Old 04-04-2015, 05:57 PM   #1
CallmeDave
CallmeDave's Avatar
Drives: 13 BRZ, 07 WRX
Will I notice a diffrence with rims that weigh 2lbs more?
Found the wheels I want at a reasonable price only problem is they are two pounds heavier than stock wheels.
Will I even notice? It's not going on a road course of autocross car just a summer DD.
Wish I could find a lighter BBS mesh style without breaking the bank.
Thanks guys.
13 BRZ Premium. 07 WRX.
CallmeDave is offline   Reply With Quote
Old 04-05-2015, 10:16 AM   #2
jflogerzi
jflogerzi's Avatar
Also dont forget tire weight as well. If those are equal i would say as a dd no you should be fine. There might be a very slight difference in acceleration
2013 Series 10 FRS #553
The Following User Says Thank You to jflogerzi For This Useful Post:
CallmeDave (04-05-2015)
Old 04-05-2015, 10:20 AM   #3
CallmeDave
CallmeDave's Avatar
Thanks. That's what I'm thinking. I'll be swaping over the stock tires so I shouldn't see a diffrence with wheels that weigh 21.8lbs. I hope ha
Old 04-05-2015, 11:42 AM   #4
tigermack
STX 188
tigermack's Avatar
Drives: STX BRZ
Send a message via AIM to tigermack
From experience, you can feel the difference. Especially on a lower powered car like ours.
tigermack is offline   Reply With Quote
Old 04-05-2015, 12:39 PM   #5
Vracer111
Vracer111's Avatar
Drives: '13 Nissan Frontier (4.0L 6spd 2WD)
Thanks guys.
Stock wheels are nearly 21lbs...so you're looking at 1lb difference.
For $190 a wheel you could get the Kosei K8R (about to be released) which are 15.4 lbs....
https://www.tirerack.com/wheels/Whee...t+Grey+Painted
Had a '13 FR-S Asphalt 6spd manual (bought new 5/25/12, sold 6/10/20) but needed to let her go... she will be missed.
Vracer111 is offline   Reply With Quote
The Following 3 Users Say Thank You to Vracer111 For This Useful Post:
CallmeDave (05-27-2015), jimmillion (05-24-2015), NWFRS (05-24-2015)
Old 04-05-2015, 01:01 PM   #6
DAEMANO
Time Traveller
IMO you wont feel any change in acceleration, but you will feel it in the steering (that is until you get used to it).
Old 05-24-2015, 01:39 AM   #7
jimmillion
Power Ranger Elite
jimmillion's Avatar
Drives: '13 WRB Sport-tech
I've been on the hunt for BBS LM reps or at least some type of mesh rims and these are pretty nice and would be a good compromise. Looks like the Apex ARC-8's I want except in a practical size and offset.
@CallmeDave which mesh rims were you eyeing?
jimmillion is offline   Reply With Quote
Old 05-24-2015, 09:39 AM   #8
wparsons
wparsons's Avatar
You'll feel more difference in steering from grippier tire compounds or change in offset than you will from a gain of 1-2lbs per wheel.
flickr
Old 05-24-2015, 09:51 AM   #9
churchx
churchx's Avatar
Drives: 2014 GT86
But then again one can lighten by 10lbs less per each wheel. And install lighter BBKs. That, i guess, will be noticeable.
Old 05-27-2015, 09:45 PM   #10
CallmeDave
CallmeDave's Avatar
Damn I wish I would of seen those!!!
Old 05-27-2015, 09:53 PM   #11
CallmeDave
CallmeDave's Avatar
I got these BBS's. Only noticed it took a little more brake petal than what I thought was normal but I got used to it.
IMG_9253.jpg by Grayman Dave, on Flickr
The Following User Says Thank You to CallmeDave For This Useful Post:
cslntuee (05-29-2015)
(All New) DND Tall Motorsport Shift Knob (Weighted: 1kg/2.2lbs) JonMotoring Cosmetic Modification (Interior/Exterior/Lighting) 26 01-20-2015 06:46 PM
How much does the frs monogram Weigh? Astroboy Engine, Exhaust, Transmission 9 02-10-2014 08:31 AM
Full Spectrum Power Pulse P3 Battery Group Buy!!! Only 2lbs Evasive Motorsports Groupbuys 16 10-17-2013 06:25 PM
Can someone explain the diffrence between catback exhaust and axleback exhaust? speedy racer Engine, Exhaust, Transmission 12 09-23-2012 12:24 PM
How much does the subbie boxer weigh? (4 cyl) Myka Engine, Exhaust, Transmission 32 04-05-2010 01:22 AM
