Old 04-13-2015, 03:25 PM   #1
cnk
Drives: '13 DGM BRZ Limited
Bendpak QuickJack BL-5000
I purchased a Bendpak QuickJack BL-5000 last December and was able to use it for the first time yesterday to swap out my winter rims/tires for my summer set. Just a quick video that shows how it works in case anyone else was interested in it. I only raised it to the first level since I was only changing out rims/tires. It goes up one other level for a total height around 24". My car is lowered 1" and I was able to safely drive over the ramps and slide them out.
[ame="https://www.youtube.com/watch?v=2zjJKwSGuFc"]Bendpak Quickjack BL-5000 lifting Subaru BRZ - YouTube[/ame]
The Following 9 Users Say Thank You to cnk For This Useful Post:
Chaetagnath (04-13-2015), civicdrivr (04-13-2015), FRSBRZGT86FAN (12-10-2015), roddy (04-14-2015), saj (04-21-2016), soulreapersteve (05-20-2016), SPCorBUST (04-14-2015), Sportsguy83 (04-20-2015), zc06_kisstherain (05-13-2015)
Old 04-13-2015, 03:33 PM   #2
Andrew025
Andrew025's Avatar
Drives: Neptune GR86
I need that.
Where did you buy it?
Old 04-13-2015, 03:43 PM   #3
ryoma
ryoma's Avatar
that's nice. how much did you pay for it? and is it safe to crawl under or do you still need jack stands?
Old 04-13-2015, 03:52 PM   #4
cnk
I need that.
I got it from a groupbuy that was hosted on the garagejournal.com forums.
It was $1272 delivered. They have 2 models, the BL-3000 and BL-5000, capable of 3000lbs and 5000lbs respectively. There is a safety bar that locks into place in case the hydraulics fail. You could use some jack stands as a secondary safety net if you plan on going under the car. That is what I plan on doing, but that's just because I like to have a backup just in case.
The Following User Says Thank You to cnk For This Useful Post:
BatStig (04-13-2015)
Old 04-13-2015, 04:29 PM   #5
Freetime
Freetime's Avatar
Drives: Raven Manual FRS
apparently these things were plagued with problems of leaky quick couplings. Did yours have any leaking issues?
Freetime is offline   Reply With Quote
Old 04-13-2015, 04:40 PM   #6
DAEMANO
Time Traveller
The BL-3500 (3500 lbs capacity) is only about $1k on ebay. Seems like a really useful tool that'll pay for itself with time. Tempted.
Old 04-13-2015, 05:00 PM   #7
Andrew025
Andrew025's Avatar
Yeah, what has me wanting one is how small my garage is and wrangling my jack back and forth to both ends of my car to jack it up.
Jacking it up takes almost as long as whatever work I'm doing on it most of the time.
The Following User Says Thank You to Andrew025 For This Useful Post:
DAEMANO (04-13-2015)
Old 04-13-2015, 05:00 PM   #8
cnk
No leaks here. They had delayed production for a few months to work those issues out. I have the revised version with casters, improved retention mechanism for the safety bar, revised quick disconnects, etc. I get a little fluid when connecting or disconnecting, but that's only because I'm not doing it quickly enough. Once they are connected, no leaks.
Old 04-13-2015, 08:45 PM   #9
rice_classic
rice_classic's Avatar
Drives: Nevermorange FRS
I need this in my life.
Fluid changes, brake or suspension work, exhaust work and on and on.. All easier.
PRO86 | WTCC | STL
Old 04-13-2015, 09:34 PM   #10
Ec1990
Drives: '14 BRZ
How are the jacking points? Just on the pinch welds with the rubber blocks? No issues with the distance between blocks?
Ec1990 is offline   Reply With Quote
Old 04-13-2015, 10:07 PM   #11
cnk
I bought the BL-5000 because it is a little bit longer. It still does not span the 60" that are between the front/rear jack points. It's reach is 53" and it comes with some 1.5" and 3" rubber blocks. I used the 1" blocks and put the front on the jack point.
I had considered something like the Atlas Kwik-bay 7000, but that thing is like 900lbs and not easy to move around. Plus it would still not reach the 60" jack points. Overall, very happy with my purchase and it's made things so much easier and faster.
Old 04-14-2015, 12:08 AM   #12
SPCorBUST
SPCorBUST's Avatar
Was that full lift?
Setup 3: JR C30, DW 700, Grams 265, 3bar, FlexFuel, Moto-East
Setup 4: JR C30 HBP, DW 700, Grams 265, 3bar, FlexFuel, Church
Setup 5: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Built Motor
Setup 6: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Closed Deck Built Motor
SPCorBUST is offline   Reply With Quote
Old 04-14-2015, 12:08 AM   #13
Ec1990
Drives: '14 BRZ
Awesome. I figured using a jacking point anywhere along any part of the pinch weld wouldn't really be an issue.
Old 04-14-2015, 12:11 AM   #14
cnk
Originally Posted by SPCorBUST View Post
Was that full lift?
From original post:
Car for $5000? dem00n Other Vehicles & General Automotive Discussions 35 01-08-2014 03:44 PM
FS: 2013 White out Manual FRS under 5000 mi Matt Andrews Cars for Sale/Trade 17 12-09-2013 01:00 AM
Clutch dump at 5000 RPM? fasteddy BRZ First-Gen (2012+) — General Topics 20 08-22-2013 12:55 PM
Anyone else above 5000 miles too? Superhatch BRZ First-Gen (2012+) — General Topics 32 06-28-2012 12:08 PM
5000 to spend on what? MtnDrvr86 Other Vehicles & General Automotive Discussions 29 03-18-2010 04:10 PM
