Old 03-29-2015, 07:03 PM   #155
Kodename47
Kodename47's Avatar
Drives: UK GT86
Whatever you do don't take the stock O2 sensor output as what's happening, it won't necessarily be accurate.
How are you reading the AFR of the wideband? Custom map result from the ECU in logs or just the visual display in the car? If it's properly setup you could easily rescale the stock sensor to your wideband output, especially if the wideband in a similar position. Or you could not bother and log the wideband output rather than the front O2. So long as the difference is minimal around the CL area, which it should be, then it won't have much of an impact on fueling error.
.: Stealth 86 :.
Kodename 47 DJ:
Old 03-29-2015, 07:55 PM   #156
Skorov
Skorov's Avatar
Drives: 86 GTS White
Thanks! So you're suggesting I use the wideband as the point of truth.
I'm looking at the visual display and the custom map result from ECU logs.
Just to confirm, I should do this:
1. Scale the custom map output to match the visual display.
2. (Optional) Rescale stock O2 sensor based in wideband data.
Do I have this right?
Skorov is offline   Reply With Quote
Old 03-30-2015, 02:20 AM   #157
Kodename47
Kodename47's Avatar
Drives: UK GT86
Are the wideband readings different? There should be information/specs about what voltage your sensor/controller outputs so creating the table should be easy, unless it's programmable output. What sensor setup do you have?
.: Stealth 86 :.
Kodename 47 DJ:
Old 03-30-2015, 06:03 PM   #158
Skorov
Skorov's Avatar
After seeing a rather silly mistake in my aftermarket O2 scaling, I have corrected and now the stock and aftermarket O2 read almost the same.
However, the reading from the ECU is a constant ~0.25 less than the reading on the display. It's an AEM Failsafe gauge.
I might have to just live with it.
Old 03-31-2015, 03:59 AM   #159
Kodename47
Kodename47's Avatar
Drives: UK GT86
Even at lambda 1? Sounds like the output has a voltage offset or there's something causing interference. If it's always 0.25 AFR different, just change the map by that amount if you're certain.
.: Stealth 86 :.
Kodename 47 DJ:
Old 04-07-2015, 04:25 AM   #160
Skorov
Skorov's Avatar
I've scaled the reading to match the gauge display as much as possible. As you can see from the log below, the readings are a bit off when compared to the stock O2 sensor.
http://www.datazap.me/u/skorov/aem-f...log=0&data=3-6
Do you think this is an acceptable error?
Thanks!
Old 04-07-2015, 05:18 AM   #161
Kodename47
Kodename47's Avatar
Drives: UK GT86
Thanks!
From that log you can easily see the delay caused by the difference in position. Now you can log the wideband I personally wouldn't worry about the stock one. There will always be a variance between different sensors, and honestly there may be times when the stock one's more accurate.
So long as your closed loop operation is scaled using the OEM sensor to reduce trims, use the wideband just to keep an eye the sensor isn't failing over time.
Remember to try and calibrate the wideband every once in a while. Most recommend annually.
.: Stealth 86 :.
Kodename 47 DJ:
Skorov (04-07-2015)
Old 04-07-2015, 07:31 PM   #162
Skorov
Skorov's Avatar
Awesome! Good to have this finally finished.
I want to use the rear O2 to rescale the open loop portion of the MAF sensor. Any reason why that's a bad idea?
Old 04-08-2015, 02:24 AM   #163
Kodename47
Kodename47's Avatar
Drives: UK GT86
Nope, that's what you should do. To make it more accurate you could set a flat AFR in the fuel table, and if you're using vgi's tool remember to increase the row offset by 1 or 2.
.: Stealth 86 :.
Kodename 47 DJ:
Skorov (04-08-2015)
Old 04-22-2015, 10:05 PM   #164
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
Just about to order a UEGO wideband myself.....will contact you soon to get your help in rescaling etc
Fizz is offline   Reply With Quote
Old 04-23-2015, 02:19 AM   #165
Kodename47
Kodename47's Avatar
Drives: UK GT86
Could I recommend the NGK AFX, or it's replacement as it's now discontinued. Better sensors which are likely to last longer and be more accurate.
.: Stealth 86 :.
Kodename 47 DJ:
Fizz (04-23-2015)
Old 04-23-2015, 03:18 AM   #166
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
Will check them out....
Old 04-23-2015, 03:55 AM   #167
Kodename47
Kodename47's Avatar
Drives: UK GT86
This is basically a replica of the NTK AFX - Make sure you go for the NGK sensor, that is what I was told.
AFR500
Or NTK's replacement for the AFX:
NTK AFRM
.: Stealth 86 :.
Kodename 47 DJ:
Old 04-23-2015, 04:01 AM   #168
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
AFR500
NTK AFRM
Thanks, but lol at the backorder till June 2015. Anyways I found a very good deal on the AEM UEGO so might jump on that instead...
BRZ Front and Rear LED Turn Signal Bulbs convoy Cosmetic Modification (Interior/Exterior/Lighting) 23 11-25-2013 07:51 AM
Aftermarket Rear Diffuser Realm Cosmetic Modification (Interior/Exterior/Lighting) 8 05-08-2013 11:23 PM
FS: BNIB Concept Three LED Amber/White signal bulbs Front and Rear with Relay xxscaxx Exterior Parts (Aero, Lighting, Etc.) 10 03-27-2013 10:17 AM
DIY: front and rear LED turn signal bulbs jjdrivesajazz DIY (Do-It-Yourself) Guides 6 10-15-2012 09:53 PM
Innovate Wideband Air/Fuel Ratio LC-1 Wideband Kit **Special Price** Titanmotorsports Audio/Visual, Electronics, Infotainment, NAV 2 09-14-2012 12:42 PM
