Old 04-19-2015, 10:14 AM   #2899
VADERR
Completely Lost
VADERR's Avatar
Drives: 2015 CBS BRZ Limited
I know this is off topic since I am not bitching about the TRD springs... But I have been autocrossing for about 10 months and have found some small success locally and I decided to attend our local autox school. bslate took footage of my first run vs my last run and the improvement is amazing! It was great to get the chance to fine tune my skills (or lack there of) in a non competition environment.
First
Last
VADERR is offline   Reply With Quote
Old 04-19-2015, 08:34 PM   #2900
coneracer30
Drives: 2013 Fiestorm FR-S
I ran the new TRD springs and Koni's today for the first time. So far I'm not impressed. The springs lowered my car almost 1.4 inches. That is quite a lot more than advertised. Center of hub to fender is roughly 13 1/16 front and rear. The lot we ran on today admittedly is not great and quite bumpy, but my car was terrible. Did not handle the bumps well at all. Watching my codriver run was like watching a civic on cut springs. The STX car didn't exhibit any of that. Ended up stiffening front shocks to 1/8 from full stiff. This seemed to help the osculation issues mostly. Rears were 1 turn from full soft.
My first impression is that these springs are no where near stiff enough to run the car this low. While we didn't get any steady state wierdness, I am certain that we are bouncing off of the bumpstops through the bumpier sections, sometimes quite violently.
I am also having some strange issues with the steering that maybe you guys can help with. I noticed post spring install that the car didn't want to straighten itself. For instance, if I turn the wheel approximately 20 degrees and let go of the wheel, the car would want to continue to turn. Would lowering it have decreased the castor significantly? The strangest problem occurred for my co driver. We had a long left hand sweeper prior to the finish that was quite bumpy. He said that at one point, the had about 20-30 degrees of wheel into it and the car was traveling dead straight. Is this even possible? He is experienced and knows when he is sliding the tires.
I retorqued everything last night before the event, so I can't imagine anything would be loose. I did NOT do any vsc or zero point calibration. Could that have anything to do with the steering issues? Bad shock maybe?
If I don't find anything obviously wrong under the car, I may have to reinstall the oem springs and give it another go.
coneracer30 is offline   Reply With Quote
Old 04-20-2015, 12:50 AM   #2901
markw
Drives: 2014 FR-S
Something is wrong. Did you use the new bump stops that came in the kit? My car feels really good with the springs and Konis. I did find that moving over to the springs put the alignment out of whack, but I did springs/shocks at the same time.
markw is offline   Reply With Quote
Old 04-20-2015, 01:10 AM   #2902
coneracer30
After looking it over tonight, I found that the sway bar had been hitting the subframe and the bottom of the strut had made contact with the endlink. Looks like I must have been bottoming out the bar before getting to the bumpstops. Explains why some of the jolts felt so severe. I lengthened the endlinks. Hopefully that solves it.
I did use the shorter bumpstops. What do you have your konis adjusted to?
I will hit the pca event at the same lot this next weekend and see if it is sorted out.
Old 04-20-2015, 01:14 AM   #2903
coneracer30
Double post oops
Old 04-20-2015, 01:56 AM   #2904
markw
Drives: 2014 FR-S
Originally Posted by coneracer30 View Post
After looking it over tonight, I found that the sway bar had been hitting the subframe and the bottom of the strut had made contact with the endlinks. Looks like I must have been bottoming out the bar before getting to the bumpstops. Explains why some of the jolts felt so severe. I lengthened the endlinks. Hopefully that solves it.
I did use the shorter bumpstops. I also did the springs and konis at the same time. What do you have your konis adjusted to?
I'm running the TRD bars and springs with stock endlinks. I did a "spirited" run up Palomar, and found that at least in the rear, the Konis set to 1 full turn were quite stiff and on corners with lots of bumps, there was too much rebound to let the springs return so it ended up on the bump stops. Backing them of to about 1/4 turn seems to solve that. Front I'm running full soft.
It seems to be pretty well balanced, but leaning a little towards over steer. Way better than it was with the other stock springs and bars, and pretty close to the perren front bar/stock springs I had before. It does seem to be a little flatter in the turns and more planted. It can also carry a ton of speed in the slalom.
