Drives: 2014 Whiteout FRS
About to get first coilovers, anything I'm missing?
Looking to purchase my first ever suspension upgrade and get a set of the RS*S Sports-i coilovers and wanted to check if I might be missing something before I pull the trigger. I am still new to car moding and all the internals of the car but trying to do as much research as I can as I go along.
About my car.. Its mainly my DD, but I go to the track around 3 times a year and hit up the mountains once a month. I am not looking to race at the track competitively ever, I just go for the fun of racing my car, pushing it as much as I can in a safe environment and get some better handling from it. Wheels - Enkei Kojin 17x9 +45 with 225/40 tires all around. I want to drop the car 1 inch overall. All other performance parts on car are stock. The RS*R Sports-i seem to be the best of what I want in a good price range. I just want to check if I am missing something before I commit to buying them. Thanks!
#3 | |
A Demon
Drives: Raven GT86
This would be funnier if the link worked. Sent from my iPhone using Tapatalk |
worked for me
#6 | |
From a lot of the threads I have seen people talk about also buying camber plates or bushing things, or in threads with springs they mention swaybars. But it seems I wouldn't need those, but I honestly just wanted to make sure because its all new to me. I really just wanted to see that if I buy these coilovers and install them am I basically good to go with the car I have? Or is there some part of the processes I might be missing? |
Drives: FRS
which tire model you're choosing also has major impact on the performance too, not just the size of it.
Drives: Whiteout
Consider getting the camber adjustment kits for front and rear, although a mild drop won't throw the setting off too much. Also, prevailing advice is to max out the front negative camber bolt and then dial in your actual desired setting at the top hat.
Junior
Drives: a car
how to click on a link
To do this, follow these steps: 1. On the Tools menu, click Options. 2. On the Edit tab, click to clear the Use CTRL + Click to follow hyperlink check box. 3. Click OK to close the Options dialog box.
#10 |
Drives: FRS
I have the RSR's and like them. I think you should consider Subaru crash bolts for the front and an adjustable control arm from the rear. These parts will allow,you to get a solid alignment after install.
#11 |
Drives: 86
On my previous cars/setups I have always purchased coilovers with front camber plates, rear/front dampening and rear lower control arms at the least for maximum adjustments for all types of setups/track.
#12 |
One & Done (AOZORA)
Drives: '15 Series.Blue BRZ (WRB)
If he's staying stock and using his car mainly for DD, I think all he would really need are coils and the tools necessary. I could be wrong and i'm sorry if I am!
"I have the need....the need for speed! - Maverick (Top Gun)
#13 |
Drives: 2013 Subaru BRZ
Why not just springs? Plenty get a 1" drop and improved handling, save money for other bits.
Build Thread:
http://www.ft86club.com/forums/showthread.php?t=43355 |
#14 |
Drives: '15 Halo FR-S
| Coilovers Coilovers, Coilovers: Tein, KW, BC, D2, Cusco, Eibach + more FREE SHIPPING! | No Limit Motorsport | Brakes, Suspension, Chassis | 204 | 05-26-2017 12:09 PM |
| Car Shopping - What am I missing | Timmy_Jones | Other Vehicles & General Automotive Discussions | 49 | 04-27-2014 10:54 PM |
| So... am I missing something? | BirdTRD | Issues | Warranty | Recalls / TSB | 10 | 11-04-2013 04:52 PM |
| missing my FRS :( | 20valvewynn83 | Southern California | 36 | 08-29-2012 03:12 AM |
| Here's what our forum is missing: | OldSkoolToys | Other Vehicles & General Automotive Discussions | 9 | 11-24-2009 05:57 PM |
