Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > FT86CLUB Shared Forum > Regional Forums > AFRICA
Old 04-11-2015, 01:18 AM   #141
Sarx
Drives: 86
Thanks Sav!
Sarx is offline   Reply With Quote
Old 04-12-2015, 01:28 PM   #142
sav
Official anti-BS squad
sav's Avatar
Drives: Toyota 86 High 6MT
Pleasure.
Toyota 86 High 6MT (Satin Pearl White)
95RON SAV Tuned
sav is offline   Reply With Quote
Old 04-13-2015, 03:24 AM   #143
Cheddaa
Cheddaa's Avatar
Drives: 86 High SWP
Thanks for the detailed write up Sav. Got me me motivated to check in the engine bay. Inspection of the headlight connector reveals that I have the full 8wires already. Following the post by @HRTROB , the horn relay in the DRL position works. Car is high spec after Aug13. Now to go buy me a spare horn relay...
Cheddaa is offline   Reply With Quote
Old 04-13-2015, 03:26 AM   #144
sav
sav's Avatar
Cool stuff, I hope it works.
Mine has also got 8 pins, tenpin that is missing is on the headlight itself. I don't think you can easily see it without removing the headlight.
95RON SAV Tuned
Old 04-13-2015, 07:15 AM   #145
Cheddaa
Cheddaa's Avatar
Drives: 86 High SWP
Vehicle On, Lights Auto, Handbrake Up
Vehicle On, Lights Auto, Handbrake Down
Subaru want R330, Toyota want R150 but got no stock - ordered and now we wait.
Used the Heater relay for now as that seems to be the least essential item.
Old 04-13-2015, 07:17 AM   #146
Cheddaa
Cheddaa's Avatar
Drives: 86 High SWP
Old 04-13-2015, 07:19 AM   #147
momoPike
Drives: Toyota 86 High 6MT - Pearl White
R150 for just the relay?
momoPike is offline   Reply With Quote
Old 04-13-2015, 07:21 AM   #148
Cheddaa
Cheddaa's Avatar
Drives: 86 High SWP
Yep, didn't need to do any wiring on mine. I also checked under the steering wheel fuse box that the fuse was already there for DRL. Test first with horn/heater relay.
Old 04-13-2015, 07:28 AM   #149
Cheddaa
Cheddaa's Avatar
Drives: 86 High SWP
Looking back at earlier posts, and this doesn't appear nearly as bright as Sav's though...
Old 04-13-2015, 07:35 AM   #150
sav
sav's Avatar
Awesome, I wishbone was that simple.
The fact that they're on with the lights in auto means they're working. They should be very bright, it's probably just the photo making them look less bright.
95RON SAV Tuned
Old 04-16-2015, 11:01 AM   #151
Sarx
Drives: 86
Even though there are 8 wires you might also notice 2 pins missing inside your white block connector
Old 04-17-2015, 05:16 AM   #152
ShaunWRX
ShaunWRX's Avatar
Drives: 2014 Toyota 86
If it was a simple relay swop your dealer shoudve contacted you to have the relay fitted as it was actually forgotten during the assembly.
Satin White Pearl 2014 Toyota 86 High
ShaunWRX is offline   Reply With Quote
Old 12-07-2015, 10:10 AM   #153
Gaz86
Gaz86's Avatar
Hi guys
I’m new to the forum. I’ve just purchased an 86!
Mine was made in 2013 and the DRL did not work. When searching for answers to this problem on the internet, I found this forum. I followed the advice of putting my horn relay into the DRL slot and it worked, so I got Toyota to order me the relay (the correct one has one extra pin than the horn one) and now they work perfectly! Thanks
Gaz86 is offline   Reply With Quote
Old 12-07-2015, 10:12 AM   #154
Fish Eagle
Platinum Member
Fish Eagle's Avatar
Drives: Toyota 86 Vortech SC
Originally Posted by Gaz86 View Post
Hi guys
Welcome, congrats, and enjoy!!
Fish Eagle is offline   Reply With Quote
Cool feature of the daytime running lights! eriktherod Scion FR-S / Toyota 86 GT86 General Forum 26 08-31-2014 10:28 PM
***FR-S/BR-Z LED Daytime Running Lights 6K White*** Vicious LED Exterior Parts - The Rest 7 10-14-2012 03:38 PM
daytime running lights JDMrolla Scion FR-S / Toyota 86 GT86 General Forum 2 06-06-2012 10:09 PM
