Old 01-21-2014, 12:42 PM   #29
hirollaz
Drives: 2013 Scion FRS 10 Series
I'm having the same issue, running catless UEL header, Ecutek tune, my CEL light came on with cruise control being used. CEL does disable the cruise control. My code was P0137, low voltage secondary o2.
hirollaz is offline   Reply With Quote
Old 01-21-2014, 01:05 PM   #30
FR-S Matt
You need to have the secondary O2 disabled through Ecutek. The only one that should be used is the primary.
Old 01-21-2014, 01:11 PM   #31
DJCarbine
Thupercharged
DJCarbine's Avatar
Just an update, ecutek tune can disable the dtc if you have no secondary o2 sensor, just ask your tuner
2013 FRS
Vortech V3 11psi
Revworks UEL - PLM Overpipe - MOTIV catted frontpipe - Invidia Q300
2019 Series.Grey STI - Stage1+ SF
DJCarbine is offline   Reply With Quote
The Following User Says Thank You to DJCarbine For This Useful Post:
post_break (04-22-2014)
Old 04-10-2015, 08:49 PM   #32
Jasiel9653
Drives: 2013 scion FRS
I had the same issue
Originally Posted by DJCarbine View Post
Backstory first...
Removed my secondary O2 sensor from my Borla UEL and installed a wideband sensor in its place. I have an ECUTEK tune, so I figured that the secondary oxygen sensor checking is removed and I thought nothing of it.
The next day I start the car and begin to drive. The CEL comes on after a few minutes, and when I press the cruise control on/off switch the cruise control light comes on but will NOT turn off. The wideband is also reading a rich air/fuel ratio (13.2) at idle when the car should be in closed loop (fully warmed up etc.)
Its almost as if its stuck in open loop or some sort of catalyst self-test mode where it runs rich at idle and doesn't use primary O2 sensor to trim fuel
WOT shows normal A:F of low 13's so I believe the wideband is getting accurate readings.
Does the ECU need the secondary O2 hooked up for some reason?
I know there was a thread stating that you don't need the secondary (as is common on older OBD-II cars), but it is creating some strange problems for me.
Anyone with any input?
I had the same issue i had some dc sports headers installed and nothing happened i drove for like a month and then i was on the highway and ia had my cruise control on and it shut down and the check engine light came on.I took the car to the dealer and they said it was bc of the o2 sensor so i heard that by installing a spacer on it you can fix the problem.
Jasiel9653 is offline   Reply With Quote
Cruise control malfunction totally Issues | Warranty | Recalls / TSB 20 02-26-2018 09:13 PM
Cruise control temporarily disabled? DarrenDriven Scion FR-S / Toyota 86 GT86 General Forum 15 06-29-2016 08:35 PM
Cruise Control 'set' light LeftFootBrake Issues | Warranty | Recalls / TSB 28 11-27-2015 08:38 AM
Cruise control notout86 Scion FR-S / Toyota 86 GT86 General Forum 50 05-13-2013 02:01 AM
Aftermarket cruise control... anyone? Yamajee Scion FR-S / Toyota 86 GT86 General Forum 10 05-10-2013 06:18 AM
