#253 |
Drives: 2013 Toyota 86 MT
Hi guys
I want to fit some 18*9,5 concave wheels (didnt decide yet, might even go with 18*9 if possible becouse i dont like the poke) and 255/40/18 AD08s at all corners, so i need coilovers. This is my daily car, i will go to track from time to time but just for fun, not going to push the car too much. I feel ride hardness is just fine with stock suspension and with stock 205/55/16 tires, roads here are not so good btw. I am planning to lower the car about 1". I have a limited budget i am not a pro, so which coilover would you recommend for a comfortable ride similar to stock? I have a limited budget can not afford top quality. |
| The Following User Says Thank You to ofuts For This Useful Post: | 10series_frs (03-02-2015) |
#254 |
BTW, can all coilovers adjust camber? Or do i need additional parts for some?
#255 | |
The front will not change. Some coilovers have slotted top holes in the front which allows you to increase the camber. |
| The Following User Says Thank You to jvincent For This Useful Post: | ofuts (10-20-2014) |
#256 | |
If not, will i need other parts to adjust camber (front and rear)? |
#257 |
Better to ask Stance or whoever is selling them.
As far as other parts it depends on how much camber you want. If the front struts are slotted all you probably need are camber bolts. For the rears if you want to adjust them from what the drop gives you, you will need LCAs. |
#258 |
Rear camber can be adjusted with aftermarket control arms. We make some, as well as other companies.
#259 |
Does it drift?
Drives: 2013 Subaru BRZ
No actual answers for my original question. Does anybody know why you would want the front harder than the rear as opposed to the rear being harder as designed by Toyota/Subaru?
#260 | |
Drives: 2017 BRZ
![]() What prompts you to ask? |
#261 | ||
Because compromise ®
Drives: Red Herring
To elaborate on @cjd's post above
OEM Scion FR-S Actual Front Spring Rate 2.3K.... At the wheel 2.1k Actual Rear Spring Rate 3.8K......At the wheel 2.1k OEM Subaru BRZ Actual Front Spring Rate 2.7K..... At the wheel 2.4k Actual Rear Spring Rate 3.5K.......At the wheel 2.0k See this article for info about motion ratio http://www.ft86club.com/forums/showthread.php?t=9936 There is no one "correct" front/rear bias. It depends on the intended use of the vehicle and driver preference. Quote:
#262 | |
Alexandrino_Auto
Drives: series.Blue
Front: 4.4 kg/mm, 245 lb/in drop: -28mm, 1.1 in Rear: 5.3 kg/mm, 296 lb/in drop: -25mm, 1.0 in
The Shadetree Project: I turn wrenches
#263 |
Drives: Scion FR S
guys im planning to buy RSR sports i coilovers.. seems adjustable cambers dont come with it.. can i use the OEM camber or do i need to buy theirs?? thanks..
#264 |
Drives: Scion Frs
Planning on getting the TRD lowering springs, according to OP these have the least amount of drop compared to other aftermarket springs right? I want something that will give my car a little drop and won't affect my daily driving too much. Would TRD be a good choice? Thanks and if anyone is selling them let me know. aha
#265 | |
Drives: Series 10 FRS
#266 |
Drives: Scion FR S
is -3 camber in the rear safe to drive in 70 - 90 mph highways??
| Adjustable shocks+ springs vs Coilovers | CyberFormula | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 44 | 06-08-2013 04:59 PM |
| Canadian FR-S options VS U.S.A's options? | Tino | Scion FR-S / Toyota 86 GT86 General Forum | 15 | 11-06-2012 11:07 PM |
| coilovers or springs? | koyv90 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 45 | 04-01-2012 09:49 PM |
| Gearing Options and Diff options | airboy808 | Engine, Exhaust, Transmission | 26 | 12-25-2011 02:11 PM |
| Subaru BRZ different suspension / springs tuning | ahausheer | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 35 | 12-06-2011 01:52 PM |
