Old 04-05-2015, 09:18 AM   #15
raven1231
Originally Posted by rickybutl View Post
245-35, I think this is fitting with rubbing. Sometimes you will rub depending on the tire brand, but overall it will give you a better look in the front (in my opinion)
So I'm guessing if the 245-35 rubs that the 255-35 will as well. When you say rubbing do you mean against the top of the wheel well or when turning
Old 04-06-2015, 03:02 AM   #16
rickybutl
Drives: I have BMW i3
Sorry mate, I mean that, 255/35/18s fit without rubbing. Sometimes you will rub depending on the tire brand, but if you used branded tire so no problem
rickybutl is offline   Reply With Quote
The Following User Says Thank You to rickybutl For This Useful Post:
raven1231 (04-06-2015)
Running but going nowhere. VictorKassil Issues | Warranty | Recalls / TSB 60 02-04-2015 07:18 PM
RPM dip with A/C running BunnyRZed Issues | Warranty | Recalls / TSB 31 10-22-2014 09:56 PM
Running e85? HSayaovong Engine, Exhaust, Transmission 16 04-24-2014 11:05 PM
Something running while car is off. grostoine Issues | Warranty | Recalls / TSB 5 04-11-2014 08:56 PM
Running 19's SocalBurt Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 8 09-04-2012 02:45 PM
