Old 04-03-2015, 02:06 AM   #1961
dj2020
Just came back from a test drive from my fresh install and noticed that the Outside Temp gauge on the dash is way off. But when I read the ambient air temp via the OBD2, it is definitely more in line with the actual temperature. I did have to relocate a temp sensor from the front of the radiator and zip tie it to the side per the JRSC oil cooler install. What is causing the two different temperatures? Is there a second temp sensor that I might have messed up during the install?
dj2020 is offline   Reply With Quote
Old 04-03-2015, 02:19 AM   #1962
dj2020
Old 04-03-2015, 05:15 AM   #1963
Xuningshen
Drives: Subaru BRZ
Its because your new oil cooler is radiating heat. the sensor that you relocated is picking it up. Mine is also doing it.
2014 WRB BRZ
Xuningshen is offline   Reply With Quote
Old 04-03-2015, 09:23 AM   #1964
*LongFella
*LongFella's Avatar
Drives: 2014 Scion FR-S|Whiteout
It's normal. Those things are never really right anyways...
My 2014 FRS build thread: http://www.ft86club.com/forums/showthread.php?t=52071
“You might be poor, your shoes might be broken, but your mind is a palace.” - Frank McCourt
*LongFella is offline   Reply With Quote
Old 04-03-2015, 09:25 AM   #1965
fasteddy
The temp sensor you relocated for the outside air is too close to the radiator. I have this issue as well. I made a bracket and moved it away but mine still reads high.
I am told it needs to be out in the open in the moving air to be correct.
That was the only thing I thought they missed on this kit. They should have included a bracket to move the sensor and a harness extension for it.
This is only a BRZ issue, FRS's don't have the outside temp sensor.
It does not affect anything to do with the engine, it is only for the dash readout.
Pat
fasteddy is offline   Reply With Quote
Old 04-03-2015, 10:55 AM   #1966
ApolloSki
Stealth
ApolloSki's Avatar
Drives: Ultramarine FR-S
Pat
My FRS reads outside temperature just as poorly as any BRZ!
ApolloSki is offline   Reply With Quote
Old 04-03-2015, 11:00 AM   #1967
dj2020
Jackson Racing Supercharger Owners Thread
That makes sense. The air temp sensor used to sit in front of the radiator open to air when we're driving. Now it is being blocked by the intercooler and engine oil cooler. Lots of warmer air radiating from that area now!
Old 04-03-2015, 11:33 AM   #1968
Sirsimon
Sirsimon's Avatar
Drives: 2021 GR Supra A91 Edition
So for those of you who track your SC 86 quite a lot (thinking track days here), do you feel that stock brakes + upgraded pads are sufficient, or are AP Racing Brakes a must?
Sirsimon is offline   Reply With Quote
Old 04-03-2015, 11:35 AM   #1969
ScionOfHorus
ScionOfHorus's Avatar
Drives: 2015 Series.Blue BRZ
@theSlowOne
ScionOfHorus is offline   Reply With Quote
Old 04-03-2015, 11:41 AM   #1970
sw20kosh
Drives: 2013 Black FR-S
If I had to do it all over again, the AP Racing Sprint Brake kit would be the second mod I do after a MANDATORY oil cooler kit. The AP kit allows you to avoid brake fade and sometimes more than double the life of your pads. Thus the AP kit makes sense if you track a lot.
And if you plan on FI later on, do not get a kit like the perrin 13 row series 6 oil cooler. It is way way too small for track duty in non-winter months with FI. I currently run a 25 row series 9. The JROC is a good kit for track. I have seen it sufficient up to 280ish whp. Maybe CSG can chime in on if it is sufficient at 350+ whp.
Old 04-03-2015, 11:45 AM   #1971
Pat
Pat's Avatar
Drives: 2023 BRZ
Originally Posted by ScionOfHorus View Post
@theSlowOne
I don't think a big brake kit is mandatory. I drive the car hard, but for no more than 20 minutes at a time. Good pads and fluid will get you 75% of the way there. I just installed the Touge Factory duct kit. From others' reports on here, that gets you the last 25% of the way there.
Don't get me wrong, the AP kit is fantastic. But if your primary concern is reliable stopping, I wouldn't consider it mandatory.
Also, if you spend a lot of time on a track, it may make economic sense to get the AP kit.
Old 04-03-2015, 12:03 PM   #1972
Sirsimon
Sirsimon's Avatar
Thanks everyone - I have the JR oil cooler, and will be getting it installed in a couple of weeks. Brake ducting does seem like a wise investment. On my last Subie I had 6 pot Alcon brakes that we're fabulous, so the pedal effort needed on the 86 is kinda new to me (the Alcons felt telepathic).
Are there key differences between the APR and TF brake duct kits I should be aware of?
DJ
Old 04-03-2015, 12:05 PM   #1973
fasteddy
Sorry, I must be wrong. I did not think they had the outside temp indicator.
Old 04-03-2015, 12:23 PM   #1974
Pat
Pat's Avatar
Drives: 2023 BRZ
DJ
The APR kit is more expensive and maybe better built. But the TF puts the air right into the rotor veins where it needs to go. The APR kit blows air onto the rotor face, which generally is less effective. If you want bling, go APR. If you want cool brakes without spending more than necessary, go TF.
Jackson Racing Rotrex Supercharger System Info and Discussion Jackson Racing Forced Induction 827 04-06-2020 04:56 PM
Jackson Racing Supercharger Press Release and Info CounterSpace Garage Forced Induction 110 01-03-2017 09:04 PM
jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! CSG Mike Forced Induction 24 04-27-2016 12:59 PM
Jackson Racing supercharger NoppyNop Forced Induction 241 06-26-2014 03:05 PM
Jackson Racing Supercharger Pre-Order Sale, $200 off! Xero-Limit Forced Induction 2 03-05-2014 04:14 PM
