   #1889
dinoniel
Help adding external mic
Anyone who added an external mic looking for some advice:
Following the instructions here http://ca-fi.com/forum/viewtopic.php?f=26&t=4693
However they say to solder red to red and black to black. My aux wire has an additional blue wire. I'm guessing this is for left/right? Do i ignore the Blue wire? Or do I solder both red and blue to the red on the headunit and black to black?
free screen capture
Old 04-24-2015, 05:58 AM   #1890
SilverlightPony
Most mics are mono, and you're using a stereo cable. You said aux? What's at the other end of it?
REVIEW: Ca-Fi Toyota Universal - Stock Fitment ANDROID Stereo SHIFTER Electronics | Audio | NAV | Infotainment 16 06-13-2017 06:23 PM
Android, bluetooth, Music, and the FR-S stock pioneer stereo JayNutter Electronics | Audio | NAV | Infotainment 27 12-18-2014 03:54 AM
How to: Torque on an android powered stereo with no hacking v. Ca-Fi Dashlinq4 SHIFTER Electronics | Audio | NAV | Infotainment 29 04-07-2014 04:58 AM
