Old 04-14-2015, 02:19 PM   #1
Raves614
Drives: 2013 FBM FRS; 2005 TJ Wrangler
first gear rattle
Recently got an frs with an ACT Race 6 Pad Sprung Clutch and lightweight flywheel. Sometimes when strating the engine seems to knock. Anyone have any ideas what this could be? It's only on the start and only happens every other time or so.
Raves614 is offline   Reply With Quote
Old 04-14-2015, 02:48 PM   #2
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
Race clutch? Sounds like part of owning the clutch. If it's made for performance, then it's going to be lacking in the sound department.
Old 04-14-2015, 02:52 PM   #3
Raves614
I fairly new to the tuning game, so I'm just making sure theres a big problem. Then car does shake pretty good at times too if that makes a difference.
Old 04-14-2015, 02:53 PM   #4
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
When you say start, it's when you turn on the car or when you roll into first?
Old 04-14-2015, 02:55 PM   #5
Raves614
Rolling in first. As in leaving a stop sign.
Old 04-14-2015, 03:00 PM   #6
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
That's sounds standard for clutch rattle.
@CSG Mike, unless I'm wrong?
Old 04-14-2015, 03:05 PM   #7
fika84
fika84's Avatar
Shaking could be caused by the harsher clutch engagement or from aftermarket bushings and/or motor mounts. If I didn't know much about tuning and aftermarket parts I wouldn't have bought a modded car... But you have it, do you know the complete list of mods?
fika84 is offline   Reply With Quote
Old 04-14-2015, 03:09 PM   #8
#maverick#
#maverick#'s Avatar
Drives: 2006 Pontiac GP (SOLD), 2014 FR-S
Sounds like your driving a 6 puck clutch add in a lightweight flywheel and solid trans bushings and itll sound like its tearing itself apart. 6 pucks also dont particularly like low rpms haha, have it checked out by a shop if you're worried.
"Project cars are like New Years Eve. Endless preparation, hype, a sleepless night of fun, followed promptly by massive headaches and regret." - Anonymous
#maverick# is offline   Reply With Quote
Old 04-14-2015, 03:46 PM   #9
CSG Mike
CSG Mike's Avatar
Normal for a setup like yours. Retuning the startup can eliminate the issue if its a startup issue that is intermittent.
Old 04-14-2015, 04:53 PM   #10
Shady195
Drives: '13 10 Series FRS #1203
Welcome to the world of pucked clutches
They make noise.
Because Racecar.
Side Note: There will come a point where you're really comfortable with that clutch and you will be able to roll off without any chatter.
Shady195 is offline   Reply With Quote
Old 04-14-2015, 06:50 PM   #11
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Don't mistake knock for chatter, which is what you have.
-alex
Old 04-14-2015, 11:39 PM   #12
Raves614
Thanks guys. I think you're right. I found the sweet spot to be between 1500-2000 rpms and have been getting a lot smoother take offs. Chatter seems like a better word.
Here's the parts list:
Full Blown Base Turbo Kit including:
FBM Base EL Turbo manifold
Garrett GTX2867R turbo
FBM Aluminum Wrinkled intercooler Piping with couplers
FBM 3" Downpipe
FBM 550hp Intercooler with cast tanks
FBM Intake Pipe
FBM Dump tube
Precision Turbo 39mm wastegate
Tial 50mm Q BOV
Bosch 550cc injectors
FBM 270LPH Pump
FBM Dual slim fans
Turbo Blanket
EcuTek Licesnce and Cable
Custom Dyno Tune from Hal@Dynosty for 93 octane
Custom Dyno Tune from Hal@Dynosty for e85
Motiv Concepts Front Pipe
Motiv Concepts Overpipe
MX-P Full Catback Exhaust
Full Blown Radiator
Cusco Oil Catch Can
Black Enkei Raijin Wheels 18x8.5
Michelin Pilot Super Sport Tires - 235/18/40 Front and 255/18/40 Rear
Front KNocking Noie and Gear Lever rattle Naughty AFRICA 17 10-26-2013 03:56 PM
Top Gear Crashes Helicopter During Filming of "Top Gear Korea" Episode SteveH Other Vehicles & General Automotive Discussions 7 02-13-2013 01:08 AM
No more 1st gear thump or 2nd gear notchiness kc4mne Scion FR-S / Toyota 86 GT86 General Forum 28 09-06-2012 09:39 PM
Transmission rattle while revving in gear with clutch both engaged and disengaged robo_robb Engine, Exhaust, Transmission 2 06-16-2012 02:35 AM
Reverse gear on the first and second gear side randytindoggy Scion FR-S / Toyota 86 GT86 General Forum 50 01-29-2012 02:21 PM
