| DIY (Do-It-Yourself) Guides For all DIYs. |
#29 |
Drives: Ultramarine FRS
What kit did you use that included the 2 OHM resisters
Instagram @nmgrizzlybear
Buschur built Evo VIII - SOLD Ultramarine FRS ![]() |
#30 |
Drives: Scion FRS
Works bell short hub
#31 | |
Drives: Scion FR-S
#33 |
Drives: Scion FR-S
#34 |
Drives: 2013 scion frs blue
#35 |
Drives: Scion FR-S
Do you think you can ask your friend how to know when the clockspring is properly positioned right? I've been trying to figure this out for months. I've tried different resistors, I've ask friends to help, still no fix yet
#36 |
#39 |
Clock spring should turn 2 and a half turns each way don't try to spin it past that to hard you will snap the flat wire inside there should be a clear window on the front face of it that should show a orange gear that lets you know it's at top dead center as for the nrg hub I believe you can just set it on without having to spin it around or anything |
#40 |
#41 |
Drives: Scion FR-S
Sorry, I meant to put nrg wheel and quick release with works bell hub. So if it's centered, it needs to be 2 1/2 turns each way? I noticed there's a clear window with the orange part in there. That should be on what side once I turned it center ? |
#42 | |
On the left if I recall.. I believe the nrg quick release should then just bolt on and your wheel should be straight and light should go off make sure your 2 ohm resisters are both in on the air bag plugs |
| Aftermarket steering wheel.. | _F-R-S_ | Cosmetic Modification (Interior/Exterior/Lighting) | 164 | 04-20-2018 05:29 PM |
| How do you keep cruise control with aftermarket steering wheel??? | kylefrs | Cosmetic Modification (Interior/Exterior/Lighting) | 32 | 04-06-2016 05:58 AM |
| Prova Steering Wheel Install | RallySport Direct | DIY (Do-It-Yourself) Guides | 38 | 08-05-2014 12:42 PM |
| How do you keep cruise control after installing a aftermarket hub and steering wheel? | Timtamtt | Cosmetic Modification (Interior/Exterior/Lighting) | 1 | 11-30-2013 07:17 AM |
| Aftermarket steering wheel HELP! | Juurian | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 06-03-2013 11:47 PM |
