Old 04-06-2015, 06:35 PM   #1
jaorocks1
jaorocks1's Avatar
Drives: 92 Prelude
NEW OBD2 Smog test checking ecu for tunes!?
Anybody know if this will have a problem for Ecutek or OFT buyers?
Link here:
http://alankandel.scienceblog.com/20...ade-with-star/
jaorocks1 is offline   Reply With Quote
Old 04-06-2015, 06:45 PM   #2
DJCarbine
Thupercharged
DJCarbine's Avatar
Isn't this pretty much what they already do in many states?
Chicago is an OBDII test, they are only concerned with emissions readiness monitors. I've passed in 3 different cars, all with tunes/reflashes.
I would be more worried about visual inspections, I think OBDII only tests are the easiest to pass
2013 FRS
Vortech V3 11psi
Revworks UEL - PLM Overpipe - MOTIV catted frontpipe - Invidia Q300
2019 Series.Grey STI - Stage1+ SF
DJCarbine is offline   Reply With Quote
Old 04-06-2015, 06:50 PM   #3
jaorocks1
jaorocks1's Avatar
Drives: 92 Prelude
Did you have to flash back to stock? Im also guessing you were running catted front pipe and headers?
The Following User Says Thank You to jaorocks1 For This Useful Post:
adjusts (05-26-2020)
Old 04-06-2015, 06:54 PM   #4
tonytduc
tonytduc's Avatar
i want to know too
tonytduc is offline   Reply With Quote
Old 04-06-2015, 07:00 PM   #5
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Considering you're exempt until 2018 at the earliest.... why worry about it now?
-alex
Old 04-06-2015, 07:00 PM   #6
DJCarbine
Thupercharged
DJCarbine's Avatar
Most tunes have the ability to make emissions monitors "ready" or ignore codes due to missing cats/evaporated equipment etc.
These features are rarely advertised as its sort of a touchy subject.
I've passed all testing with tunes on the ecu, several times without cats, and usually some form of forced induction. They don't even pop the hood, they only want to read the emissions monitors and keep the line moving. This depends on your local area of course.
No cats would fail a visual, and more than likely fail a true smog test with tailpipe sniffer.
Check your local laws on emissions testing to see what they do. Most places even allow one or two monitors to be "not ready" so you can do some tricks to pass anyways.
2013 FRS
Vortech V3 11psi
Old 04-06-2015, 09:44 PM   #7
billwot
Drives: '11 Cayman , '14 Camry, '11 Tacoma
...technicians will plug into the vehicles' on-board computers to find out how well the cars perform when they're actually on the road.
NC has been doing this for 5 years or so.
And starting this year, all cars less than 3 years old with less than 70K will be exempt from all testing.
billwot is offline   Reply With Quote
Old 04-06-2015, 10:36 PM   #8
Tromatic
LOL, CA. That crap spreads, unfortunately.
WTH is this:
Breitler noted, “The need for change is clear, officials say. A 2009 audit found that 19 percent of cars that initially passed a smog check ended up failing a roadside inspection within a year.”
Old 04-06-2015, 10:38 PM   #9
civdaddy
Drives: Slow
OBDII scan only testing works out great if you have a modified car or your income depends on car related repairs.
civdaddy is offline   Reply With Quote
The Following User Says Thank You to civdaddy For This Useful Post:
Old 04-06-2015, 11:35 PM   #10
clayrush
Drives: FRS,09 370z, 00 CelicaGT-S, 85 300Z
My 09 370z has a uprev flash. It passed fine.
clayrush is offline   Reply With Quote
Will headers cause me to not pass smog? 67corvette Engine, Exhaust, Transmission 39 11-13-2018 12:12 PM
CA Smog for Milltek Exhaust Decisis Engine, Exhaust, Transmission 6 01-09-2015 08:58 PM
Smog stock air intake davebrus Northern California 6 05-12-2014 01:42 PM
Smog & Tunes? fooddude Software Tuning 5 04-14-2014 05:18 AM
SMOG Issues SkullWorks Engine, Exhaust, Transmission 8 10-04-2012 02:23 PM
