Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > FT86CLUB Shared Forum > Regional Forums > NY / NJ / CT / PA
NY / NJ / CT / PA NY, NJ, CT, PA
Old 12-29-2014, 10:08 PM   #1
dp1
driving smoother faster
Drives: Sold
dp1 track build (NY)
Base Car
- 2014 Scion FR-S Monogram MT Firestorm, June 2014 - present, primarily track use in North East May-Nov.
Shops and Tuners
- Trusted advisers and parts suppliers: Mike @CSG Mike and David @CSG David from Counter Space Garage (CSG). Wouldn't have gone this far without their support.
- Mechanical: EFI Logics. Top notch shop in North East that I use regularly. Tons of experience servicing and driving track cars.
- Tuner: @DeliciousTuning (DeliciousTuning.com), FlexFuel Flash and Go (FNG) tune. Car feels great on track, AFR looks good through the rpm range.
- Engine Builder: Outfront Motorsports. Thanks to @DeliciousTuning for mentioning their work. Most impressed by (1) Good reputation, (2) Jeremy's openness and honesty about what they do, quality parts and labor, and (3) Confirmation from @CSG Mike who stopped by Outfront Motorsports in person to talk to Jeremy and agree on the final design.
- Sincere thanks to Mike @moto-mike at Moto-East for helping me sort out the car in 2014 after many problems with PrimeMotoring/Prime Motoring (mechanical) and JrTuned/Jr Tuned (tune). I would have never done business with them if a post like this had been available. Mike runs a great shop, is a master Ecutek tuner, owns and tracks a twin.
Consider the following when looking for a shop to build and maintain a track car:
- Few if any bad online reviews (even Yelp), and how any bad reviews are handled,
- Racers and instructors recommend the shop in person (at the racetrack) and online,
- Shop is owned and/or ran by racers who can be seen at race tracks,
- Other track cars can be seen serviced at the shop (Facebook, other online sources, visit in person),
- Shop is focused on track performance builds and not drag strip builds (very different design goals) or stance, bagging,
- Respectable age and experience of people running the shop and working on your car,
- Good experience when dealing with issues, small or big, on-line and in person,
- Good experience working on cars like yours,
- Valuable contributions to the online community, etc.
...choose wisely, your life may depend on it.
Engine Build
Design goals: Reliable whp @ OEM 12.5 compression @ 93/100 gas with Jackson Racing C38 SC and HBP. Engine should survive a "money shift".
Donor: 2015 engine with <3k miles.
- Custom CP Carrillo FA20 Pistons for BRZ/FRS 12.5:1 CR 86.5mm.
- Piston Ceramic Crown And Moly Skirt Coating.
- Carrillo Subaru/Toyota FA20 Pro-H 3/8 CARR Bolt Connecting Rods.
- King Performance FA20 Main and Rod Bearings.
- Ferrea complete set valve springs/spring retainers/spring seat locators/valves (+1mm exhaust)/springs.
- Subaru FA20 BRZ Left Intake + Exhaust and Right Intake + Exhaust Cam Gears.
- Fluidampr Subaru BRZ/Scion FR-S/Toyota 86 FA20/4U-GSE 2014+ Steel Internally Balanced Damper.
- Outfront Motorsports 1/2" Head Stud Kit.
- WPC Treatment for Bearings, H4 Crankshaft, Connecting Rod, Wrist Pin, Thrust Bearing, 4 Cyl Camshaft Set, Rocker, Valves, Valve Spring Retainers, Valve Springs, Rocker Arm Pivot, Oil Pump Gears.
- Motul Break-in Oil 10w40 for 50mi, then Valvoline 779309 SAE 10W-40 Premium Conventional Motor Oil @ 50mi, 100mi, 500mi, 1000mi, 2000mi, 3000mi, then Synthetic 10w40.
Engine Other
- Supercharger: Jackson Racing C38 with High Boost Pulley (HBP).
- MAP Sensor: Jackson Racing 4bar.
- Air-Oil Separator: Crawford AOS.
- Oil Baffle: Bluemoon Performance - FA20 / 4U-GSE - Baffled Oil Plate.
- Windshield Washer Reservoir: Ptuning Windshield Washer Reservoir kit.
- Engine mounts: Perrin.
