Old 04-16-2015, 01:18 PM   #127
Racecomp Engineering
Originally Posted by wparsons View Post
Wait, that isn't what you guys do too???
They're Subarus...you can go back to a 1993 Impreza on some of these parts.
But you probably shouldn't use the same damper cartridge for EVERY CAR EVER MADE like some do.
Our R&D is a little bit more involved thanks to the capabilities of our partners.
- Andy
The Following 3 Users Say Thank You to Racecomp Engineering For This Useful Post:
CSG Mike (04-16-2015), Hyper4mance2k (04-16-2015), wparsons (04-16-2015)
Old 04-16-2015, 01:52 PM   #128
Kostamojen
Correction: 1990 Legacy
The Following 4 Users Say Thank You to Kostamojen For This Useful Post:
CSG Mike (04-16-2015), Hyper4mance2k (04-16-2015), Racecomp Engineering (04-16-2015), wparsons (04-16-2015)
Old 04-16-2015, 02:09 PM   #129
Kostamojen
For the same width and overall diameter, a 16" tire will be heavier than a 17". More rubber, and more sidewall reinforcement.
Thats what you would think, but if you look at specific tire specs some are lighter as 16's and others are lighter as 17's. Depends entirely on the specific tire.
Old 04-16-2015, 02:14 PM   #130
CSG Mike
CSG Mike's Avatar
Why do people keep running stiffer springs up front? Do they even look at the geometry before making decisions?
The effective wheel rates put that as incredibly front biased, it must understeer like crazy at turn in.
12.5 * 0.95^2 = 11.3kg/mm at the front wheel
10.2 * 0.75^2 = 5.7kg/mm at the rear wheel
if you flipped the springs front to rear it's still front biased, but not nearly as bad:
10.2 * 0..95^2 = 9.2kg/mm at the front wheel
12.5 * 0.75^2 = 7.0kg/mm at the rear wheel
I know it's not the norm, but at some point, you do need a frontward bias when you can just break the rear loose effortlessly
Now, carry on, I like this discussion!
Old 04-16-2015, 03:52 PM   #131
Calum
That Guy
Drives: 2013 asphalt FRS MT
Originally Posted by Shankenstein View Post
While it's clear to us, most of the coilovers from Taiwan (and some from Japan) coilovers come setup with a significant front bias.
This is how I imagine their R&D teams:
The sway bars are front biased, the stock spring rear biased. I'd imagine if one were to remove both sway bars they would want to change the spring bias to compensate.
Old 04-16-2015, 04:07 PM   #132
jvincent
jvincent's Avatar
Taking this thread to the next level.......
If no sway-bar is good, how about no springs up front. Hell why not take out the whole strut?
Think of how planted the car would feel.
The Following 2 Users Say Thank You to jvincent For This Useful Post:
CSG Mike (04-16-2015), wparsons (04-17-2015)
Old 04-16-2015, 04:13 PM   #133
*Hachiroku86*
BAZINGA!
*Hachiroku86*'s Avatar
Drives: 15 FR-S
Originally Posted by adamg View Post
so sick of ignorant "track guys" on this forum
you mad bro?
Colin Chapman - "Adding power makes you faster on the straights, subtracting weight makes you faster everywhere."
*Hachiroku86* is offline   Reply With Quote
Old 04-16-2015, 04:27 PM   #134
HunterGreene
Hail Magnet
HunterGreene's Avatar
Yeah, I have an idea...
It has priests in it?
The Following 3 Users Say Thank You to HunterGreene For This Useful Post:
cdrazic93 (04-16-2015), jvincent (04-17-2015), wparsons (04-17-2015)
Old 04-16-2015, 04:32 PM   #135
*Hachiroku86*
BAZINGA!
Drives: 15 FR-S
Originally Posted by KoolBRZ View Post
It wasn't till last night that I got my suspension to give a halfway decent ride.
should of just left it stock...
