Old 04-01-2015, 06:19 PM   #3165
Triumphrider
Triumphrider's Avatar
Drives: 2013 Scion FRS in white out
Yeah I'm not sure of the difference between the 2 system pulley wise
2013 Scion Frs AT in Whiteout, Borla UEL header, Greddy SP Elite AxleBack. Kraftwerks C38 Supercharger tuned by Moto East and 2 kid seats in the back.
Triumphrider is offline   Reply With Quote
Old 04-01-2015, 06:29 PM   #3166
zERoTu
Drives: 1st RBv2 10 Series FRS
Probably nothing. Hehe. Let me know. I'll try to use this app again when I'm at home. Less ambient noises.
zERoTu is offline   Reply With Quote
Old 04-01-2015, 06:49 PM   #3167
Triumphrider
I'll go take a peak now... Yes mine was very sensitive to any ambient noise
Old 04-01-2015, 06:56 PM   #3168
Triumphrider
So from what I can see I have a 100 crank and a 75 SC pulley
Old 04-01-2015, 07:00 PM   #3169
zERoTu
Icic. Ok. Thx.
Old 04-01-2015, 08:50 PM   #3170
zERoTu
It's at 49hz atm. Gonna leave it I def don't want to go tighter unless @KraftWerks wants me to :P
Old 04-02-2015, 01:38 AM   #3171
pgranberg11
BoostedBRZ
Drives: Turbo BRZ
installed my c38 kit!!! myself and a good friend and some beer. Finally worked out the kinks and it drives nice. I hit about 12psi on full boost! I don't have numbers yet, but working on renting a dyno to some better logs.
Only issue i'm having is that the banjo bolt/banjo fitting is leaking on the top of the reservoir very very very slowly. and i know for a fact it's not the vented cap that oil is coming out of.
pgranberg11 is offline   Reply With Quote
Old 04-02-2015, 07:02 AM   #3172
Triumphrider
I'll post a pic shortly, mine day doing that too. You need to rotate the banjo bolt and fitting to the side other wise you cannot the bolt properly as the rubber line keeps the fitting from making a good seal
Old 04-02-2015, 11:43 AM   #3173
DAN_BRZ
DAN_BRZ's Avatar
Drives: 2013 WRB BRZ Sport Tech
Have you taken her for a spin yet?
DAN_BRZ is offline   Reply With Quote
Old 04-02-2015, 11:45 AM   #3174
Triumphrider
Oh yeah , works fantastic.... Oh if you need a check valve I have 2 extras
Old 04-02-2015, 05:23 PM   #3175
Scracho
Drives: 2018 Subaru BRZ
I should be installing my kit by next weekend
On my fourth 86... and everything in between
Scracho is offline   Reply With Quote
Old 04-02-2015, 05:56 PM   #3176
Triumphrider
Same goes for you @Scracho, if your kit didn't come with a check valve I got one you can have
Old 04-02-2015, 08:35 PM   #3177
Scracho
I should really check to see if I have one
Old 04-02-2015, 08:39 PM   #3178
Triumphrider
Let me know if you need one
Kraftwerks Rotrex Supercharger Discussion nelsmar Forced Induction 697 01-18-2022 12:06 PM
All SUPERCHARGER kits compilation thread subatoy Forced Induction 76 03-10-2016 12:38 PM
Kraftwerks Supercharger?? umpadupa Forced Induction 1 08-05-2013 05:27 PM
