Old 03-26-2015, 06:50 PM   #1
redlined600
redlined600's Avatar
Drives: Fr-s
Help with Ecutek install
I'm trying to install the ecutek software on a Win8.1 laptop (maybe my problem?)
Install starts fine but when I'm prompted to plug the cable into the computer nothing happens, nothing.
Is the light on the cable supposed to light up? Is the cable supposed to be plugged into the car as well? Is my cable fried?
I looked up some tutorials to delete the driver and start over but it doesn't look like the cable is even showing up in the device manager.
Any thoughts?
ps. I don't have the license or tune yet as I wanted to get all set before purchase for this exact reason.
redlined600 is offline   Reply With Quote
Old 03-26-2015, 11:57 PM   #2
BRZtoni
Turbo E85
BRZtoni's Avatar
Drives: 13 wrb brz
your better off waiting for the lincense and tune before you begin..
what i did was checked perrins website because they offer AWESOME DIYS and GUIDES, but since im such a nice guy
here is the link..
http://blog.perrinperformance.com/ho...-your-brzfr-s/
Flex Fuel Turbo BRZ
BRZtoni is offline   Reply With Quote
Old 03-27-2015, 05:01 AM   #3
Kodename47
Kodename47's Avatar
Drives: UK GT86
Any thoughts?
You don't need to be in the car or have the license to install. I have recently "upgraded" to Win8.1 and I had no issues installing on mine.
From scratch (apologies if you already know this), download the ECUtek app downloader from here: http://www.ecutek.com/Support/Downloads
Follow the install procedure, it should install the drivers 1st for the hardware. Then plug in the cable and dongle when requested.
Did you get the audio that you connected a USB device? What type of USB port are you using? I can't remember if the LED came on until the drivers installed. I've used USB 2 and 3, 3 is preferable for flashing speeds.
Might be worth giving the laptop a full reset.
.: Stealth 86 :.
Kodename 47 DJ:
Old 03-27-2015, 11:52 AM   #4
SpeedWi
SpeedWi's Avatar
Drives: 2014 BRZ (SOLD)
I'm running it on Win 8.1 no issues here. Just uninstall the driver/software and try again. Don't plug the cable in until the driver is installed/updated
Supercharged 2014 DGM Limited
SpeedWi is offline   Reply With Quote
Old 03-27-2015, 12:22 PM   #5
redlined600
Drives: Fr-s
I did not plug the cable in until the install as suggested. I also tried to delete the driver but one wasn't present. I suspect it's either a computer problem or my cable it's dead.
I'll start with a reinstall of win 8.1or maybe see if my old laptop will run long enough to try and install it.
Old 04-28-2015, 03:29 PM   #6
TrueLoneReaper
TrueLoneReaper's Avatar
Drives: 2013 Scion FRS
I'm not sure if you're having the same thing happen that I did but while I was trying to install on my laptop it did not seem to be doing anything either. What it ended up being was that I had to wait about 3/4 min. for it to pop anything up, and when it did it popped up another box in the background that I had to mess with. You can try Alt+Tab after a bit to see if there is another window behind the installer.
TrueLoneReaper is offline   Reply With Quote
Old 05-08-2015, 03:55 PM   #7
redlined600
Drives: Fr-s
Sorry I should have followed this up. It was an issue with the laptop. Basically when I tried to install it the usb ports weren't functioning correctly. I've since successfully installed them on another computer.
The Following User Says Thank You to redlined600 For This Useful Post:
CSG Mike (05-08-2015)
DIY: innovate Wideband Install for ecutek logging BadBRZ DIY (Do-It-Yourself) Guides 0 07-18-2014 06:04 PM
ecutek ? mrnibbs Software Tuning 39 01-26-2014 10:40 PM
Ecutek's 86 jpit FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 10 07-12-2013 12:35 PM
Which should I get ecutek stg 1 or stg 2? Frsexxxy Engine, Exhaust, Transmission 5 03-21-2013 01:10 PM
ECUTEK????? 20valvewynn83 Engine, Exhaust, Transmission 4 10-03-2012 09:34 PM
