Old 04-14-2015, 08:10 PM   #2101
babydriver
Hit the road and I'm gone
babydriver's Avatar
Originally Posted by DaiTT500 View Post
Completed my first weekend on e85 on the track at MSR Houston. The car ran much cooler and made good power. I was not afraid of detonation at all. The power was smooth and kept on pulling when I was on it. Above is the picture of my dyno on e85 with remote tuning by moto-east. Blue is the after-tune red is the baseline pre-tune. All weekend I was battling with a race-car corvette ZR1 and all other cars I just passed up effortlessly. All of the bigger horsepower cars kept on thinking they could leave me in the straights and they all were surprised I stayed on their bumper.
Youtube Video
The noive of dat guy! It must have been fun passing the ZR1. I can just imagine the startled look on the driver's face.
Slip, slidin' away.
Old 04-15-2015, 01:51 PM   #2102
lastexile1987
lastexile1987's Avatar
Drives: Lightning Red '13 Limited BRZ
Hey CSG mike/David. How much would it be to get replacement oil lines like the ones pictured. Mine are still giving me an issue and there seems to be smaller (smaller than before) amounts of oil leaking. I would just opt to get brand new ones and have the piece of mind.Name:  uploadfromtaptalk1429120290848.jpg
lastexile1987 is offline   Reply With Quote
Old 04-15-2015, 02:02 PM   #2103
alpax
alpax's Avatar
Drives: 2013 Subaru BRZ AT JRSC
Are the hose connections to the radiator tight enough? I had an oil leak at those spots after installation because I was afraid to damage the radiator by overtightening (the risk of this was mentioned in the manual, but no torque amount mentioned for those connections). Then I tightened those a bit more, and it fixed that.
alpax is offline   Reply With Quote
The Following User Says Thank You to alpax For This Useful Post:
CSG Mike (04-15-2015)
Old 04-15-2015, 02:21 PM   #2104
lastexile1987
Well my issue that happened was the hose completely separated and purged my oil. I don't know the technical terms for the part but the black hose came off of the dark silver where it screws on to the system. The hose is supposed to be pressure sealed up to 300psi (if I remember correctly what mike told me) and it just popped off a day or two after I had the kit installed. I bought the kit used so nothing I could do except have it fixed. Had it towed and they put clamps on. Still very paranoid and would rather have new ones AND clamps on there. Fiance doesn't even want to ride in the car in case something happens again.
Old 04-15-2015, 02:28 PM   #2105
lastexile1987
Before, when the oil leaked really bad, it covered about 45-50% of the engine. This morning when I checked the engine, which I've grown accustomed to now, there was oil about the circumference of a softball on the oil pan directly beneath the hose connectors. Definitely not as bad as before but still leaves me worried.
Old 04-15-2015, 03:00 PM   #2106
alpax
alpax's Avatar
The radiator on your picture is for the SC oil line - it's different from your first problem when the leak was in the main engine oil system. The oil, which leaks now, is blue - isn't it? Couldn't you find the actual leaking spot? When oil is not all over the place, the leaky connection should be easy to locate.
First I would try to tighten the hose connectors on this small radiator. They have to be pretty tight because there are no rubber gaskets in those spots, but just metal-to-metal, with a copper crush washer (I believe that's how it's called). BTW, maybe just those washers have to be replaced to keep the connections sealed.
And don't forget keeping an eye on the oil level in that SC oil line can in the driver's side corner of the engine bay.
Old 04-15-2015, 03:08 PM   #2107
lastexile1987
No the oil is golden (motor oil). Sc oil levels have remained perfect.
Old 04-15-2015, 03:09 PM   #2108
CSG Mike
CSG Mike's Avatar
Originally Posted by The Slow One View Post
Dai is by 3-4 seconds, having aero helps if you get to our level, I had sti brembos going ccw so I can't count that way and it's not that hard on brakes on either direction other then going into 15. And I go into turn 15 over 80 mph and brush off speed as I go.
Looks like I will be out there in a few weeks. Are you guys running the weekend of April 25th?
Old 04-15-2015, 03:11 PM   #2109
CSG Mike
CSG Mike's Avatar
Send us a PM.
It sounds like the fitting was damaged during the uninstall.
Old 04-15-2015, 03:11 PM   #2110
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
Originally Posted by sw20kosh View Post
No. Huge swings in temperature are bad regardless. Don't argue with Mike/CSG unless you are extremely experienced at track driving. They live and breathe track and do very much know what they are talking about.
what sw20kosh said. The only point at which i would argue with them is based on prior knowledge of the material used in the pads and rotors with some background in thermo.
Just like when they make harder steel, they cant just heat it up and cool it indefintely. That introduces too much carbon into both the pads and rotors causing them to become brittle.
Keeping your brakes at a certain temp during track will not only keep the braking consistant but keep fade down. This is assuming you have good enough brake fluid that doesnt boil at the first sign of a hard stop.
Old 04-15-2015, 03:12 PM   #2111
CSG Mike
CSG Mike's Avatar
I'd like to make an important addition.
**Use assembly lube or the same fluid the system will hold**
This will help prevent damage, as the threads will not be "grinding" when you tighten.
Old 04-15-2015, 03:14 PM   #2112
CSG Mike
CSG Mike's Avatar
Originally Posted by ScionOfHorus View Post
So is getting your brakes hot enough to boil the fluid.
Well, if you're boiling fluid, the REAL solution is a BBK. Technically, I want the rotors to stay hot, but the calipers and knuckle assembly to stay cool.
The rule of thumb we use, is if you have a properly sized brake system, you should not boil RBF600. The stock system will degrade RBF600 rather quickly with an experienced driver, even an intermediate level one that has learned the limits of braking grip. This is where the other fluids we recommend come in. They will temporarily raise the limits of the system.
http://counterspacegarage.com/pmu-gfour335.html
http://counterspacegarage.com/torque...uid-dot-4.html
Oh, there's a buy 3, get 1 free special on torque right now too...
Old 04-15-2015, 03:29 PM   #2113
lastexile1987
Took some very quick pictures since I am at work. Sorry about the low quality. First is just a view down with the amount of oil.
Second is a shot with the hose that came off. I tried to point it out but I have my glove on and I had to crop the hell out of the picture before I could upload it.
Third is just another shot of oil on the oil pan.
I will try tightening the hose, a little, so I don't damage it but I would still like to look into getting replacements.
Size:  234.4 KBName:  uploadfromtaptalk1429125962118.JPG
Size:  332.7 KBName:  uploadfromtaptalk1429126005009.JPG
Old 04-15-2015, 04:17 PM   #2114
CSG Mike
CSG Mike's Avatar
Those clamps are not designed to hold anywhere near the pressure of the oil system. Lets get you some new lines.
PM me.
Jackson Racing Rotrex Supercharger System Info and Discussion Jackson Racing Forced Induction 827 04-06-2020 04:56 PM
Jackson Racing Supercharger Press Release and Info CounterSpace Garage Forced Induction 110 01-03-2017 09:04 PM
jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! CSG Mike Forced Induction 24 04-27-2016 12:59 PM
Jackson Racing supercharger NoppyNop Forced Induction 241 06-26-2014 03:05 PM
Jackson Racing Supercharger Pre-Order Sale, $200 off! Xero-Limit Forced Induction 2 03-05-2014 04:14 PM