I think the springs help, but I have also gotten way more comfortable with the car. In the last month I've done the Evo phase 1 and 2, plus the SD national Tour (7th). Today I finished 3rd out of 9 in class for the region. Still waiting for PAX to come out. I'm beating guys who I were trailing by a good amount towards the end of last year and beginning of this year.
Mark
Old 04-20-2015, 02:07 AM   #2905
renfield90
The Stig's German cousin
BRZ takes 1-2 finish in Crows champ tour. Y'all just ran out of excuses!
Old 04-20-2015, 09:49 AM   #2906
G_Ride
G_Ride's Avatar
Drives: Some kind of Subaru
I had a few friends in CS at that tour, but I don't think they noticed any of the FRS cars with the TRD parts. However, Jonathan Stroud is a good driver, and apparently his codriver is too.
G_Ride is offline   Reply With Quote
Old 04-20-2015, 11:22 AM   #2907
Jawnathin
Drives: Toyobaru FRZ
Erik is correct, there were no FRS on TRD parts at the Crows NT. Haven't seen one yet, but then again this was my first event since the SD tour and the TRD parts were 'revealed' last month.
Crows NT was a blast. Looking forward to the Pro.
Jawnathin is offline   Reply With Quote
Old 04-20-2015, 11:37 AM   #2908
renfield90
Originally Posted by Arigh View Post
Now imagine if they had TRD parts in ADDITION to being better drivers on that day than their competitors!
Doesn't matter since the parts make you slower.
Old 04-20-2015, 01:00 PM   #2909
Kido1986
Dodging cones
Kido1986's Avatar
Drives: 2013 BRZ Limited, 93 Z28
Before I went on Hiatus, Jason was beating me like a red headed step child locally in his new-to-him RX8. He flew out to CA and drove his brother's car and cleaned up it appears.
Originally Posted by trevorovert View Post
Originally Posted by mrbillclintong View Post
If you guys spot any riced frs/brz post them here just for laughs no hating please.
Isn't there already a thread like this? It's called aggressive wheels or summat...
C Street Build/Progress Questions about C Street Autocrossing?
Kido1986 is offline   Reply With Quote
Old 04-20-2015, 02:08 PM   #2910
Jawnathin
Yep, Jason is a great driver. Won several Dixie Tours in an MX5, driven several 86s locally, and now campaigns a CS RX8. He is very familiar with these types of cars. He took 2nd at Dixie last month. He came out to participate in the Tour and Pro.
It was a great race. I gave up a chance to take the lead on Day 1, didn't even feel the cone. We traded blows between runs on Day 2, then he nailed it out of the park on his 3rd run and I couldn't match it. No shame in losing no to him and I'm glad he did well. CS is a very competitive class with lots of great drivers in this region.
We will be back out at the Pro next week. Running Hankooks instead of Bridgestones. It should be a blast.
Old 04-20-2015, 03:12 PM   #2911
SeanRTR
C-Street AutoX
SeanRTR's Avatar
Why?
Heat?
-2013 Scion FR-S C-Street
Gearhead Homes - Homes geared towards car enthusiasts: https://www.facebook.com/GearheadHomes.RealEstate
SeanRTR is offline   Reply With Quote
Old 04-20-2015, 03:53 PM   #2912
Jawnathin
Originally Posted by SeanRTR View Post
Why?
Heat?
Contingency
Cinco De Mayo SCCA SOLO Ryeong86 NY / NJ / CT / PA 0 04-23-2013 05:22 PM
Koni Sports in SCCA SOLO Ryeong86 Tracking / Autocross / HPDE / Drifting 4 04-22-2013 12:58 PM
2013 Preliminary SCCA SOLO and PRO SOLO National Schedule Scooby South Tracking / Autocross / HPDE / Drifting 13 12-05-2012 08:08 AM
Houston SCCA Solo #9 - 5 FRS, 1 BRZ hankster Tracking / Autocross / HPDE / Drifting 0 10-09-2012 01:35 PM
SCCA Solo Car Class for the FR-S/BRZ? MrVito Scion FR-S / Toyota 86 GT86 General Forum 31 06-15-2012 10:03 AM