The Following User Says Thank You to *Hachiroku86* For This Useful Post:
8R6 (04-16-2015)
Old 04-16-2015, 05:28 PM   #136
BRZChix
Drives: Subaru BRZ 2013
feel free to take a sick leave
BRZChix is offline   Reply With Quote
The Following 2 Users Say Thank You to BRZChix For This Useful Post:
*Hachiroku86* (04-17-2015), Koa (04-16-2015)
Old 04-16-2015, 05:35 PM   #137
mokinbird87
BOXER FR
mokinbird87's Avatar
Drives: WRB BRZ Limited
I've gone to a lot of time and trouble to try to get a better ride on the street from my BRZ. I've tried Airlift coilovers, KW V3, Hypermax GT IV, Bilstein HD, used FR-S suspension and if it's too soft I get bounced around, and if it's too stiff I feel every wrinkle on the road. Then I read a thread by @captain_snooze where he had his anti-sway bars removed, and AST5200 coilovers installed. He liked the new ride so much I decided to try removing the front anti-sway bar from my BRZ. I also installed my Bilstein HD's with BRZ front springs, (27 N/mm), and FR-S rear springs, (37 N/mm). I'm not getting much leaning yet, because I still have on my stock rear anti-sway bar, but I'm going to remove that one as well, just to see how it rides. Best of all, this "fix" is completely free, unlike a lot of suggestions out there.
have you tried the Ohlins R&T? i think it rides better than stock and outperforms it for sure... i mean, if you have the budget to try multiple set ups (including V3) give it a try.
mokinbird87 is offline   Reply With Quote
The Following User Says Thank You to mokinbird87 For This Useful Post:
KoolBRZ (04-17-2015)
Old 04-16-2015, 08:59 PM   #138
KoolBRZ
KoolBRZ's Avatar
Drives: Silver 2013 BRZ Ltd Auto 45,000 mi
My front sway bar is back on now, and my rear sway bar is removed. I also have my summer setup installed right now, HKS Hypermax GT IV 6K front 4k rear with 3" helpers on the rears. I'm learning the importance of preload right now, and adjusting the dampening to get the best compromise.
KoolBRZ is offline   Reply With Quote
The Following User Says Thank You to KoolBRZ For This Useful Post:
Koa (04-16-2015)
Old 04-17-2015, 12:04 AM   #139
aagun
Drives: 86
at my tune it is balanced and it is under steer and overseer at the same time while fast cornering , flexible drive and it is slider
OK , suspension tuning is a huge system that the drifters or modification use it to adjustment rolling and driving feel and allowed us to get better way to control the car.
as we know there are two ways the car jumps to while driving it at corner , one of it is under-steering and other one is over-steering .
there are many things effect in both things like tire pressure at front and rear tires , Width of the car from the front and the rear with driver, Width of the tires ,tire Aspect Ratio , tire Section Width , tire tread depth , wider and lighter wheels , camber , toe , caster , Anti-Sway bars , Spring rates , Shock absorbers , Suspension Bushings , Brake Proportioning , Aerodynamics.
check http://www.northursalia.com/techdocs...ver-under.html
so to get the right balance you need a lot of time and tests .
top gear fun
[ame="https://www.youtube.com/watch?v=zoICf55jED8"]Top Gear Understeer and Oversteer explained - YouTube[/ame]
[ame="https://www.youtube.com/watch?v=L0_w3C840uw"]Car Control: Oversteer, Understeer and Braking (What to do in emergency situations) - YouTube[/ame]
aagun is offline   Reply With Quote
The Following User Says Thank You to aagun For This Useful Post:
Old 04-17-2015, 07:59 AM   #140
wparsons
wparsons's Avatar
Except the stock springs aren't really rear biased when you look at the motion ratios. On the FRS they are ever so slightly rear biased, on the BRZ they're front biased.
FRS
2.3k * 0.95^2 = 2.09k
3.8k * 0.75^2 = 2.14k
BRZ
2.7k * 0.95^2 = 2.44k
3.5k * 0.75^2 = 1.96k
Factor in the front bias from the sway bars and overall it's front biased on both cars.
flickr
Calum (04-17-2015)
Say no to SWAY with our Anti-Sway Bar and Sway Bar Bushing Special. FRSport.com Brakes, Suspension, Chassis 0 01-23-2015 12:38 PM
FS:NY RCE Anti-roll/Sway Bar kit $250 snky_snky Brakes, Suspension, Chassis 2 08-19-2013 09:42 PM
FS: NY RCE Sway/Anti-roll bar kit $250 snky_snky Engine, Exhaust, Bolt-Ons 2 08-18-2013 12:09 PM
ST Suspensions Lowering Springs & Anti-Sway Bars Now Available @ BMS! Boston Motorsports Brakes, Suspension, Chassis 84 07-23-2013 11:42 PM
How to pick anti-sway bars FastLane1000 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 19 07-12-2013 05:06 PM
