Old 03-27-2015, 11:37 PM   #3151
John92
Drives: White scion frs
Originally Posted by post_break View Post
What is your afr doing? I had that when running crazy lean. Tuner fixed it and the car stopped pulling massive timing.
I can't do any logs as I found out this morning that I only brought along my dongle and not the cable. The cable is with all my stuff in route to Florida. I guess I will just have to try to stay out of boost as much as possible and no :burn rubber: for me.
John92 is offline   Reply With Quote
Old 03-28-2015, 08:52 PM   #3152
post_break
Professional Smartass
post_break's Avatar
Drives: White Out FRS
Originally Posted by Triumphrider View Post
@post_break how did the moto East tune work for you?
Works great. Flex fuel works and I can definitely feel the difference. Car is daily driven and no real quirks.
post_break is offline   Reply With Quote
The Following User Says Thank You to post_break For This Useful Post:
Triumphrider (03-28-2015)
Old 03-30-2015, 05:49 PM   #3153
Triumphrider
Triumphrider's Avatar
Drives: 2013 Scion FRS in white out
Crank pulley is on, and hoses are all clamped, check valves are in..... Tomorrow morning starts the c38 install! So pumped I probably won't sleep tonite!
2013 Scion Frs AT in Whiteout, Borla UEL header, Greddy SP Elite AxleBack. Kraftwerks C38 Supercharger tuned by Moto East and 2 kid seats in the back.
Triumphrider is offline   Reply With Quote
The Following 2 Users Say Thank You to Triumphrider For This Useful Post:
DAN_BRZ (03-30-2015), Rulin (03-31-2015)
Old 03-30-2015, 06:11 PM   #3154
DAN_BRZ
DAN_BRZ's Avatar
Drives: 2013 WRB BRZ Sport Tech
Come pick me up!!! Hahah man I'm so jealous! How long did the install take u?
DAN_BRZ is offline   Reply With Quote
Old 03-30-2015, 06:17 PM   #3155
Triumphrider
That actual install starts tomorrow, just wanted to get the tedious bits done today
Old 03-30-2015, 06:36 PM   #3156
Triumphrider
Let me say though getting the lines under the intake manifold clamped are a big pia!
The Following 3 Users Say Thank You to Triumphrider For This Useful Post:
Andreas83 (03-31-2015), Freeman (03-31-2015), Rulin (03-31-2015)
Old 03-31-2015, 12:53 PM   #3157
Freeman
Freeman's Avatar
Drives: 2013 Ultramarine FR-S
Open to ideas on this, CSG if you're lurking feel free to chime in.
The other day I romped on it and the car felt sluggish. I looked over at my failsafe gauge and the PSI (which is normally ~11psi) was at ~8psi. I figured that since my perrin motor mounts had shaken my oil cooler fittings and bolts loose that they had struck again. I took the bumper off and tightened up all the clamps on the piping and which got the PSI up to ~9. The car feels closer to normal, but still a bit slower than it was.
Any other ideas out there? Hoping the blower isn't shot, but it has gotten louder.
Freeman is offline   Reply With Quote
Old 03-31-2015, 08:52 PM   #3158
zERoTu
Drives: 1st RBv2 10 Series FRS
quick question. i just installed the updated pulleys, and my new belt. anyone know if im suppose to set the tensioner space to the regular 21mm from the plate to the bolt for tension??? because at 20mm its pretty damn loose!.
waiting for your replies
-edward
zERoTu is offline   Reply With Quote
Old 03-31-2015, 08:54 PM   #3159
Triumphrider
So tomorrow I prime the oil system, obviously you can't let the reservoir run dry... How the heck do you know, you can't see in it?
Old 04-01-2015, 05:53 PM   #3160
zERoTu
ok, ive been using the gates carbon drive app on the iphone and android, I keep getting 43hz.
I got 43, 60, 59, 43, 43,43,43 that was me sequence. and im at 17mm from the plate and the bolt. don't know if I wanna go tighter or not
Old 04-01-2015, 06:12 PM   #3161
Triumphrider
I used the gates app, got 61hz like 5 times in a row, good enough for me
Old 04-01-2015, 06:14 PM   #3162
zERoTu
Are u using the 95mm sc and 125? Crank pulley? And how much space did u end up with?
Old 04-01-2015, 06:16 PM   #3163
Triumphrider
I'm using what ever comes stock with the c38 kit. I'll check when I get home
Old 04-01-2015, 06:17 PM   #3164
zERoTu
Oh. Hmm I have the c30.
Kraftwerks Rotrex Supercharger Discussion nelsmar Forced Induction 697 01-18-2022 12:06 PM
All SUPERCHARGER kits compilation thread subatoy Forced Induction 76 03-10-2016 12:38 PM
Kraftwerks Supercharger?? umpadupa Forced Induction 1 08-05-2013 05:27 PM
