go_a_way1
Old 04-14-2015, 11:01 AM   #8583
Thobjo
Drives: GT86
Sweet mother of ... exchange rate is bad.
Since Im at year two waiting for this kit and seem to be moving up the list and close enough right now, no chances taken !
Procede ordered
Thobjo is offline   Reply With Quote
The Following 2 Users Say Thank You to Thobjo For This Useful Post:
DAEMANO (04-14-2015), raven1231 (04-14-2015)
Old 04-14-2015, 12:16 PM   #8584
DAEMANO
Time Traveller
Procede ordered
This man is all about the end game.
The Following 2 Users Say Thank You to DAEMANO For This Useful Post:
raven1231 (04-14-2015), Thobjo (04-14-2015)
Old 04-14-2015, 01:19 PM   #8585
KoolBRZ
KoolBRZ's Avatar
Drives: Silver 2013 BRZ Ltd Auto 45,000 mi
Shiv, can the Procede controller be programmed to control anything else while it's controlling the ESC? (Nitrous, water/meth injection, exhaust dump valve, or etc.)
KoolBRZ is offline   Reply With Quote
Old 04-14-2015, 01:55 PM   #8586
LucidMomentum
No Money, No Problems
LucidMomentum's Avatar
Next paycheck I will probably order the Procede and OFT as well, if possible. I want the last thing I need to wait on to be the actual SC
Technically it can, as I've heard it has multiple input / output channels? Just like any PLC I'm assuming. Implementation wise may be another story.
Old 04-14-2015, 04:37 PM   #8587
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
The Procede has 4 digital outputs that can be configured to trigger shift-light, additional injectors, meth/boost control solenoid, etc. Currently, with the ESC, we aren't using any of them. Just a single analog output (it has 4 of those available as well). But setting all these extra features up requires some work so that you don't have conflicting I/Os. We aren't touting those additional features for this reason. But it is very likely that we will be enabling add-one as time goes by.
Shiv@Openflash is offline   Reply With Quote
The Following 5 Users Say Thank You to Shiv@Openflash For This Useful Post:
Blu-by-U (04-14-2015), DAEMANO (04-14-2015), Fareast auto part (04-14-2015), KoolBRZ (04-14-2015), tyrantcf (04-15-2015)
Old 04-14-2015, 06:27 PM   #8588
07jazzrs5gt86
Drives: Firestorm 86
@shiv
Is the ESC activate by rpm or from tapped dbw?
How many levels of ESC activation can the procede be set at?
Example
50% - 60% = 1psi
60% - 70% = 2psi
70% - 80% = 3psi
80% - 100% = max psi
07jazzrs5gt86 is offline   Reply With Quote
Old 04-14-2015, 06:37 PM   #8589
Shiv@Openflash
Drives: 2013 FRS
Originally Posted by 07jazzrs5gt86 View Post
@shiv
Example
50% - 60% = 1psi
60% - 70% = 2psi
70% - 80% = 3psi
The ESC is 3 dimensionally mapped as a function of RPM and DBW throttle. The throttle:ESC DC% relationship varies with engine speed. The ESC control signal ranges from -100 to 100 with minimum active ESC DC% (barely spinning) right around -20. By ~80, the ESC is spinning at maximum speed. So there are ~100 levels of activation possible (-20 to 80).
Shiv
The Following 9 Users Say Thank You to Shiv@Openflash For This Useful Post:
07jazzrs5gt86 (04-14-2015), Blu-by-U (04-14-2015), DAEMANO (04-14-2015), Gums (04-14-2015), KoolBRZ (04-14-2015), LucidMomentum (04-14-2015), Thobjo (04-14-2015), VR46 (04-14-2015), WRB5titch (04-14-2015)
Old 04-14-2015, 07:44 PM   #8590
l0aded
Addicted
l0aded's Avatar
Drives: 2013 Asphalt FR-S 6MT
Ordering. Luckily socal is close so hopefully it'll come asap .
Shipping we use USA (OFT only)?
Phantom Supercharger | Tsudo Cat-Back Exhaust | K&N Drop-in Filter | Winjet Headlights | Opti-coated | 35/20 Tint | Radar/Dashcam Hardwired | OFT tuned | OEM Audio+ Reference 400CF | Uber Sound Deadened | LED DRL strips | JPM Coachworks Kneepads
l0aded is offline   Reply With Quote
Old 04-14-2015, 07:49 PM   #8591
WRB5titch
Drives: WRBrz
that's what @DAEMANO and i did
EBSC - dt.FF - MXP CompRS
WRB5titch is offline   Reply With Quote
The Following User Says Thank You to WRB5titch For This Useful Post:
l0aded (04-14-2015)
Old 04-14-2015, 09:17 PM   #8592
Gums
Drives: SWP BRZ
Shiv
This Procede thingy just gets better and better, so glad Iv'e ordered one.
Shiv@Openflash Will there be an airflow straightener available for the FRS/86 similar to the one you have in the Miata/MX5 or is it not necessary?
Gums is offline   Reply With Quote
Old 04-14-2015, 09:34 PM   #8593
Shiv@Openflash
Drives: 2013 FRS
Funny enough, the GT86 airbox already has an airflow straightener integrated into it just upstream of the MAF. Very nice!
The Following 3 Users Say Thank You to Shiv@Openflash For This Useful Post:
DAEMANO (04-14-2015), Gums (04-16-2015), Sojhinn (04-14-2015)
Old 04-14-2015, 09:35 PM   #8594
Sojhinn
Lightning McQueen Driver
Sojhinn's Avatar
Drives: Limited Red 6MT BRZ
Lol yeah we figured this out on Saturday.
Installed Mods:
Old 04-15-2015, 01:26 AM   #8595
SimplePortal
Drives: Hot Lava
Still can't get it exactly centered. I feel like the tube between the airbox and compressor is a little bit too long.
SimplePortal is offline   Reply With Quote
Old 04-15-2015, 02:36 AM   #8596
Target70
Target70's Avatar
Drives: 2013 Asphalt 6spd
I agree with you. If it were me, I would take some tin snips or equivalent and cut 1/4'' off of the tube. Just make sure the PVC connector has room and won't hit the intake box before you do (intake box side of the connector looks a little longer from the fitting).
Phantom ESC, OFH, OFT, K&N Drop in
Target70 is offline   Reply With Quote
The Following User Says Thank You to Target70 For This Useful Post:
SimplePortal (04-16-2015)
Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras Circuit Motorsports Member's Car Journals 4 03-21-2013 05:45 PM
Subaru BRZ : Full Throttle, powerslide, hard revving & ride ESBjiujitsu BRZ Photos, Videos, Wallpapers, Gallery Forum 20 05-30-2012 07:43 PM
86 Full Throttle Video + another. Aus86 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 2 04-02-2012 08:07 AM
