#15 |
A Demon
Drives: Raven GT86
#16 |
Drives: brz
#17 |
Member of the year - 2016
Drives: Scion FRS
| The Following 4 Users Say Thank You to dem00n For This Useful Post: |
#18 |
Drives: FRS
#19 |
Drives: 2014 Whiteout FRS
Thanks everyone for the ideas and feedback.
I am a bit lost when it comes to "crash bolts" "camber plates" and "adjustable control arms". They ALL seem to adjust camber but are all widely different and I dont see why you would pick one over the other. It just seems the bolts are the cheapest but cost the most to install. Are these camber adjustment options something that could be added after the fact? Like would I be fine with just the coilovers, see how they feel, decided what I want to go with next, be it camber plates or control arms? Or is it that without one of these, having the coilovers would be almost a waste? I am a fan of the upgrade 1 part at a time method. Really lets you understand what each part is doing and how it effects the car more so than buying everything at once. I dont plan to go lower than 1 inch if that makes any difference. As for why coils over springs, I want the adjustablity and ease that coils offer. |
#20 |
Drives: 2014 FR-S
Crash course:
"Crash bolts" and camber plates both adjust front camber. Camber plates do it from the top of the strut, camber bolts adjust it from the knuckle connecting to the strut housing. Why do you need both? Usually you don't. Some coilovers don't come with camber plates, so people run bolts. Some people run both if they need more negative camber than one application alone can provide. Adjustable lower control arms (LCAs) adjust camber in the rear. The stock arm is not adjustable. When you lower your car, you will naturally get some negative camber. When you increase the drop, you increase camber. That's why you would get LCAs: to dial back and fine tune the camber in the rear. Most people end up with ~ -1.8-2.0 rear camber with a 1 inch drop, that's usually ok to run without LCAs. I believe the RSR sport-i are unique in that they do not have fine adjustment on the camber plate, it is basically two settings: 0 and -1.5 degrees. I remember Moto-P mentioning it somewhere. Therefore you will need camber bolts for fine tuning. I think you will be fine without LCAs until you start hitting the track. Toe is adjustable from the factory. Keep in mind that it's always recommended to do an alignment after your suspension is modified, to keep your camber and toe in check. This affects your handling and more importantly (imo), tire wear. Don't neglect camber and toe, it goes hand-in-hand with lowering your car. And as always, remember to search! |
| The Following 4 Users Say Thank You to kbye For This Useful Post: |
#21 |
Drives: 86
I would recommend getting what I mentioned, I like to get the minimum requirements to ensure that I can get the car back to factory spec without spending alot of income. Everything I mentioned will help when you decide to change tire setups, go lower, or adjust for your track events.
| The Following User Says Thank You to HATED1 For This Useful Post: | Autocon (03-30-2015) |
#22 | |
#23 | |
Unless you're actually going to adjust ride height and have the car corner balanced, having adjustable spring perches is a waste of money. Unless you're going to learn how to properly adjust the shocks (and have people to help you learn), having that adjustability can actually make it handle much worse. A better use of money is to get good shocks that aren't adjustable, and good springs (like a Bilstein/RCE tarmac, or swift spec R combo), and just enjoy the car. As for buying one part at a time... if you get coilovers (or springs), you'll need an alignment since you're pulling the suspension apart. If you get the camber adjustment parts, you'll need another alignment. There's nothing to gain by waiting (unless you need time to save the $$$) to do the camber adjustment later.
| The Following User Says Thank You to wparsons For This Useful Post: | Dimman (04-02-2015) |
#24 | |
Springs while cheaper make you locked into that setting. My buddy has coils on his Miata and when taking it to the track it was very noticeably different when he adjusted from softer to more firm. And that is something I would want and coils seem to be the only way to get that. Also the ability to drop it an inch lower and get it corner balanced and aligned with my weight in the driver seat is what I hope to accomplish as well. Your points about not getting things part by part as it will all require a new alignment each time makes a lot of sense. Something I didn't realize and I don't see any reason to not just get it all in one go if I am going to rip up the suspension. So I appreciate the info! ![]() Now time to research front camber plates and control arms :O |
#25 |
You can get adjustable shocks without going to coilovers, probably better quality shocks than most cheaper coilovers too. You also need to know what you're doing when adjusting shocks. Just because it's firmer doesn't mean more grip, and you can make a real mess of the handling balance if you're adjusting it wrong.
For what you're after, you're probably not going to get any noticeable benefit from corner balancing. Is it a good thing to do, sure, but until you're much more experienced or trying to get every last tenth out of it, it's probably not worth it. You'll also want to look at different tire sizes if you're trying to squeeze more grip out of it. 225's are better on an 8" wheel, 245's will be a better fit on a 9" wheel next time you need tires.
| The Following User Says Thank You to wparsons For This Useful Post: | Autocon (04-06-2015) |
#26 | |
Did a lot more reading up over the weekend on shocks and springs and boy was I way off base on all of this :X Super appreciate you taking the time out as it gave me a lot more insight into all of this and kept me from making a purchase so quickly as it seems springs/shocks indeed might be a much better solution for what I want. As for the tires, yeah I was suppose to get 245's but my buddy hooked me up with his friend who gave me 40% off a new set of tires. Only problem was I didn't check the actual tires sizes they put on till I got home. A really stupid mistake :/ But I will burn them at the track quickly enough ha |
| Coilovers Coilovers, Coilovers: Tein, KW, BC, D2, Cusco, Eibach + more FREE SHIPPING! | No Limit Motorsport | Brakes, Suspension, Chassis | 204 | 05-26-2017 01:09 PM |
| Car Shopping - What am I missing | Timmy_Jones | Other Vehicles & General Automotive Discussions | 49 | 04-27-2014 11:54 PM |
| So... am I missing something? | BirdTRD | Issues | Warranty | Recalls / TSB | 10 | 11-04-2013 05:52 PM |
| missing my FRS :( | 20valvewynn83 | Southern California | 36 | 08-29-2012 04:12 AM |
| Here's what our forum is missing: | OldSkoolToys | Other Vehicles & General Automotive Discussions | 9 | 11-24-2009 06:57 PM |
