CANADA Canada
Old 05-22-2012, 08:12 AM   #71
Sport-Tech
Sport-Tech's Avatar
Drives: TBD
I would totally agree with Jeff that being in neutral in city driving is not a great idea, but in the city I am rarely higher than 4th gear. I decelerate in that gear to about 10 mph at which point pushing in the clutch will not cause me any safety issues as I come to a stop (I use common sense based on my situation of course).
As to heel-toe, my experience after several hours of practice on a simulator is that it's far from easy to get it right and it would take a long, long time to get it to the point where I would feel I could do it safely in busy traffic without getting distracted in an unsafe way from what is going on around me, as it takes all of my focus away from the road (much like fiddling with a cell phone). I doubt more than 1% of manual drivers heel-toe downshift, learning it is such a PITA. YMMV, I am not a pro athlete. You also have to think about the strain you put on your drivetrain as you're learning, as you make hundreds of wildly inaccurate attempts to revmatch. Gentle use of the clutch will mitigate wear due to uneven rev matching if you downshift without heel-toe while in motion, or you can momentarily take your foot off the brake and tap the accelerator before you let the clutch out for the lower gear.
As to the "no engine braking" it's true most such signs are for trucks, however in my neighbourhood I have seen a few on arterial but residential roads where big trucks are banned.
Sport-Tech is offline   Reply With Quote
Old 05-22-2012, 08:37 AM   #72
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
Originally Posted by bneale View Post
First of all, nobody said anything was wrong with an Auto.
when you state real sports cars mostly come in manual, you're inversly stating that anything that is not manual is not a real sports car
should i draw a venn diagram for you?
You're just trying to be an ass here.
Yes, i am, because muddy thoughts annoy me.
Same with the next statement. When it comes to a DSG transmission, in my opinion its not a true manual.
you're entitled to your opinion, but my opinion of your opinion is that it is outdated and rooted in some sort of prehistoric notion of car involvement. You are a man standing in court proclaiming the world is flat.
You're grasping at straws for an argument.
Well, when you throw a whole hay bale at me...
nom nom nom
Old 05-22-2012, 09:26 AM   #73
SEC
SEC's Avatar
Drives: 12Focus, 16MX5, 99VFR
A point I don't think has been made is that the biggest benefit of a MT is control. With a MT there's a direct connection between the engine and the drive wheels. With most AT, there's some slipping. A MT also lets you keep the engine revs where you want them. The benefit? When you're driving a car like the FR-S/BR-Z you use the throttle to control the attitude of the car in a corner. At the limit, modulating the gas will allow you to tighen your line (by easing off the gas). Or, you can induce some power-oversteer (if you dare).
To answer the OP question, a MT will be more fun when your comfortable enough to do some spirited driving. It'll help you develop car control skills. There is also something really satisfing about doing a quick downshift while braking hard for a corner. I've not driven a car with the newer DSG-type box, but I can't imagine it would be anywhere near as satisfing to drive.
SEC is offline   Reply With Quote
Old 05-22-2012, 09:50 AM   #74
Sport-Tech
Sport-Tech's Avatar
Drives: TBD
You'll get 95% of this control with the FR-S auto, as it's got a locking torque converter for all gears but the first, and shifts faster than you would be able to do yourself with a manual. The only thing you won't be able to do is high-rpm clutch dumps, which aren't great for your car anyways. Using the paddles in manual mode, it functions basically like a clutchless manual. Too bad about the wide gear ratios for it though, they add more than a second to the 1/4 mile time.
Old 05-22-2012, 01:18 PM   #75
Sport-Tech
Sport-Tech's Avatar
Drives: TBD
I may have overstated the difficulty on learning to heel - toe. After a few hours yesterday on the simulator I was not making much progress but after 2 hours lapping Laguna Seca just now it's really starting to come to me - blipping for one gear drops is getting pretty automatic. (I switched the gearshift to sequential mode to simplify the shifting so I could focus on the heel-toe action.) So there is hope for all, I am not the most coordinated guy with my feet!
Doing 2 or 3 drops quickly in succession, as you would on a GT3 car on full braking coming into the corkscrew, is tougher. I have a tendency to lift my right foot off the brake to some degree when I lift off the clutch between downshifts which results of course in underbraking and bingo I am in the sand...
At some point I will have to try this with my real car, but not yet.
Old 05-22-2012, 01:42 PM   #76
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
brake(hold), clutch (hold), paddle, paddle, paddle, gas (hard blip)+ release clutch, release brake.
remember there is no need to shift all gears down.. at all
when you are braking for a turn, your goal is to slow down to the speed that your car will navigate through that turn. So the only variable here is brake.
once you get down to that speed your next goal is to hold that speed by applying throttle
the whole problem comes from the need to be in your engines proper power band by a) not bogging down b) not over-revving. The first slowing you down and the second causing you to spin.
