Old 03-29-2015, 03:49 PM   #29
kounkun
kounkun's Avatar
Drives: 2015 CWP BRZ Limited
Helium filled tires.
kounkun is offline   Reply With Quote
The Following User Says Thank You to kounkun For This Useful Post:
DoomsdayJesus (03-29-2015)
Old 03-29-2015, 03:52 PM   #30
Originally Posted by jetsevo4 View Post
A single exit exhaust would've saved a few pounds I feel
marketing
Old 03-29-2015, 03:53 PM   #31
ChrisSC300
Drives: 2014 SWP BRZ
Take a large dump before u drive. Better than deleting modern amenities.
ChrisSC300 is offline   Reply With Quote
The Following 3 Users Say Thank You to ChrisSC300 For This Useful Post:
Captain Snooze (03-29-2015), DoomsdayJesus (03-29-2015), GotBRZ1691 (03-30-2015)
Old 03-29-2015, 03:54 PM   #32
4 lug wheels
All the noticeable from the outside things have already been mentioned, the only truly inventive ideas can only come from people who know every inch of this car, stuff like sharing mounting points for hardware, creating shorter harness pathways, and the stuff that would add to the cheapness, thinner plastics, carpet removal, no little rear window etc.
Clever integration for the win.
strat61caster (03-29-2015)
Old 03-29-2015, 03:56 PM   #33
Plastic 5 gallon fuel tank.
Choco (03-29-2015), Koa (03-29-2015), strat61caster (03-29-2015)
Old 03-29-2015, 04:36 PM   #34
Sometimes the choices made can be difficult to quantify.
Maybe target inertial properties of the car influenced muffler specs.
Old 03-29-2015, 06:35 PM   #35
Bristecom
Bristecom's Avatar
Drives: 2017 Subaru BRZ PP
Without removing functionality or increasing cost much, they could have made the front fenders and roof out of a modern plastic. These are supposedly now strong and durable enough to be used. Also, make the trunk out of aluminum instead of steel. I'm not sure if the bumper beams are already aluminum or not (does anyone know?) but if they aren't then that would be a big one.
The wheels could definitely be lighter. They should use Enkei, OZ, or BBS's flow-forming cast techniques to make them lighter and stronger with minimal increase in cost.
Also using OEM-grade Brembo calipers would be a little lighter and higher performance with a small cost increase and perhaps switch to a dedicated e-brake so that we can upgrade to two piece rotors front and rear or use co-cast/dual cast type discs.
Other than that, maybe include a stock AGM type battery which is typically a little bit lighter and leak-free. And I think since the release of the FR-S, Denso has come up with a lighter AC system so that might save a bit.
I would like forged aluminum suspension arms/links/knuckles but that might raise the cost a bit too much.
But yeah, these things would lower center of gravity, improve weight distribution, and enhance performance with little to no increase in price.
Toyota + Subaru =
Bristecom is offline   Reply With Quote
Old 03-29-2015, 06:43 PM   #36
Factory could set me up with a gym membership.
gramicci101 (03-29-2015), Koa (03-29-2015), srizzors25 (03-30-2015)
Old 03-29-2015, 06:49 PM   #37
Bristecom
Bristecom's Avatar
Muscle weighs more than fat. But losing weight yourself doesn't do much to the performance of the car. You are generally centrally located in the vehicle and not a part of the unsprung weight or rotational mass. The target areas for weight would be up high, in front of the front wheels, behind the rear wheels, and everything that is part of unsprung weight and rotational mass. Also, I would prioritize things that would positively effect f/r weight distribution - so on this car, I wouldn't focus too much on things that are lower down towards the rear (like spare tire or fuel).
Toyota + Subaru =
Old 03-29-2015, 07:19 PM   #38
Bullshit. Strap 70 pounds of lard in the passenger seat and get back to me on that.
Captain Snooze (03-29-2015), Koa (03-29-2015)
Old 03-29-2015, 07:29 PM   #39
Koa
does briste even own a 86 or is he one of those weird lurkers
Old 03-29-2015, 08:05 PM   #40
Haha... dunno but I wonder if there's a per-thread quota on saying "bullshit" legitimately, or otherwise.
Anthony (04-02-2015), Koa (03-29-2015)
Old 03-29-2015, 08:14 PM   #41
navanodd
Drives: 2013 BRZ Sport-tech WRB
Even thinner paint?
navanodd is offline   Reply With Quote
The Following 3 Users Say Thank You to navanodd For This Useful Post:
Anthony (04-02-2015), Ganthrithor (03-30-2015), srizzors25 (03-30-2015)
Old 03-29-2015, 08:21 PM   #42
Bristecom
Bristecom's Avatar
Within reason... I was responding to those who were saying that they can go much faster by taking a crap or working out a bit. Of course a whole nother body's worth of weight will make a difference.
Toyota + Subaru =
I thought this car came with an LSD? AZOOZ_95 Scion FR-S / Toyota 86 GT86 General Forum 74 08-26-2017 04:04 AM
Anybody thought about these? Memphis Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 18 08-13-2012 04:01 PM
Swap: factory 16s for factory 17s Sydney MZ21 Australia Classifieds 10 07-29-2012 11:46 PM
BRZ Feather weight, What mods are you planning on doing to lighten up your BRZ? yeabude BRZ First-Gen (2012+) — General Topics 53 04-04-2012 02:31 PM