- Air filter wrap: AEM 1-4007 Dry Flow Air Filter Wrap for car wash (with hood louvers) and driving in rain.
Cooling
- Oil Cooler: Jackson Racing (FI version).
- Radiator: Koyo + CSF filler neck.
- Fans: Custom CSG fan shroud and Spal fans.
- Hood louvers: TrackSpec Motorsports T1.
Exhaust
- Header and Overpipe: Tomei EL 4-2-1 header and overpipe.
- Front pipe: ACE catless.
- Tail End: Catback resonated exhaust Blitz Nür-Spec VS.
- Exhaust hangers: Perrin polyurethane exhaust hanger kit.
Drivetrain/Suspension
- Clutch/flywheel: ACT SB7-XTSS - Streetlite Flywheel.
- Dampers: JRZ RS (double adjustable) with 9 kg/mm (~500 lb/ft) front | 11 kg/mm (~600 lb/ft) rear springs.
- Limited Slip Differential: OS Giken 1.5 LSD, customized by Counter Space Garage @CSG Mike.
- Front lower control arm front spherical bearing: Cusco 956 464 AV.
- Front lower control arm rear bushing: Cusco 692 464 BV.
- Rear upper control arm front bushing: Cusco 965 464 LV.
- Rear upper control arm rear bushing: Cusco 965 464 IV.
- Differential mount collar: Cusco 965 928 A.
- Rear subframe collars: Cusco 965 927 A.
- Transmission Support: Perrin.
- Adjustable Rear Toe Arm: SPL.
- Bumpsteer Adjustable Front Tie Rod Ends: SPL.
- Titanium Rear Traction Arm: SPL.
- Titanium Rear Lower Camber/Control Arms: SPL.
- Adjustable endlinks: Whiteline KLC179 front/KLC182 rear.
- Rear adjustable toearms: Whiteline KTA147.
- Rear brace sway bar mount support: Whiteline KBR38.
Brakes
- BBK: Essex AP Racing Sprint + spare set.
- Rotors front BBK: Essex plain 2-piece AP front rotors (left and right).
- Rotors rear: Centric.
- Brake ducts: APR Performance brake rotor cooling kit.
- Brake pads street: Carbotech 1521 (front BBK size and rear OEM size).
- Brake pads autocross: Carbotech AX6 (front BBK size and rear OEM size).
- Brake pads track/HPDE: G-Loc R12 (front BBK size and rear OEM size).
- Brake lines: Stainless steel Spiegler (front and rear).
Rims/Tires/Wheels/Other
- OEM rims | Dunlop SP Winter Sport 3D 225/45-17.
- Enkei RPF1 black 17x9 +45 | Toyo Proxes RA1 255/40-17.
- FOR SALE Enkei RPF1 black 17x8 +45 | no tires.
- 949 Racing 6UL 17x9 +40 (Charcoal) | Toyo Proxes RA1 235/40-17.
- 949 Racing 6UL 17x9 +40 (Charcoal) | Continental ExtremeContact DW 255/40-17.
- Extended wheel studs: ARP.
- Lug nuts: 949 Racing Forged Lug Nuts - M12x1.25 - Black - Set of 20.
- Spacers: Hubcentric 12mm (Amazon) spacers for stock winter wheels and Enkeis RPF1 to clear AP Racing Sprint BBK.
Interior
- Gutted behind front seats, removed passenger seat.
- Seat bracket: Planted, driver side only.
- Seat: Sparco Ergo L.
- Heel/toe gas pedal attachment: Cusco.
- Shifter knob: Raceseng Slammer and Sphereology.
- Rearview mirror: Auto Dimming Homelink Mirror w/Compass Subaru BRZ.
Safety
- Roll bar: Autopowerindustries Race Roll Bar With Options (part# 60783), with removable diagonal and harness tubes.
- Helmet: G Force Pro CFG Carbon Fiber.
- Racing Suit: MIR Tri-Color Red Suit FIA SFI-5.
- Harness: Schroth Profi-II 6-point.
- Brake master cylinder brace: Perrin.
