Old 05-19-2012, 09:32 PM   #1
BT OBDII/Android/Torque Confirmed working
I hooked up my BT OBDII connector today and verified it all works with my FR-S (not really sure why it wouldn't but anyways). Details and some screen shots on my Owner's Journal here if you are interested. If you have any questions I can answer post here and I'll give it a shot. I'm not an expert at its use but it is cool to have access to all that data!
The Following 9 Users Say Thank You to Dadhawk For This Useful Post:
BRZranger (10-26-2012), chulooz (05-19-2012), Dimman (05-19-2012), ESBjiujitsu (05-21-2012), ESC POD (10-26-2012), Guff (05-22-2012), RWD_only (05-22-2012), Shagaliscious (10-26-2012), zoomzoomers (10-26-2012)
Old 05-19-2012, 09:36 PM   #2
chulooz
Registered you sir
chulooz's Avatar
Drives: 99 impreza coupe
That info/display is pretty neat! Curious location for that port though.
How do you like it while running, is it something you would only turn on during spirited driving/competing?
chulooz is offline   Reply With Quote
Old 05-19-2012, 09:46 PM   #3
I don't really compete so it wouldn't be on then. I just find it interesting data to look at when diagnosing an issue with a vehicle before getting it serviced, etc.
Also it lets you look at emissions codes and such should a light come on. I'm sure tuners could find way more use out of the information than I do.
Old 05-19-2012, 10:12 PM   #4
neutron256
neutron256's Avatar
Drives: '13 GBS Subaru BRZ
How was the refresh rate? I have the PLX Kiwi WiFi and I've notice the data refreshes at a different rate on different cars. My 2001 Impreza was pretty quick, my Current Honda Fit, and CR-Z have quite the lag.
Old 05-19-2012, 10:28 PM   #5
It was pretty quick, very little lag although there is always some. About the same as the Mustang, Accord and Astro (other cars I've played around with).
Old 05-20-2012, 03:19 PM   #6
arghx7
Drives: car
The refresh rate could depend on the load on the communication bus for the vehicle.
Old 05-22-2012, 12:51 AM   #7
Jordo!
Enjoy it, destroy it.
Jordo!'s Avatar
Drives: Datsun Racing Hen
Sweet.
Is the O2 signal narrow (0-1.0v) or wideband (0-5.0v)?
Jordo! is offline   Reply With Quote
Old 05-22-2012, 09:18 AM   #8
Future
Future's Avatar
Drives: BRZ!
Originally Posted by Jordo! View Post
Sweet.
Can't remember where, but I did read that it is narrow.
Many will likely say the FR-S/BRZ needs more power and while more wouldn’t hurt, those folks (the same ones who have probably never driven on a track) are missing the point.
Future is offline   Reply With Quote
The Following User Says Thank You to Future For This Useful Post:
Dadhawk (05-22-2012)
Old 05-22-2012, 09:40 AM   #9
arghx7
Drives: car
We know it's a 4-wire sensor, and it's highly likely that it's Denso limiting-current type wideband. This is, generally speaking, not quite as accurate as the latest Bosch sensors, but not a traditional "narrowband" with a 0-1v output.
People assume that 4-wire = narrowband, 5 wire = wideband. That's half true. Modern heated oxygen sensors (narrowband rear o2 you would find after the cat) are, generally speaking, 4 wire sensors. Old narrowbands might have three wires or one wire if they are unheated.
Pump-cell type widebands made by Bosch and NTK use 5 wires.
Limiting-current type widebands made by Denso use 4 wires.
The Following User Says Thank You to arghx7 For This Useful Post:
Old 05-22-2012, 03:28 PM   #10
vividracing
vividracing's Avatar
Some cars use a 4 wire narrow as well. 4 wire doesn't mean its a wideband o2 sensor.
As for the Torque program. You can adjust under adapter status PID read speed and a few other setting to help speed up data rates.
I have been using this for two years and works almost as good as my AIM dash. Just requires a cell phone holder and you have to remember to calibrate the phone to the angle its resting at.
I have not tried it yet on the FR-S, I will next time it is running.
vividracing is offline   Reply With Quote
Old 10-25-2012, 09:32 PM   #11
soros151
SorosMotorsports
soros151's Avatar
Drives: Whiteout Pearl
Just got my adapter... Seems to one of the faulty ones. Great.
soros151 is offline   Reply With Quote
Old 10-25-2012, 10:00 PM   #12
fuddbutter
Potato Farmer
fuddbutter's Avatar
Drives: #SLOBRZ
I really want one of these, but i think the physical size of it may not work with me, my legs are pretty close to the plug..
Something something butter..
www.vic86brzclub.com
fuddbutter is offline   Reply With Quote
Old 10-25-2012, 10:09 PM   #13
Raz555
Drives: 86 GTS & MY11 WRX
I have a GoPoint BT1, which is a lot smaller then the one the OP has pictured. I have it in the WRX (port is under the steering wheel) and it doesn't get in the way. Don't have my 86 yet, so can't comment if it would get in the way when driving or not.
Raz555 is offline   Reply With Quote
The Following 2 Users Say Thank You to Raz555 For This Useful Post:
Dadhawk (10-26-2012), fuddbutter (10-25-2012)
Old 10-25-2012, 10:53 PM   #14
Laika
When In Doubt...
Laika's Avatar
Drives: Slowww
Could someone familiar with this share any info on basic phone requirements to run the Bluetooth adapter and his app in my car? I ask because I was hoping to just score a cheap used android phone on eBay and use it only for my car. I completely forgot about this app when I was shopping for a new phone and wound up with the iPhone 5
Join the Galaxy Blue Silica BRZ registry below:
https://docs.google.com/spreadsheet/...2c&usp=sharing
Laika is offline   Reply With Quote
Mazda Working on mulitple rotary engines DIG1992 Other Vehicles & General Automotive Discussions 10 04-21-2012 09:40 AM
Not working... well I'll make it work ichitaka05 Other Vehicles & General Automotive Discussions 12 11-11-2011 10:42 PM
Toyota working on low budget FR sports car!!! yera Scion FR-S / Toyota 86 GT86 General Forum 5 03-16-2011 02:45 PM
Android vs iOS vs BB os...which is best? Raiden Off-Topic Lounge [WARNING: NO POLITICS] 19 02-02-2011 10:37 PM
