Old 04-13-2015, 05:25 PM   #29
stevesnj
stevesnj's Avatar
The other things to cause this is low AT flud, bad gas/moisture in gas. Dump some dry gas in there.
My 2016 Build thread
Old 04-13-2015, 05:50 PM   #30
themajesticone
themajesticone's Avatar
Drives: '13 UM86
Originally Posted by spatcha88 View Post
Yessiree. All I have after market is my exhaust but the issue has been there long before. And my frs is out of warranty and already has the ecu flash. I might need someone to help me tune it. Where is delicious tuning?
Looks like you are in LA. Not too too far from you:
http://www.delicioustuning.com/contacts
I would give them a call and explain your scenario. Ask about their flex fuel kit and if it would a solution to your issue. Hopefully they can help you out
JRSC C30 91 oct | JDL UEL Header | Tomei Overpipe | Milltek Front Pipe | Milltek Catback | SPL LCA v2 | FA 500 v5 Coilovers 6k/7k | SPC Front Camber Bolts | Enkei RPF1 17x9 +35 | 245/40 Michelin Pilot Super Sport
themajesticone is offline   Reply With Quote
Old 04-13-2015, 08:13 PM   #31
spatcha88
Drives: 2013 Scion FRS Whiteout
Thanks man I just might. If I can't get this fixed I'm just going to sell the car. Last time I bought a toyota it was nothing but problems. The frs really made me want to give toyo one more try. This might be my last of the brand. Sorry if I offended anyone, I've just had nothing but bad luck with toyota a for some reason.
spatcha88 is offline   Reply With Quote
Old 04-13-2015, 08:49 PM   #32
themajesticone
Drives: '13 UM86
Usually you hear nothing but good things but sometimes there are always those lemons out there and people get unlucky .... I forgot to ask, did you already get your ECU replaced by toyota for a brand new one?
Old 04-13-2015, 09:05 PM   #33
FRS Johnny
FRS Johnny's Avatar
Drives: 2013 FR-S Whiteout MT
Had the same issue. The car would shudder and then die when I came to a stop. Once it died 4 times in a row right after I started the car over again and again. Another time the car died while I was making a left turn.. I had to turn the car back on in the middle of the intersection while still moving... Was freaked out for a split second, then just started it and drove off pissed.
The dealer said they would flash it when I went in for a free oil change. Drove it for two weeks and it still had the issue.. So I doubted if they actually even flashed the ecu. Just got the oft earlier than I expected to solve the issue which is a plus in the end.
When in doubt, throttle out!
FRS Johnny is offline   Reply With Quote
Old 04-13-2015, 09:47 PM   #34
spatcha88
Did the OFT fix your problem?
Old 04-13-2015, 09:47 PM   #35
spatcha88
And nope, the car was flashed in 2013 and I bought this car private party and is unfortunately out of warranty. I am beginning to believe it has to be the ECU :\
Old 04-13-2015, 09:51 PM   #36
spatcha88
Shit and I just noticed there's a hairline crack on the stock intake box, wonder if this could be an issue as well?
Old 04-13-2015, 09:53 PM   #37
FRS Johnny
FRS Johnny's Avatar
Yeah it did. I was already planning on getting of oft, but just bought it earlier cause of the idle dip.
Old 04-13-2015, 10:02 PM   #38
spatcha88
gahh mind helping a brotha out lol
Old 04-14-2015, 12:16 AM   #39
FRS Johnny
FRS Johnny's Avatar
lol, I would if I had the extra money to throw around, but I'd get more stuff I want/need...
don't worry. Just wait and save. Its much more rewarding!
Do you ever feel like an asshole for coming to a complete stop? Ozzman Off-Topic Lounge [WARNING: NO POLITICS] 53 01-20-2014 12:35 AM
Difficult to shift into first when coming to a stop ZackZ Scion FR-S / Toyota 86 GT86 General Forum 21 08-31-2013 12:05 PM
Shifter clicking when coming to a stop larryt1026 Issues | Warranty | Recalls / TSB 1 07-15-2013 07:34 PM
Strange sound coming from my car on idle bcmakesiteasy Engine, Exhaust, Transmission 2 10-05-2012 06:16 PM
Single knock when coming to a stop oops86 Issues | Warranty | Recalls / TSB 14 08-05-2012 01:17 AM
