Old 04-12-2015, 07:29 AM   #3235
nlowell
nlowell's Avatar
Drives: 2013 Scion FRS
Originally Posted by Triumphrider View Post
Anyone have any issues with the intercooler pipe rattling? Mine doesn't touch anything anywhere, however at engine start and at certain rpm just above idle I can hear it rattle. Anything above 2000rpm is fine..
I have the same description rattle and it drives me bonkers. I'm convinced it's my stock header heat-shield though and not the pipe as I have used a rubber pipe coupler to insulate the pipe from rattling at most locations. If I pound (with the side of my fist) on the KW bracket above the AC I can hear what I believe to be my heatshield rattle. Not sure what to really do about it besides maybe some large worm clamps...
nlowell is offline   Reply With Quote
The Following User Says Thank You to nlowell For This Useful Post:
Triumphrider (04-12-2015)
Old 04-12-2015, 10:36 AM   #3236
Boofneenee
Go-Kart Enthusiast
Boofneenee's Avatar
Drives: Toyota Scion FRS
Catless header without heat shield
FRS
Current mods: K&N air filter, OFT, OFH, berk high flow cat front pipe, Q300 exhaust, lighter wheels
Boofneenee is offline   Reply With Quote
Old 04-12-2015, 10:48 AM   #3237
Triumphrider
Triumphrider's Avatar
Drives: 2013 Scion FRS in white out
Lol I'm catless without shield
2013 Scion Frs AT in Whiteout, Borla UEL header, Greddy SP Elite AxleBack. Kraftwerks C38 Supercharger tuned by Moto East and 2 kid seats in the back.
Triumphrider is offline   Reply With Quote
Old 04-13-2015, 12:01 AM   #3238
projek_01
projek_01's Avatar
Drives: 1996 ST204, Series 10 FR-S
Tried the Carbon Drive App and it seems to be very inconsistent on my phone. I am guessing it is too noisy where my car is parked. I loosened it quite a bit after you guys mentioned it and now it seems quieter (still noticeable at idle). Now the belt vibrates (visually) where its a little slack. Is it too lose now?
Thanks!
Originally Posted by FirestormFRS View Post
Belt tension..if it whines at idle it's too tight, if it slaps at idle it's too loose. Get the carbon drive app and use it. I still had mine a bit tight @60hz reading but a 1/4 turn loose and it's spot on now.
projek_01 is offline   Reply With Quote
Old 04-13-2015, 01:32 AM   #3239
lordhustlerr
lordhustlerr's Avatar
Drives: GT86
Up for the question :-)
Originally Posted by lordhustlerr View Post
Hi fellow frs/brz Kraftwerks owners,
I'm a new KW owner who got 354hp using Ethanol. Because i track my car i feel i'm oblige to install an oil cooler. I found a shop who can install the oil cooler i bought. The oil cooler is not branded but pretty much solid. The problem is it won't fit on the KW kit because the oil filter host hit the bracket, so the shop who installed myt kw kit relocate the oil filter position near the rotrex. (It is circle in the photo)
Brothers do you think it will affect on how the oil filter works? Considering it has more distance from the engine. Do you think it will affect the pressure pushing the oil in the engine? How about the position of my Greddy oil catch can? I think KW guys should answer this, considering their kit might be accuse of the cause, if i will have engine failure in the future.
Thanks in advance,
and more power KW
lordhustlerr is offline   Reply With Quote
Old 04-13-2015, 03:01 AM   #3240
glamcem
glamcem's Avatar
Drives: 2022 BRZ Limited
Arrow Kraftwerks BRZ vs Kraftwerks Miata side-by-side
I've also posted this on Subaru BRZ's facebook page and wanted to share here too
my BRZ w/ @KraftWerks SC next to my friend's NC3 Miata also w/ Kraftwerks (Supercharger kit has been recently installed), both cars are built for track use with similar mods and tuned by @moto-mike from Moto-East . ..throttle response on the MX-5 was really good and a bit smoother than the BRZ -as we thought it would be, most likely due to advantage of a smaller C30-84 Rotrex unit (vs C30-94 in the BRZ kit), or Miata engine's flatter torque advantage in the mid range (where we have a dip) or maybe combination of both factors
I wonder what kind of numbers the Miata will put down on the dyno and how those will translate to lap times this season
hood vents and the removable clear tray on the Miata also looks also really good and makes sense for combating the heat at the track ,
glamcem is offline   Reply With Quote
Old 04-13-2015, 06:57 AM   #3241
FirestormFRS
Thanks!
