Old 04-16-2015, 04:20 PM   #3249
86SPEED
86SPEED's Avatar
Drives: The silvertrooper 10 series
There is not.
It's not something you'll be doing a lot...
Yeah according to Rotrex 50k or 2 years. i thought i read 30 from KW..
86SPEED is offline   Reply With Quote
Old 04-16-2015, 06:40 PM   #3250
CSG Mike
CSG Mike's Avatar
Originally Posted by Triumphrider View Post
I just took my car out and did some logging. A quick question for those more experienced... I had the traction control on when I was doing my logging. And to stay out of sight I was on an older bumpy road. If the traction control kicks in while doing a pull will that effect knock as the engine cuts in and out.
It can if you're on an obsolete base map.
Old 04-16-2015, 06:43 PM   #3251
Triumphrider
Triumphrider's Avatar
Drives: 2013 Scion FRS in white out
I doubt I'm on an obsolete base map. I'm using the moto East tune. In my head at least I'm thinking to do a pull it would be best to simulate a dyno... ie smooth, no tc interruption
2013 Scion Frs AT in Whiteout, Borla UEL header, Greddy SP Elite AxleBack. Kraftwerks C38 Supercharger tuned by Moto East and 2 kid seats in the back.
Triumphrider is offline   Reply With Quote
Old 04-17-2015, 12:02 PM   #3252
DAN_BRZ
DAN_BRZ's Avatar
Drives: 2013 WRB BRZ Sport Tech
on the skunk2 sandwich plate what port in/out?!
installing KRAFTWERKS C38 FROM RICKSPECD MOTOEAST TUNE & SKUNK2 ULTRA RAD / SANDWICH PLATE / GRAMS 550cc
JDL UEL PERRIN EXHAUST 2.5" OP 3" CATTED F 3" CATBACK - PERRIN MOUNTS PERRIN PULLEY KIT WHITELINE BUSHINGS WILDWOOD BBK ACT CLUTCH & FLYWHEEL KW V3 MTEC KARTBOY SS SEIBON ROOF SPOILER & FRONT LIP 57XTREME 18x9.5 +40 W/ 255/55/R18 MICHELIN PSS
DAN_BRZ is offline   Reply With Quote
Old 04-18-2015, 01:18 PM   #3253
EquiFox
Drives: 2014 FRS Firestorm
Car started doing this a few days ago. Very annoying sound.
[ame="https://www.youtube.com/watch?v=JK6mp1cRZJs"]VID 20150417 233158 - YouTube[/ame]
Performance doesnt seem to be affected, however car almost didnt start this morning and it was doing a tiny knock-like sound for the first 10-15 seconds of actually moving but it went away, so I don't know. It looks terrible on idle now.
I checked Rotrex oil level and its on the first bar after minimum (been 4000KM only so I dont know what happened)
As for motor oil, I'Ve put Redline last week.
Any hints ?
EquiFox is offline   Reply With Quote
Old 04-19-2015, 06:54 PM   #3254
nlowell
nlowell's Avatar
Originally Posted by zoth View Post
Good new to guys waiting on CARB, More, Better information surrounding C.A.R.B. will be released next week as per my conversation with @KraftWerks.
nlowell is offline   Reply With Quote
Old 04-19-2015, 07:39 PM   #3255
SPCorBUST
SPCorBUST's Avatar
Was any CARB information released?
Setup 3: JR C30, DW 700, Grams 265, 3bar, FlexFuel, Moto-East
Setup 4: JR C30 HBP, DW 700, Grams 265, 3bar, FlexFuel, Church
Setup 5: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Built Motor
Setup 6: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Closed Deck Built Motor
SPCorBUST is offline   Reply With Quote
Old 04-20-2015, 09:54 AM   #3256
BRZZZZZZZZZZ
Car Nut
BRZZZZZZZZZZ's Avatar
Drives: BMW 335d, Toyota Echo RS, FRS
Almost 4000km on my kit now, still running strong and lots of fun.
BRZZZZZZZZZZ is offline   Reply With Quote
Old 04-20-2015, 10:38 AM   #3257
mit_peid
Boosted Noob
mit_peid's Avatar
Drives: '13 FRS MT KW SC, '05 4Runner 4WD
A quick Google search reveals some challenges getting CARB on their previous kits. This particular one from the s2k forums was when Oscar Jackson was still part of KW. I'm guessing his knowledge back then transferred to them being able to get CARB approval for the JR kit.
http://www.s2ki.com/s2000/topic/7925...s-carb-status/
mit_peid is offline   Reply With Quote
The Following User Says Thank You to mit_peid For This Useful Post:
SPCorBUST (04-20-2015)
Old 04-20-2015, 12:58 PM   #3258
DAN_BRZ
DAN_BRZ's Avatar
installed my kit over the weekend!!! holy hell!!! this thing moves
The Following 5 Users Say Thank You to DAN_BRZ For This Useful Post:
drewbot (04-29-2015), Freeman (04-20-2015), Rulin (04-20-2015), Triumphrider (04-20-2015), zoth (04-20-2015)
Old 04-20-2015, 03:35 PM   #3259
Freeman
Freeman's Avatar
Drives: 2013 Ultramarine FR-S
Originally Posted by Freeman View Post
Open to ideas on this, CSG if you're lurking feel free to chime in.
The other day I romped on it and the car felt sluggish. I looked over at my failsafe gauge and the PSI (which is normally ~11psi) was at ~8psi. I figured that since my perrin motor mounts had shaken my oil cooler fittings and bolts loose that they had struck again. I took the bumper off and tightened up all the clamps on the piping and which got the PSI up to ~9. The car feels closer to normal, but still a bit slower than it was.
Any other ideas out there? Hoping the blower isn't shot, but it has gotten louder.
Well, the boost leak that I though I had isn't there. Its at the shop now and they're going to pull the system off and go through it. No rotrex oil in the intercooler piping, so the seals havent been leaking. But its down to 6.6 psi at red line now. So, maybe the blower IS dying? Which will probably be expensive...
Freeman is offline   Reply With Quote
Old 04-21-2015, 07:04 PM   #3260
John92
Drives: White scion frs
For anyone running the High boost pulley on the C30 are you still using the stock map sensor or did you need a 4bar? Thanks for the help.
John92 is offline   Reply With Quote
Old 04-21-2015, 10:13 PM   #3261
industrial
Add lightness!
industrial's Avatar
Drives: 17' WRX
Doesn't rotrex blowers come with a warranty?
industrial is offline   Reply With Quote
Old 04-22-2015, 01:35 PM   #3262
Freeman
Freeman's Avatar
They do. It'll be interesting to see how it all plays out. Yes I'll post up the end result of all this. I'm working with Kraftwerks on options to replace the C30. Sounds like it's an internal part failure in the C30, but obviously wont know until they get it evaluated by rotrex. I got the car back from the shop last night after they went through it. There were no holes in the system to cause a boost leak. The supercharger is really screaming now, so I'm leaning towards an internal failure of the C30.
The Following User Says Thank You to Freeman For This Useful Post:
industrial (04-22-2015)
Kraftwerks Rotrex Supercharger Discussion nelsmar Forced Induction 697 01-18-2022 12:06 PM
All SUPERCHARGER kits compilation thread subatoy Forced Induction 76 03-10-2016 12:38 PM
Kraftwerks Supercharger?? umpadupa Forced Induction 1 08-05-2013 05:27 PM