So this is where heel-toe comes in, you only need to do it once, and you only need to do it the second before you need to get back on the gas.
in the case of paddle shifters you need to give yourself more time, so you simply hold the clutch earlier as you brake and start to machine gun down to the gear you want.
Old 05-22-2012, 02:16 PM   #77
Sport-Tech
Sport-Tech's Avatar
Drives: TBD
^ Thanks, yes I had tried using that method as it is simpler, but unless you are in an open-wheeled or prototype racer there are one or two seconds between gear shifts when you are braking hard that you would optimally like to apply engine braking to. Treating each downshift as independent rather than holding the clutch down through all of them would move some of the braking stress from the brakes to the driveline - and should slightly aid high-speed braking performance.
I guess it depends on your heel-toe speed and skill level, and how much time you have between shifts, which technique you use. In the track tests the Best Motoring guys have done with the twins they seem to favour the multiple-blip approach to hard-braking downshifts, probably because there is more time available between shifts with such a "low-performance" car.
Old 05-22-2012, 03:34 PM   #78
SEC
SEC's Avatar
Good point. I'd have to see what 95% feels like before passing judgment. The last three cars I bought I drove the AT before ordering the MT. I've yet to experience an automatic that has the direct feel I like from a MT. Granted, these were all "Sporty" cars, not sports cars. I do think that knocking off the perfect heal-toe downshit under hard braking is just too satisfing to be without. I also have to admit I'm bit biased after 27 years of driving stick.
Old 05-22-2012, 04:10 PM   #79
Turbowned
Turbowned's Avatar
I've driven numerous S4's, S5's, TT's and A3's with S-Tronic (DSG) gearboxes, an R8 V10 Spyder with R-Tronic (single clutch auto), a Porsche 911 Carrera S with PDK, and plenty of 8spd Tiptronic Audis as well. The best of the best, so to speak.
None of them were even remotely as much fun to drive as their manual-equipped counterparts. They just aren't. I'm sorry. No one is going to convince me that the torque converter-equipped automatic transmission is anywhere near as good as rowing them on your own. You're wasting your breath.
Old 05-22-2012, 04:19 PM   #80
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
all on a racetrack i assume?
Old 05-22-2012, 04:27 PM   #81
Capt Canuck
Drives: BMW E36 323is
Kinda makes all the text before it redundant really.
Capt Canuck is offline   Reply With Quote
Old 05-22-2012, 04:51 PM   #82
Klinn
Klinn's Avatar
Drives: '20 Pure Red BRZ, '20 Torch Red C8
I can understand your reluctance regarding a conventional torque converter type auto (e.g. the Tiptronic) but do you feel that the dual-clutch automated manual (e.g. DSG) is no better?
I've read that some still have issues but have never had the opportunity to try one myself.
Klinn is offline   Reply With Quote
Old 05-22-2012, 04:54 PM   #83
mattles
Proud of FR Layout
mattles's Avatar
Drives: 2013 Scion FR-S 6MT
I see we've got some professional level bench-racers here. Although, based on what Ive read on the past 2 pages alone, Im awarding the trophy for Best in Class Bench Racing Expert to 7thGear.
Congrats kid, you done good. Now get on out there and start debating aerodynamics because the only thing cooler than a bench-racer is an All-Pro Armchair Physicist.
--Matt // Flickr \\ Instagram
mattles is offline   Reply With Quote
Old 05-22-2012, 04:56 PM   #84
blu_
blu_'s Avatar
Drives: SWP BRZ LTD
I can't believe I missed this thread
blu_ is offline   Reply With Quote
Odometer Functions - "S" & "G" What are they? kablammo BRZ First-Gen (2012+) — General Topics 59 12-01-2013 12:28 AM
Toyota Holds "FT-86 Fastest Painted Website" Event to Help Launch FR-S / FT-86 Snoopyalien24 Scion FR-S / Toyota 86 GT86 General Forum 35 11-26-2011 07:56 AM
Subaru BRZ Prototype First Drive Review: "Off the Chart" (Motor Trend) Hachiroku BRZ First-Gen (2012+) — General Topics 67 11-09-2011 05:58 PM
May 2010 Car&Driver issue FT-86 article - "25 Cars Worth Waiting For" JDMinc Scion FR-S / Toyota 86 GT86 General Forum 76 04-17-2010 03:58 AM