Electrical/Gauges/Data/Video
- @Beastronix custom 86Nanny with ACC pass-thru harness and 2 LED toggle switches. Automated 24/7 features - belt chimes disable, TPMS disable and airbag indicator disable. Switch 1 controls the nannies (PD). If the switch is left in the ON position the car starts in a default track mode. Flipping the switch off turns all nannies back on. Switch 2 controls fan lock. When the switch is ON the fans lock to 100% power. When the switch is off the fans obey the factory set of instructions by the ECU, they do not disable.
Install Instructions. NOTE: Extra "secure" ground wire on OBDII harness can be secured under the bolt at the front of the fuse panel seen in Step 7.
- Failsafe gauge (AFR/boost): AEM on the right side of the instrument panel (custom).
- Oil pressure gauge: Stack 3502 in a block8head.com pod, top left vent.
- Data Recording: AIM Solo DL (GPS + OBD2).
- Video Recording: One GoPro Hero 4 camera, two Hero Session cameras with mounts attached to the roof and to the roll bar, facing front driver/rear.
- Video Editing: AIM Race Studio 2 to merge video and data.
- ECU Diagnostic: DashCommand (via MX) on iPhone.
Aero
- Front Splitter: APR Performance - Front Wind Splitter.
- Rear Wing: Voltex GT Wing Type 2 (1600mm).
- Rear Skirts: APR Performance - Rear Bumper Skirts.
- Side Skirts: APR Performance - Side Rocker Extensions .
Exterior
- Taillights: Toms Red USDM.
- Side markers: clear.
- Badges: Front and rear Toyota black, similar to this.
dp1 track suspension reinforcements (bushings, links, sways, arms).
dp1 track car mods that pass NY inspection - street legal?.
dp1 tires (reference/research/reviews).
dp1 track days (north east).
dp1 reference (maintenance/consumables/configurations).
Other topics of interest
- Steering issue under braking ! (steering "locks up" in high G downhill turns).
- Car suspension tuning guide by Rapid-Racer.com.
- Dsportmag.com - Shock tuning 101 and Suspension 201.
dp1 is offline   Reply With Quote
Old 12-29-2014, 10:12 PM   #2
whataboutbob
AutoX-10/10ths every run
Nice build.
Build thread:Here
Old 12-30-2014, 11:42 AM   #3
dp1
Drives: Sold
Old 12-30-2014, 01:05 PM   #4
campy
No rice, no life
campy's Avatar
Drives: 2013 Asphalt FR-S
Originally Posted by dp1 View Post
A number of people in the area reached out since the initial build and the "flying wheel" accident
Were you the one who hit that stray truck wheel on the highway?
I also have the JRSC kit with the factory tune. Do you feel like you need both the JR oil cooler and Koyo rad to keep temperatures down at the track? My impression was that most people were content with only the oil cooler.
campy is offline   Reply With Quote
Old 12-30-2014, 02:27 PM   #5
dp1
Drives: Sold
I'm the one...unlucky to catch it but lucky to walk away from it
You need an oil cooler for track but you don't need Koyo rad...I just wanted extra insurance but it's not necessary.
Old 12-30-2014, 07:31 PM   #6
AZP Installs
AZP Installs's Avatar
Drives: '11 STi->'14 BRZ | '14 Touareg TDi
Send a message via AIM to AZP Installs
I would say to change out your fluids. OEM fluids just suck big time.
Great build though!
What kind of Oil Temps/Pressures are you seeing on track with the JR Oil Cooler?
-Mike Paisan
Maintaining, Modifying and Educating TriState Enthusiasts since 2001.
Like us on Facebook! | E-mail: sales@azpinstalls.com | 725 Fairfield Ave | Kenilworth, NJ 07033 | 908.248.AZP1 (2971) |AIM: AZP Installs
"Race Tested, Enthusiast Approved!"
AZP Installs is offline   Reply With Quote
Old 12-30-2014, 08:32 PM   #7
dp1
Drives: Sold
Hi Mike, thanks and I agree re fluids, will get them replaced in the spring. Got free (OEM) oil change and tranny fluid when they replaced the tranny under warranty.
Don't have an oil pressure gauge. Oil temps on a very hot and humid track day were in mid 240s iirc.
See that you had fun in Miami, way to go
Great build though!
