Old 03-24-2015, 02:41 PM   #351
steve99
Drives: FT86
Originally Posted by Danklvr View Post
normally i get a good log - normal cruise driving, then manually filter out my data from the log. once i have my filtered closed loop data, i fill "injection mode" collumn with "2".
I'll switch my paramater to include "fuel system status", and remove "injection mode", and report back with a better log based on the feedback you gave
once nailed down CL, I'll start on OL, then move on to timing...
Again, thanks Steve99, and KOA!
for maf scaling you must use Fuel system status else the utility will produce rubbish results.
Old 03-27-2015, 10:59 AM   #352
sstfnv
sstfnv's Avatar
Did some logging with OFT yesterday. The map is OTS Stage1 93oct. Does the AFR look normal? It appears to me that it is running a little rich.
Here is the log: http://www.datazap.me/u/sstfnv/fr-s-...1587&mark=1911
sstfnv is offline   Reply With Quote
Old 03-27-2015, 11:18 AM   #353
Kodename47
Kodename47's Avatar
Drives: UK GT86
It doesn't look like it's knocking on WOT, although you're logging the wrong parameters for FLKC. I've not seen the O2 sensor scaling so don't know if it's "accurate" anyway, it doesn't look like it's going too rich however.
.: Stealth 86 :.
Kodename 47 DJ:
sstfnv (03-27-2015)
Old 03-27-2015, 11:42 AM   #354
sstfnv
sstfnv's Avatar
Thank you. I will log the O2 sensor scaling and FLKC next time.
Old 03-27-2015, 06:58 PM   #355
BRZoomTX
BRZoomTX's Avatar
Drives: '13 BRZ
First real log of the stage 1 OFT 93 octane tune. Would appreciate if someone could take a look for me.
2nd to 3rd gear pull.
http://datazap.me/u/slowbaru/2nd-gea...13-14-15-18-19
BRZoomTX is offline   Reply With Quote
Old 03-27-2015, 07:13 PM   #356
Koa
is that something other than OFT used to log?
Old 03-27-2015, 07:24 PM   #357
BRZoomTX
BRZoomTX's Avatar
Drives: '13 BRZ
Yes. I am using a tactrix cable with the built-in logger. The parameter names are named after the actual memory addresses so it may be slightly different from what OFT names them as.
Old 03-29-2015, 08:09 PM   #358
wooly35
Drives: 2014 Scion FR-S LS3
Did a third gear pull with the new turbo set up and OFT tune. I thought the Air fuel might be a little rich, but would like some others opinions.
http://www.datazap.me/u/wooly35/sbd-...-6-7-8-9-10-11
wooly35 is offline   Reply With Quote
Old 03-30-2015, 03:26 AM   #359
Kodename47
Kodename47's Avatar
Drives: UK GT86
If it's off of the stock sensor then I'd say it looks about right.
.: Stealth 86 :.
Kodename 47 DJ:
Old 03-30-2015, 07:23 AM   #360
wooly35
sry, using the 3 bar map and tune.
Old 04-01-2015, 02:48 AM   #361
JB86'd
JB86'd's Avatar
Drives: JAWS
Stage 2 OFH 91 octane...Just took another log now that I've given the ECU about 250 miles to learn. Still running rich (according to the 02 sensor). Is installing a wideband the only way to find out for sure if I'm running too rich?
I'm right on the threshold of having knock at least timing-wise..so going leaner will probably create knock afaik.
Car feels great and I'd rather be on the safe side than ragged edge for hot days/autox days, but don't want to be so rich it causes other issues.
http://datazap.me/u/joshbustos86/206...-8-9-12&solo=9
JB86'd is offline   Reply With Quote
Old 04-01-2015, 03:12 AM   #362
Wayno
Wayno's Avatar
Drives: Toyota 86 GTS
http://www.ft86club.com/forums/showthread.php?t=82875
Old 04-05-2015, 09:27 PM   #363
Captn_Jack
Drives: Firestorm FR-S
Hey guys,
I'm usually just a lurker but was hoping somebody could take a look at my logs. I think things look ok but not great, however I'm a complete noob when it comes to tuning and data logging. I'm running the OFT E85 stage 2 EL on a stock car. Currently about 175 miles on the tune. Below are 3 pulls through second and into third.
I'm concerned with how low my LTFT is and it appears I'm getting a slight knock between 5600-6600 rpm correct?
http://datazap.me/u/captnjack/log-14...=1-5-7-8-13-14
Captn_Jack is offline   Reply With Quote
Old 04-05-2015, 10:50 PM   #364
Wayno
Wayno's Avatar
Originally Posted by Captn_Jack View Post
Hey guys,
I can only dream of having AFR curves like yours. I wouldn't worry too much about the knock.
RGM Supercharged 86 performance data TheGooseman AFRICA 14 12-13-2014 02:15 AM
Interpreting Ecutek Data Logs? cuddefred Software Tuning 3 09-02-2013 01:55 PM
VIR - Impressions/Pics/Logs/Video (Track Daze) swift996 Tracking / Autocross / HPDE / Drifting 39 08-30-2013 10:21 AM
Noise tube delete air/fuel logs? jm1681 Engine, Exhaust, Transmission 13 10-17-2012 05:57 PM
ECU Data Logger Motordyne Engine, Exhaust, Transmission 5 07-18-2012 10:27 AM
