Old 04-09-2015, 01:37 AM   #99
Fastbrew
Drives: 2014 Pearl White BRZ
Best ride for least money is stock.
Fastbrew is offline   Reply With Quote
The Following 11 Users Say Thank You to Fastbrew For This Useful Post:
8R6 (04-09-2015), Captain Snooze (04-09-2015), chas3wba0 (04-09-2015), DGM33 (04-16-2015), GotBRZ1691 (04-16-2015), Hyper4mance2k (04-09-2015), RJasonKlein (04-09-2015), RobertPaulson (05-06-2015), TougeSlug (04-15-2015), Wayno (04-09-2015), wparsons (04-09-2015)
Old 04-09-2015, 05:53 AM   #100
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
That made me laugh! So succinct! I totally agree though.
Old 04-09-2015, 08:41 AM   #101
HunterGreene
Hail Magnet
HunterGreene's Avatar
Originally Posted by KoolBRZ View Post
...but I'm actually interested in getting the best ride for the least money.
I am really questioning why you bought this car if all the reason you bought it for was for comfort.
If that's all you are looking for, here, these have good ride quality, and aren't expensive:
Ford Fusion
Ford Focus
Nissan Altima:
Chevy Sonic
And pretty much anything Buick makes
It has priests in it?
The Following User Says Thank You to HunterGreene For This Useful Post:
Old 04-09-2015, 09:05 AM   #102
Shady195
Drives: '13 10 Series FRS #1203
Seriously why did you buy this car?
I'm really not trying to be a **** when I say that. However you bought a car whos SHINING wonderful characteristic was that it handles extremely well for its price point, then you go and fuck that up by trying to make it ride like a Cadillac.
There are plenty of sporty fun cars that would seem to cater to your needs much better.
I get it, its your car and you can do what you want but you're wasting time and money and frankly making yourself look like a clown on here by trying to turn it into something its not.
You bought the wrong car if you wanted to ride around on a cloud and haul shit in the back like a truck.
Shady195 is offline   Reply With Quote
Old 04-09-2015, 09:26 AM   #103
Dimman
Kuruma Otaku
Dimman's Avatar
Free speech is your right, but I'm actually interested in getting the best ride for the least money. I have a hydraulic coil spring compressor, so it makes changing springs much quicker than with the hook style threaded compressors. I've had all my struts out and springs changed 4 times in the last 3 days. I'm seriously wearing the threads off my wheels studs though. It wasn't till last night that I got my suspension to give a halfway decent ride.
Suspension isn't the only thing I've changed recently. Just this morning I discovered how the AVCS tables need to be adjusted to compensate for the lowered back-pressure of a free-flowing exhaust. I tried reducing the valve overlap previously, but that made it worse, so this morning I increased the overlap and behold, more power, and better mileage. So this week has been a two-fer for me, better suspension, and a better running engine.
#Winning!
Because titanium.
Old 04-09-2015, 11:37 AM   #104
wparsons
wparsons's Avatar
With no preload there is almost no shock travel left before hitting the bumpstops. Spring pressure, strength or preload gives shock travel, and the adjustable mounts give height. Sway bars add to the spring strength of the struts. My front springs are too soft, so I am using the front sway bar to help stiffen them up. The rear springs are firmer, so I've removed the rear sway bar. I'll probably increase the front preload and decrease the rear to help balance the difference between the two.
With all this playing, did you bother looking at the stock spring rate ratio front to rear, combined with the motion ratios, when deciding on what rates you want and removing the rear sway bar?
You do realize that the sway bars only add stiffness to independent motion right?? If both wheels hit a bump the sway bars aren't adding any stiffness at all.
flickr
Old 04-09-2015, 01:32 PM   #105
Hyper4mance2k
Alexandrino_Auto
Hyper4mance2k's Avatar
Drives: series.Blue
He doesn't and doesn't care to learn. Everything everyone has posted in his threads has yet to change a single opinion or thought on how thing do, or should, work.
The Shadetree Project: I turn wrenches
Hyper4mance2k is offline   Reply With Quote
The Following 2 Users Say Thank You to Hyper4mance2k For This Useful Post:
gramicci101 (04-09-2015), wparsons (04-09-2015)
Old 04-09-2015, 02:40 PM   #106
KoolBRZ
KoolBRZ's Avatar
Drives: Silver 2013 BRZ Ltd Auto 45,000 mi
I grew up in snow country, and after I learned to drive, drove mostly rear-wheel-drive cars. I used to love going out driving in the new snow, sliding sideways, feathering he throttle to keep the slide going... One thing I learned, you can't slide a front-wheel-drive car in the snow. It's just going to hit a curb. Four-wheel-drive cars are almost as bad as front-wheel-drive cars in the snow. They can't slide for shit.
