Old 04-03-2015, 12:26 PM   #1975
Sirsimon
Sirsimon's Avatar
Drives: 2021 GR Supra A91 Edition
Originally Posted by Pat View Post
The APR kit is more expensive and maybe better built. But the TF puts the air right into the rotor veins where it needs to go. The APR kit blows air onto the rotor face, which generally is less effective. If you want bling, go APR. If you want cool brakes without spending more than necessary, go TF.
Appreciate it. If one wanted function + form, do you think the TF kit would have enough length to work with the pretty APR ducts? </end stupid questions>
Sirsimon is offline   Reply With Quote
Old 04-03-2015, 01:08 PM   #1976
Pat
Pat's Avatar
Drives: 2023 BRZ
Probably, but I'm not sure. With the APR ducts you need to make major modifications to the washer fluid reservoir. If you're willing to do that, and spend the extra coin, it might be a great option. I would do some research on it first, though. I'm guessing it's been tried and maybe isn't worth the hassle.
Old 04-03-2015, 01:16 PM   #1977
CSG David
CSG David's Avatar
So for those of you who track your SC 86 quite a lot (thinking track days here), do you feel that stock brakes + upgraded pads are sufficient, or are AP Racing Brakes a must?
Proper race/track pads + high quality DOT 4 brake fluid work well.
There are pros/cons of brake ducting. This is something we can work with you identify what you are really looking for. For most, ducting works well especially due to the type of pads people are running. For other setups, ducting is actually a bad idea. On top of that, you'll need to find a creative method to funnel a good amount of air with any FI kit.
If you track quite often over the course of the year, you will find that BBKs are there for consistency and reduced brake consumption (over time).
The Following User Says Thank You to CSG David For This Useful Post:
Sirsimon (04-03-2015)
Old 04-03-2015, 03:53 PM   #1978
CSG Mike
CSG Mike's Avatar
Looking at purchasing this oil cooler.
http://www.maximalperformance.com/fr...oil-cooler-kit
Is the main differences between the maximal and JRSC cooler, JRSC is 15 row, mounting bracket and the hose for the rotrex cooler?
The cooler bolts to the plastic under-body between the radiator and front bumper.
Sorry, pass.
Old 04-03-2015, 10:40 PM   #1979
Jmonty
Realtor/ Principal Broker
Drives: JRSC BRZ GBS LTD 2010 LTD Outback
Originally Posted by fasteddy View Post
The temp sensor you relocated for the outside air is too close to the radiator. I have this issue as well. I made a bracket and moved it away but mine still reads high.
I am told it needs to be out in the open in the moving air to be correct.
That was the only thing I thought they missed on this kit. They should have included a bracket to move the sensor and a harness extension for it.
This is only a BRZ issue, FRS's don't have the outside temp sensor.
It does not affect anything to do with the engine, it is only for the dash readout.
Pat
Is there a fix to correct this? CSG do you ideas?
Jmonty is offline   Reply With Quote
Old 04-03-2015, 11:59 PM   #1980
dj2020
I want to confirm if I did my install correctly: did you guys reinstall the air deflection shield from the upper front bumper area before buttoning up the front bumper? This was removed in Step 4, page 4 of the install manual.
dj2020 is offline   Reply With Quote
Old 04-04-2015, 01:53 AM   #1981
SPCorBUST
SPCorBUST's Avatar
The boost is back, and man, it feels good.
Have a crank pulley, accessory pulleys and driveshaft on standby for after I secure a clutch and rims.
Want to get a feel for the setup on 91 and E85 before going after peppiness.
Setup 3: JR C30, DW 700, Grams 265, 3bar, FlexFuel, Moto-East
Setup 4: JR C30 HBP, DW 700, Grams 265, 3bar, FlexFuel, Church
Setup 5: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Built Motor
Setup 6: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Closed Deck Built Motor
SPCorBUST is offline   Reply With Quote
The Following 4 Users Say Thank You to SPCorBUST For This Useful Post:
*LongFella (04-04-2015), CSG Mike (04-04-2015), dj2020 (04-04-2015), Xuningshen (04-05-2015)
Old 04-04-2015, 08:00 AM   #1982
ScionOfHorus
ScionOfHorus's Avatar
Drives: 2015 Series.Blue BRZ
Nope
ScionOfHorus is offline   Reply With Quote
Old 04-04-2015, 09:06 AM   #1983
The Slow One
Track Junkie
Drives: Argento Scion FR-S
I installed mine just fine
The Slow One is offline   Reply With Quote
Old 04-04-2015, 01:29 PM   #1984
CSG Mike
CSG Mike's Avatar
Snaps. Welcome to the CARB legal club.
Old 04-04-2015, 01:29 PM   #1985
CSG Mike
CSG Mike's Avatar
You can trim it to go around the charge pipes if you like, but we do not.
dj2020 (04-04-2015)
Old 04-04-2015, 01:31 PM   #1986
CSG Mike
CSG Mike's Avatar
You can relocate it to the clean air between the intercooler and front bumper opening, but there's really no way to make it fully functional with all the additional piping in the way. You can always remove a faux fog light, and place it directly behind that opening...
Old 04-04-2015, 01:35 PM   #1987
dj2020
Looks like everything worked out okay in that area. I did not have to trim the deflection shield and it still bolted back on.
Old 04-04-2015, 04:24 PM   #1988
0351USMC
0351USMC's Avatar
Drives: 2014 FRS JRSC'd
Question for the guys running a moto-east tune on the JRSC kit, what Rev limit is optimal? 7850,8050 or 8150? Keeping in mind my car will have a lighter flywheel and lightened pulleys.
0351USMC is offline   Reply With Quote
Jackson Racing Rotrex Supercharger System Info and Discussion Jackson Racing Forced Induction 827 04-06-2020 04:56 PM
Jackson Racing Supercharger Press Release and Info CounterSpace Garage Forced Induction 110 01-03-2017 09:04 PM
jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! CSG Mike Forced Induction 24 04-27-2016 12:59 PM
Jackson Racing supercharger NoppyNop Forced Induction 241 06-26-2014 03:05 PM
Jackson Racing Supercharger Pre-Order Sale, $200 off! Xero-Limit Forced Induction 2 03-05-2014 04:14 PM