-Mike Paisan
Old 04-05-2015, 04:48 PM   #8
dp1
Drives: Sold
Track timing evolution: Started with Harry's Lap Timer and built-in iPhone GPS (1Hz - up to 1 sec delay, way too slow to capture fast transitions), then moved up to the external bluetooth GPS Dual 150A (5Hz - up to 0.2 sec delay, much better), and now VBOX Sport (20Hz - up to 0.05 sec delay, pretty much perfect) is on it's way...little pricey but it's a long-term investment.
Old 04-05-2015, 04:53 PM   #9
dp1
Drives: Sold
Go-karting: Great way to fill the winter track/ax void. Took a 1hr 1-on-1 instruction today at GPNY to get into 9hp instead of standard 6hp karts...wow, what a difference.
Old 04-05-2015, 08:01 PM   #10
Alan
Alan's Avatar
Drives: 2013 SWP BRZ Ltd. / E60 M5
What made you chose VBOX over AIM Solo?
Hope to see you again at an event this year.
2013 BRZ Limited | SWP | Verus Ventus 1 and High-Efficiency Rear Wing | Invidia N1 Ti | JR Oil Cooler | RCE T2 | RaceSeng Cas/Cam | SPL LCA & TA | Wilwood/RR Racing Stage II/Sport Performance | XP10 | Apex ARC-8 | Toyo R888R | 245/40-17 | Sparco Ergo II/Evo II | AIM MXP | SmartyCam GP HD 2.2
Alan is offline   Reply With Quote
Old 04-05-2015, 08:19 PM   #11
dp1
Drives: Sold
Would be great to see you at an event
VBOX because I wanted portability and a better GPS, since I review video (GoPro attached to the middle/inside rear window) of my track/ax runs with data overlays. I already use and like Harry's Lap Timer (iPhone) and MX WiFi obd2 adapter.
Old 04-05-2015, 09:36 PM   #12
Alan
Alan's Avatar
Ah, so it sounds like you did not want to leave the Harry's/OBDII setup you currently have. I am starting at square one (other than already having a Go-Pro) so I'm trying to make the decision.
Also, Ohlins was on my short list of coilovers for this year, but I think I am leaning towards RCE Tarmac 2 (re-valved/sprung KW V3) instead. Will be pared with RaceSeng Cas/Cam and read 1" mounts, rear LCA and toe arms. Thoughts? Not my daily driver but does see some weekend/winter fun driving.
One last question - Does your P3 work at the same time as your OBDII BT dongle?
Old 04-06-2015, 06:29 AM   #13
dp1
Drives: Sold
My 2014 FR-S monogram firestorm (JRSC with street/AX/track setup)
That's right, I just wanted a faster and portable GPS, happy with everything else.
Not familiar with dampers other than stock, Ohlins and Bilstein B16. I changed springs on Ohlins and had them revalved, to allow a little more rotation, more at low than high speed. You do want camber in front and rear, at least -2.0 and little more negative in front, so you're looking at the right parts. Also consider adjustable endlinks.
P3 doesn't work at the same time as MX, as both use obd2.
Old 10-03-2015, 09:41 PM   #14
dp1
Drives: Sold
After two years and two done up twins, I've been thinking about alternatives i.e. Cobra GT350 or track prepped C5/C6 (never owned American muscle and already owned Boxster and Elise). However, 3 days at Palmer Motorsports Park with NASA last weekend confirmed that my car is now set up so well for my HPDE and AX needs that I'd be foolish to let it go...decided to keep it for at least another year and a new Scion iA (AT) is taking over the daily commute.
Megan Racing Coilovers - Street / Track / EZ STREET - Starting at $699 Shipped GuerillaRacing Brakes, Suspension, Chassis 149 05-12-2015 05:53 PM
2014 Firestorm FRS Monogram "Steezy" Thatdudesteveo Member's Car Journals 6 06-01-2014 03:38 PM
New Firestorm Monogram sinical Scion FR-S / Toyota 86 GT86 General Forum 21 06-01-2014 01:41 PM
Smythe's FR-S slow build (Firestorm Monogram MT) NVSmythe Member's Car Journals 5 05-09-2014 04:48 PM
Scion tC and FR-S 2014 Monogram Series to be available in early 2014. Moto-P Scion FR-S / Toyota 86 GT86 General Forum 655 01-10-2014 05:03 PM
