Old 04-01-2015, 03:45 PM   #1
huertash
huertash's Avatar
Drives: KM4SH FRS
1J/2J Wiring Harness with Dual ECU
Well:
After asking some questions to Chasebays thru their page, they replied that Chasebays will no longer be building the Wiring Harness for our platform with the Dual ECU chasis Sub-harness setup to maintain the A/C, Power Steering. and Tach
Does anyone has Information of wiring diagrams, sources or anything that may help in making this wiring?
Thanks
huertash is offline   Reply With Quote
Old 04-01-2015, 04:59 PM   #2
Manji
Toyotas don't have boxers
Manji's Avatar
Drives: GTV86, ISF, TE27
Do it once, do it right. Motec M150.
Manji is offline   Reply With Quote
The Following 3 Users Say Thank You to Manji For This Useful Post:
burdickjp (04-09-2015), mig86 (04-02-2015), Valentino (04-09-2015)
Old 04-01-2015, 08:44 PM   #3
wutsaiu
wutsaiu's Avatar
Drives: 2015 Raven V8
Originally Posted by huertash View Post
Well:
Thanks
You can get power steering and tach working via canbus signals, don't know why you would need fancy wiring harness for that. Not sure about A/C, I personally wouldn't bother using AC in an engine swapped vehicle but it can be done obviously.
wutsaiu is offline   Reply With Quote
Old 04-02-2015, 05:53 PM   #4
huertash
huertash's Avatar
Drives: KM4SH FRS
Well the goal is to maintain as much features of the car as possible. Street Legal. A/C is a comfort i want to keep since where im from temperatures rarely go below 80 dg.
The "fancy" harness should make it easier for the swap. But anyways....
Any help will be apreciated
Old 04-02-2015, 07:13 PM   #5
wutsaiu
wutsaiu's Avatar
http://www.ft86club.com/files/BRZwiringi.pdf
Wiring diagrams are a good start, but a lot of things are controlled by CANBUS.
Personally I'm just focusing on getting the gauge cluster to work properly and have power steering.
Old 04-02-2015, 10:39 PM   #6
huertash
huertash's Avatar
Drives: KM4SH FRS
Thanks!!!
Old 04-08-2015, 07:30 PM   #7
Ross
Drives: 85 corolla gts
From my experience in doing one of these swaps build the harness. Makes life so much easier.
Ross is offline   Reply With Quote
Old 04-08-2015, 08:44 PM   #8
Trefoil
Trefoil's Avatar
Drives: GBS BRZ Harrop SC/PTuning Header
Tweak'd Performance can build you a brand new wiring harness to suit your needs. The MR2 community where I came from rely on them for the Gen4 3S-GTE upgrades as well as other engine swaps.
Link: http://www.tweakdperformance.com/index2.html
Trefoil is offline   Reply With Quote
The Following User Says Thank You to Trefoil For This Useful Post:
huertash (04-15-2015)
Old 04-08-2015, 10:46 PM   #9
inertia
inertia's Avatar
Most people do not have the cash for Motec goodies lol
inertia is offline   Reply With Quote
Old 04-15-2015, 01:31 PM   #10
xxscaxx
Drives: 2013 SWP BRZ
I highly doubt money is a factor for someone dropping in a 1/2J/LS/etc in this car. If it is, they shouldn't be attempting the swap in the first place.
xxscaxx is offline   Reply With Quote
Old 04-15-2015, 02:03 PM   #11
huertash
huertash's Avatar
Drives: KM4SH FRS
Excuse my ignorance, but what would be the advantage of having the Motec instead of an AEM in terms of instalation and keeping the factory features?
I would still need to make the wiring harness right?
Old 04-15-2015, 02:12 PM   #12
xxscaxx
Would love to help but i'm not very familiar with Motec. I'd ask @Manji since he mentioned it, or you could always ask @DeliciousTuning or @Carolina Dyno (just two off the top of my head that I know recommend it).
The Following User Says Thank You to xxscaxx For This Useful Post:
Old 04-15-2015, 02:14 PM   #13
huertash
huertash's Avatar
Drives: KM4SH FRS
Old 04-15-2015, 07:56 PM   #14
Ross
the motec can communicate with the can communication system. There is firmware for it to integrate into the chassis communication system.
LH/RH Bulkhead Wiring Harness C130NAV Want-To-Buy Requests 2 12-01-2014 05:03 PM
wiring harness so26 Electronics | Audio | NAV | Infotainment 5 10-30-2013 03:19 AM
Wiring Harness Question Sigh-on-Rice Electronics | Audio | NAV | Infotainment 0 08-10-2013 10:46 PM
3rd harness wiring? kndonlee Electronics | Audio | NAV | Infotainment 3 07-01-2012 07:49 PM
Wiring harness sastexan Electronics | Audio | NAV | Infotainment 0 06-16-2012 11:41 PM
