Old 04-09-2015, 02:48 PM   #1
Fender0122
Drives: 2013 BRZ Limited SWP 6MT
DIY Rear Seat Delete
Not much to this, but I figured I would share the rear seat delete I made. I'm not a big fan of the options out there to buy one, and I had some left over carpet from making a subwoofer box so I figured I would just make something. I would like to point out, however, that if you are autocrossing in the STX class that this is not permitted in that class. So really this was a waste of time on my part, but I at least want to share what I did since it was relatively easy and extremely inexpensive.
I first made a template out of cardboard. There was a lot of trial and error in the fitment of everything, so I just cut away little bits at a time until it fit in there nicely.
The piece of cardboard I used wasn't wide enough, so I used this template to make another one that was a little bigger. When you are cutting it away, make sure you cut a little extra away to make room for the thickness of the carpet to wrap around, otherwise it will be too tight.
Here's where you can go one of two ways. I chose to use cardboard as my actual backing material, but I feel like there are better options out there at a hardware store of fabric store. It would be nice to match up similar backing to what the trunk uses.
Once you get the template the way you like it you can start gluing the carpet to it. I got the carpet at a local car audio shop (Columbus Car Audio) for roughly $20. Cut out the carpet about 3 inches out from the edge of the template. I then used 3M Super77 spray adhesive and sprayed just the cardboard side and let it sit for a moment. I then laid the carpet over the cardboard, starting at one side and working my way across making sure there's no bubbles. You can pretty much put all the carpet on when it's flat, but I made sure to bend the back part as I laid the carpet so it wouldn't be too tight.
I then flipped it over and cut reliefs at every corner so I could fold it around and not overlap anywhere. I then sprayed the edge with more spray adhesive (make sure you don't hit the carpet too hard or it will bleed through) and then just folded it around.
After that, you're pretty much done! Take the back seats out and then just drop this in. It's not perfect, but sure beats paying a bunch of money for a kit. I realized groceries or anything else I put in the trunk would come flying at me, so I bought a cargo net from a motorcycle shop to keep things where they're at. Here's the finished product:
I'm planning to keep mine for if I move up a class or take it drag racing, but anyone in the Columbus Ohio area is more than welcome to stop by and trace my template if they want to make their own.
OVR-SCCA Course Design and SSSI
Fender0122 is offline   Reply With Quote
Old 04-09-2015, 03:33 PM   #2
FRSfan111
Sideways and smiling!
Drives: First 86 FRS 5/8/2012 (second US)
For cardboard that came out really nice
FRSfan111 is offline   Reply With Quote
Old 04-09-2015, 03:46 PM   #3
Fender0122
Thanks! My thinking is that I can easily pull the carpet off if I find a better backing material.
Old 04-10-2015, 12:38 AM   #4
ZOMFGAARON
A Demon
ZOMFGAARON's Avatar
Drives: Raven GT86
Agreed it looks super good.
Old 04-10-2015, 12:54 AM   #5
Amaya
Amaya's Avatar
Drives: 2015 Scion FR-S 6MT
That's pretty good looking, I may have to try this.
Amaya is offline   Reply With Quote
Old 04-12-2015, 02:25 AM   #6
kounkun
kounkun's Avatar
Drives: 2015 CWP BRZ Limited
Maybe alcantara?
kounkun is offline   Reply With Quote
Old 04-19-2015, 01:08 AM   #7
zman
zman's Avatar
Drives: scion frs
You should write the dimensions on one of the pictures
zman is offline   Reply With Quote
Old 04-19-2015, 04:32 AM   #8
sachu
Drives: rocketship
damn.. that's brilliant.
My only gripe is that center drive shaft channel running through. I've got a doberman girl who rides in the back a bunch and I'd love to have that section level and cushioned with like memory foam or something.
Inspiring stuff!!
sachu is offline   Reply With Quote
Old 04-19-2015, 10:11 AM   #9
Blu-by-U
Some Dumb Guy
Blu-by-U's Avatar
Drives: wanting an Acabian
Nicely deleted. Any extra road noise? I had the seat down and the back full, but didn't really notice any increase in road noise.
She said it was her or the car. Longest she had ever seen.
Blu-by-U is offline   Reply With Quote
Old 04-20-2015, 11:00 AM   #10
Fender0122
Originally Posted by kounkun View Post
Maybe alcantara?
It would need to be something that is somewhat stiff. Alcantara would be great to cover it with, though. I found the perfect stuff in my back warehouse that is acoustical backing for cubicle panels. It's like a fibrous material but semi stiff. I'll have to see if I can find a name for the stuff.
I have it out of my car now so it wouldn't be too hard to get some dimensions for everyone.
Inspiring stuff!!
I'm almost wondering if you can use thin wood or luan sheeting or something. It might be a little heavier but then you could put a little padding and that puppy would be happy! That's half of why I put this up here. The design isn't perfect, but it's enough to get people out in the garage and make their own with whatever materials suit them best.
Yes, but really only more muffler noise because the rear seat is down and exposed to the trunk. I've got just a borla UEL header on stock exhaust and the added noise from this almost made me content enough with the sound the car makes. Almost...
diy, diy interior, rear seat delete
DIY: Shrader Performance Rear Seat Delete Kit & Rear Seat Removal PoorMansRacing DIY (Do-It-Yourself) Guides 98 10-10-2023 04:51 PM
Rear Seat Delete kit ender2664 Cosmetic Modification (Interior/Exterior/Lighting) 53 10-04-2017 02:10 PM
Has anyone used this rear seat delete kit? OkieSnuffBox Cosmetic Modification (Interior/Exterior/Lighting) 19 10-24-2015 03:40 PM
REAR SEAT DELETE SUB BOX NYCsubaruBRZ NY / NJ / CT / PA 19 01-28-2014 02:38 AM
