Old 04-15-2015, 12:31 PM   #2605
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
What is a decent time for Big Willow on stock tires and suspension? I couldn't make it past 76mph in (not exiting) turn 2. How much time would stickier, non-slick tires take off?
Old 04-15-2015, 03:05 PM   #2606
CSG Mike
CSG Mike's Avatar
Originally Posted by Lateral G View Post
I'd really like a balance of the two, leaning towards performance as primary concern.
Try -2.4 front -2.3 rear, 1/16" total toe-in front and rear.
You'll need front camber plates and rear lower control arms to achieve this, if you don't have them already.
Old 04-15-2015, 03:07 PM   #2607
CSG Mike
CSG Mike's Avatar
Running at an event with higher quality drivers and less traffic would be a great start.
I did a 1:37.003 back in 2012 with a stock car and a passenger. My entry speed was around 102-104.
Seat time will help you more than tires, but stickier tires will help cornering speeds while hurting straight line speeds, sit's a trade off, especially with a low powered car.
You should come out to the 86CUP.
https://www.facebook.com/groups/1444342282448992/
Old 04-17-2015, 01:47 AM   #2608
Raven240
Drives: 2015 Release Series 1.0 FRS
Will Enkei RFp1s clear stoptech bbk? What other 17 inch track wheel setups will clear BBK?
Raven240 is offline   Reply With Quote
Old 04-17-2015, 12:14 PM   #2609
CSG Mike
CSG Mike's Avatar
Depending on the width and size, yes. I need more info.
Old 04-19-2015, 04:57 AM   #2610
ShadowTS
Drives: Toyota GT86 SWP
I need to buy summer tires for daily driving + 3/4 occasional track events every season. I have to stick to 215/45 R17 because of law issues, I can't go with 225, and Michelin Pilot Super Sports are not available in 215/45 in EU. What is your recommendation? I'm torn between sticky tires (AD08R, Ecsta XS) or performance tires (RE002, Advan Sport V105...): my main concern is to not destroy the latter type on a few laps because of overheat.
EDIT: Car is currently stock, I will upgrade soon pads + lines + fluid, and eventually add a little drop (lowest as possible) but it won't happen soon. Stock power. I'll also do like 8k KM on street every season, so my plan is to have each set of tires for 2 seasons and change it before it becomes old.
ShadowTS is offline   Reply With Quote
Old 04-19-2015, 10:36 AM   #2611
Doozer
Doozer's Avatar
Drives: gt86...among others
Just tested the new Maxxis VR-1's this weekend. Held up very well with 2+* camber in 35* heat all day on a "stockish" 86. They'll be released in June. Treadwear 140
For the other choices, check out the tirerack video comparing AD08, XS, RE11 and Direzza's. I've never driven any of them on an 86 so others will hopefully chime in with their opinions.
http://www.tirerack.com/tires/tires....Model=Ecsta+XS
Hope this helps
racing gods live deep in corners
Doozer is offline   Reply With Quote
Old 04-19-2015, 12:16 PM   #2612
CSG Mike
CSG Mike's Avatar
Go with the sticky compound.
Old 04-19-2015, 04:32 PM   #2613
ShadowTS
Hope this helps
Hi, yes, I've done a lot of research. The main doubt is going with Extreme Performance or Max Performance (PSS excluded), not the exact tire inside the group. This is also because, for example, in the Extreme category the only tires for sale here are the Kumho XS and the Yoko AD08R, all the others (Direzza DII, Hankook R-S3, Bridgestone RE11 and 71) are not for sale in Italy.
Old 04-19-2015, 04:35 PM   #2614
ShadowTS
I'll also add that I'm not an experienced track driver, but a newbie. I've red a lot of your posts suggesting to start with good but not extremely grippy tires to better learn the limits of the car. Have you changed opinion?
Old 04-19-2015, 07:14 PM   #2615
CSG Mike
CSG Mike's Avatar
Nope.
They're sticky, relative to the "non-sticky" tires you're comparing them to, but they're not sticky compared to race rubber.
Give the RE11A a try.
Old 04-19-2015, 07:29 PM   #2616
ShadowTS
Nope.
Unfortunately not available here. The only alternative is the AD08R. I'll but the Kumho, I hope they won't be to noisy on the street.
Old 04-19-2015, 07:38 PM   #2617
CSG Mike
CSG Mike's Avatar
Go with the AD08R
Old 04-19-2015, 07:44 PM   #2618
ShadowTS
Go with the AD08R
Can you also suggest a tire a step lower (Max Perf) that will survive some track events (newbie, not pro driver), excluding Michelin PSS?
Simple question, hard to find answer... Mango22 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 05-16-2013 06:23 PM
Silly question about protecting track rims sw20kosh Tracking / Autocross / HPDE / Drifting 16 04-25-2013 12:34 PM
Asking the question that I already know the answer to. Are the engines the same? Bigmaxy Engine, Exhaust, Transmission 10 01-19-2013 07:47 PM
Random dog-related question for those who have their BRZ GMU-BRZ BRZ First-Gen (2012+) — General Topics 11 05-31-2012 07:48 AM
Got my answer - BRZ comes with HID headlights as STD Z_Rocks BRZ First-Gen (2012+) — General Topics 20 01-10-2012 09:54 AM