The belt will move a bit. As long as you don't hear it audibly slapping it's not too loose.
FirestormFRS is offline   Reply With Quote
The Following User Says Thank You to FirestormFRS For This Useful Post:
projek_01 (04-13-2015)
Old 04-13-2015, 03:58 PM   #3242
Triumphrider
Just so everyone knows, the belt will stretch a bit. I have 600 miles on my car since I installed the charger and set the belt tension to 61hz. Over the last few days the belt slap got more and more, today I had to snug it up again and is back to being nice and quiet again
Old 04-13-2015, 08:09 PM   #3243
industrial
Add lightness!
industrial's Avatar
Drives: 17' WRX
I wish they just used a spring loaded tensioner. I've adjusted my belt almost everyday since I've installed my kit and started driving my car after winter hibernation. I'm tired of fussing with it.
industrial is offline   Reply With Quote
The Following User Says Thank You to industrial For This Useful Post:
CSG Mike (04-16-2015)
Old 04-16-2015, 12:37 AM   #3244
Triumphrider
@KraftWerks is it common for the belt to stretch a bit initially?
Old 04-16-2015, 01:31 PM   #3245
86SPEED
86SPEED's Avatar
Drives: The silvertrooper 10 series
My Belt stretched a bit, ive had to adjust mine twice after first install. As of right now with 11-12k miles the belt still visibly looks ok. Id have to assume it would though, i mean even the steel 520 chain on my sport bike gets stretched a little bit, i personally dont expect this belt to last the life of the car, I was talking to a customer that feels it should, even thought the OEM drive belt doesnt, i will most likely swap belts at the service interval of the supercharger, for me 20-25k, i dont think ill wait for that 30k mark. My fluid has already turned a grey.
-Thomas
86SPEED is offline   Reply With Quote
The Following 2 Users Say Thank You to 86SPEED For This Useful Post:
CSG Mike (04-16-2015), Triumphrider (04-16-2015)
Old 04-16-2015, 03:04 PM   #3246
DAN_BRZ
DAN_BRZ's Avatar
Drives: 2013 WRB BRZ Sport Tech
is there any other option for the traction fluid then the "rotrex fluid"?? $100 is steep
installing KRAFTWERKS C38 FROM RICKSPECD MOTOEAST TUNE & SKUNK2 ULTRA RAD / SANDWICH PLATE / GRAMS 550cc
JDL UEL PERRIN EXHAUST 2.5" OP 3" CATTED F 3" CATBACK - PERRIN MOUNTS PERRIN PULLEY KIT WHITELINE BUSHINGS WILDWOOD BBK ACT CLUTCH & FLYWHEEL KW V3 MTEC KARTBOY SS SEIBON ROOF SPOILER & FRONT LIP 57XTREME 18x9.5 +40 W/ 255/55/R18 MICHELIN PSS
DAN_BRZ is offline   Reply With Quote
Old 04-16-2015, 03:59 PM   #3247
CSG Mike
CSG Mike's Avatar
There is not.
It's not something you'll be doing a lot...
86SPEED (04-16-2015)
Old 04-16-2015, 04:09 PM   #3248
Triumphrider
I just took my car out and did some logging. A quick question for those more experienced... I had the traction control on when I was doing my logging. And to stay out of sight I was on an older bumpy road. If the traction control kicks in while doing a pull will that effect knock as the engine cuts in and out.
Kraftwerks Rotrex Supercharger Discussion nelsmar Forced Induction 697 01-18-2022 12:06 PM
All SUPERCHARGER kits compilation thread subatoy Forced Induction 76 03-10-2016 12:38 PM
Kraftwerks Supercharger?? umpadupa Forced Induction 1 08-05-2013 05:27 PM
