Old 03-29-2015, 07:41 PM   #1
aghuman
aghuman's Avatar
Drives: 2013 Asphalt FR-S
Corrosion Warranty Claim
I'm curious to see if anyone has ever made a successful claim for corrosion? Today I noticed a spot about 2cmx6cm on the leading edge of my roof. I'll post a picture when I can but any thoughts as to whether or not Toyota will accept this as warranty or just say it's wear and tear? It's a a tougher spot to hit directly with a rock or something that could have chipped the paint but anything is possible. Any thoughts/opinions are appreciated.
Thanks
aghuman is offline   Reply With Quote
Old 03-29-2015, 09:33 PM   #2
swarb
rust is corrosion. paint/clearcoat damage/wear is not. you pretty much need rust or see bare metal with rust on it to make a claim.
Old 03-29-2015, 09:35 PM   #3
BRZnut
Drives: BRZ DGM Limited
I have seen others post that surface corrosion was corrected by the dealer, but I think officially the corrosion warrantee is when the rust goes through a panel.
Post some pics of what you are seeing.
Old 03-30-2015, 06:30 AM   #4
Will reserve comment until there is something to see.
Old 03-30-2015, 11:37 AM   #5
aghuman
aghuman's Avatar
See the attached photo, this is at the top tight corner of the roof of you were to be looking down onto it facing forward.
Old 03-30-2015, 11:39 AM   #6
Yep! That should be covered for sure. No way that can be blamed on damage that I can see.
Old 03-30-2015, 11:48 AM   #7
Jesse36m3
Jesse36m3's Avatar
Drives: JDL Turbo BRZ
Have you had any previous body work done or is that straight from the factory?
Jesse36m3 is offline   Reply With Quote
Old 03-30-2015, 12:07 PM   #8
aghuman
aghuman's Avatar
Those are all original body panels, I haven't had any body work done
Old 03-30-2015, 12:10 PM   #9
aghuman
aghuman's Avatar
Thanks, I'm hoping they are able to cover it and don't give me some bs excuse. It was my first thought as well that it would be too hard to actually get a stone chip there. I understand regular stone chips on the hood wouldn't be covered due to wear and tear but this one seemed odd to me. Ill bring it up to a dealer and see what they say.
Old 03-30-2015, 12:12 PM   #10
My guesses:
Improper trim install and it nicked or rubbed.
Paint prep faulty or piece of debris.
Something caught in trim or gasket rubbed and broke paint.
Old 03-30-2015, 12:48 PM   #11
fasteddy
Is that by your windshield or back glass? Have you had your windshield replaced?
Pat
fasteddy is offline   Reply With Quote
Old 03-30-2015, 12:59 PM   #12
swarb
Ya, you should be covered. Also check the seal by the doors where the triangle glass meets the moving glass, under the trim there, there has been tiny rust spots to show up. And pop the hood near the fender well area there is a rubber trim/cover area where leaves can accumulate inside the fender and hold moisture.
Old 03-30-2015, 01:14 PM   #13
aghuman
aghuman's Avatar
Pat
Its my windshield, and yea I did have it replaced. I'm hoping that doesn't cause an issue with the claim but who knows.
Old 03-30-2015, 02:54 PM   #14
AznBRZer
Drives: 16 CBS WRX Limited
Uh oh. Looks like whoever did the job fucked it up.
AznBRZer is offline   Reply With Quote
Has anyone had a warranty claim denied? Seized engine! Pics of teardown added 6/5 CSG Mike Issues | Warranty | Recalls / TSB 909 09-15-2016 10:31 AM
Normal amount of corrosion on brake calipers? Annahra Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 08-05-2014 03:19 PM
Corrosion on sway bar mounts SubiePig Issues | Warranty | Recalls / TSB 5 10-29-2013 05:01 PM
HELP with diminished value claim! zohare Scion FR-S / Toyota 86 GT86 General Forum 41 04-03-2013 11:17 AM
Corrosion Free installer in GTA who do you recommend? chenshuo CANADA 4 02-19-2013 02:26 PM