This car slides wonderfully in the snow. It's even fun in the rain. Those front-wheel-drive cars you've shown are just transportation. They're no fun in the snow or rain. You can't drift them. They suck.
Life's too short to drive a car that's just transportation, that sucks, even if it is a hybrid.
Now I'll agree my efforts have been full of mistakes, but when I cancel out all the wrong choices, that sure narrows down the right ones. There is method to my madness however, by starting out making the wrong changes, they point out the right direction to go to make the right changes. For example, I thought I would get a better ride with softer dampening and softer springs. I found out, by making this change, that that is wrong. The heavy wheels/tires shake the whole car when they move very far up and down because the car was designed for lighter weight 16" wheels/tires. (Little-known-fact that.) The sway bars are what actually communicates that shaking to the rest of the car. By keeping the front sway bar and removing the rear one I keep the ability to corner the car, but I've reduced the shaking transmitted by the sway bars by 50%.
I'm trained in my daily work to question everything. But, just because I question things about these cars, doesn't mean I don't love them. It means I believe there are things the factory could have done better.
KoolBRZ is offline   Reply With Quote
Old 04-09-2015, 03:20 PM   #107
Pat
Pat's Avatar
Drives: 2023 BRZ
While I agree RWD cars are easier to slide than most AWD cars, saying AWD/4WD cars, "can't slide for shit" is taking it waaay too far in my opinion. I used to drift my A4 in the snow much more than my BRZ now. In fact, I once drifted it for several miles on end at speeds between 70 and 110 mph. It was an absolute blast, and something the BRZ would have a tough time replicating.
The Following User Says Thank You to Pat For This Useful Post:
Old 04-09-2015, 04:28 PM   #108
HunterGreene
Hail Magnet
I applaud your willingness to experiment and try new things--Personally, I just don't see the point in doing it with something that costs as much as my car, especially as I DD this and I don't really have the time. If this was a weekend toy or I had a ton of money, I would be less critical, of course.
As to your point I highlighted above--so why aren't our cars shipped with 16" wheels? What's your source for this info? The wheels aren't the selling point of these cars, so I don't see why the car would be designed with them in mind. I realize some of the trim levels overseas come on 16" wheels, but the vast majority have 17" wheels.
Old 04-09-2015, 04:45 PM   #109
Kostamojen
Actually all of the "base" models in the rest of the world come with 16's. Equivalent to the "premium" BRZ for example.
This car loves 16's. The reduced weight brings the drivetrain to life, the extra sidewall helps keep the rear end traction intact, and you can even run shorter sidewalls for better gearing.
The Following 4 Users Say Thank You to Kostamojen For This Useful Post:
HunterGreene (04-09-2015), KoolBRZ (04-09-2015), NissanGuy (04-10-2015), Ultramaroon (04-09-2015)
Old 04-09-2015, 04:54 PM   #110
HunterGreene
Hail Magnet
Its funny, I was going to say the same thing about the wheels, I figured it was just my "butt dyno" talking when I have the 16" wheels on during the winter.
On that much, I stand corrected.
Old 04-09-2015, 06:13 PM   #111
Captain Snooze
Drives: Red Herring
I do not know about the oem 16" wheels but when I was considering 16" wheels I found there wasn't much difference in weight between 16 & 17 inch wheels.
RPF1 17x8 + Yoko AD08 17x8 18 kgs
RPF1 16x8 + Yoko AD08 16x8 17 kgs
T66-F 17x8 + Kumho V710 16.8 kgs
T66-F 16x7 + Kumho V710 15.8 kgs
Old 04-09-2015, 06:21 PM   #112
RJasonKlein
RJasonKlein's Avatar
Drives: 2013 Scion FR-S 10 Series
I'm quite fascinated by your problem solving abilities - may I ask what it is that you do in your 'daily work'?
RJasonKlein is offline   Reply With Quote
The Following User Says Thank You to RJasonKlein For This Useful Post:
Say no to SWAY with our Anti-Sway Bar and Sway Bar Bushing Special. FRSport.com Brakes, Suspension, Chassis 0 01-23-2015 12:38 PM
FS:NY RCE Anti-roll/Sway Bar kit $250 snky_snky Brakes, Suspension, Chassis 2 08-19-2013 09:42 PM
FS: NY RCE Sway/Anti-roll bar kit $250 snky_snky Engine, Exhaust, Bolt-Ons 2 08-18-2013 12:09 PM
ST Suspensions Lowering Springs & Anti-Sway Bars Now Available @ BMS! Boston Motorsports Brakes, Suspension, Chassis 84 07-23-2013 11:42 PM
How to pick anti-sway bars FastLane1000 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 19 07-12-2013 05:06 PM
