Old 04-18-2012, 01:13 PM   #1
DIG1992
DIG1992's Avatar
Drives: 2011 MK6 GTI
Mazda Working on mulitple rotary engines
The minds at Car and Driver recently took a moment to speak with Robert Davis, senior vice president of Mazda U.S. operations, about the automaker's plans for the future. According to Davis, the rotary engine will continue to play a role in the company's products moving forward, with engineers applying the lessons learned through the SkyActiv program to the powerplant. That means the next-generation rotary will likely feature reduced internal friction and lightweight internals in a quest to reduce emissions and increase fuel economy. But the engine may find applications outside of its traditional role.
Not only is Mazda pursuing a rotary engine to power a vehicle, Davis admits Mazda is also investigating ways to use the design in tandem with an electric motor, with the pistonless engine responsible for charging an extended-range EV's batteries. Given the compact size and relatively low torque supplied by a rotary, this application would seem to hold promise. Of course, we've heard some of this before.
And what of a SkyActiv V6? Davis makes it clear there's no room in the SkyActiv stable for a six-cylinder, saying that the company will focus on lighter platforms and forced-induction four-cylinder engines instead
DIG1992 is offline   Reply With Quote
Old 04-18-2012, 01:46 PM   #2
SUB-FT86
86 Member
Drives: 2013 Toyota 86 2.0T (Asphalt)
I wonder if this means there will be a N/A and a F/I Rotary?
SUB-FT86 is offline   Reply With Quote
Old 04-18-2012, 06:14 PM   #3
SpeedR
First86 / boat thief
Drives: MKIV Supra
NO make them stop
SpeedR is offline   Reply With Quote
Old 04-18-2012, 06:37 PM   #4
SkullWorks
Drives: SSM LT MT BRZ
Direct injection rotary with ~14:1 compression...yes please,
Rotary generator for EV....might even get me a little intrigued IF it turns the right tires...
SkullWorks is offline   Reply With Quote
Old 04-18-2012, 07:00 PM   #5
Sparkplug
Rotard
Sparkplug's Avatar
Drives: 135i M-Sport
Don't believe it until I see it.
Sparkplug is offline   Reply With Quote
Old 04-18-2012, 07:06 PM   #6
serialk11r
Drives: '06 AM V8V Coupe
I don't think 14:1 is physically possible on a Rotary due to the shape, even if you get rid of the recessed part in the rotor face which is crucial for combustion.
If friction reduction goes well, they could try spinning it at higher speeds and using fancy coatings and stuff to counteract the poor combustion chamber shape, but that doesn't seem like it will give it competitive efficiency. I guess we'll just wait and see what they come up with.
Old 04-18-2012, 07:31 PM   #7
ahausheer
Re-member
Drives: Toyota camry
Since I have heard this a few times I guess you could say this story keeps going round in circles? or perhaps when the rotary is reintroduced it will have gone full circle?
Nothing decays like progress, and nothing preserves like neglect.
ahausheer is offline   Reply With Quote
Old 04-21-2012, 01:31 AM   #8
00NissanNinja
The Thread Lurker
00NissanNinja's Avatar
Drives: '14 BRZ, '17 GTI, MT09
I wonder if they are still looking at using hydrogen in their rotary engines, I remember a couple years back they mentioned some plans about research in using hydrogen in their rotary engines.
00NissanNinja is offline   Reply With Quote
Old 04-21-2012, 02:07 AM   #9
old greg
Rocket Surgeon
Drives: PSM GGA OMG
They did that years ago. Dual fuel hydrogen/gasoline RX8's were available for lease in Japan back in ~2007.
old greg is offline   Reply With Quote
Old 04-21-2012, 05:33 AM   #10
Levi
Drives: Toyota
I don't want the new RX-7 to be a hybrid.
Levi is offline   Reply With Quote
Old 04-21-2012, 09:40 AM   #11
Sparkplug
Rotard
Sparkplug's Avatar
I forget which company designed it, but a hybrid rotary already has been made. It was only a static rotary engine though (designed to spin at a single rpm) and only act as a generator to charge the batteries for the car. The real power was provided by the electrical motor.
I really don't think Mazda has it in them to make another rotary car. Things do look better now that a new Miata is coming out, as the last RX was made on a heavily modified MX-5 chassis, but I'm still skeptical. 16 mpg combined throughout the lifetime of a car is a tough pill to swallow. The only time I've even broken 20 mpg was on VERY long (300+ mile) trips. It wasn't even to how I treat the car, but just the general nature of how the motor runs; very rich at first and then it will finally lean out.
So you think you know engines? Ryephile Other Vehicles & General Automotive Discussions 43 02-04-2012 03:49 AM
Not working... well I'll make it work ichitaka05 Other Vehicles & General Automotive Discussions 12 11-11-2011 10:42 PM
Toyota working on low budget FR sports car!!! yera Scion FR-S / Toyota 86 GT86 General Forum 5 03-16-2011 02:45 PM
Rotary Extinction??? Rotarydisciple Other Vehicles & General Automotive Discussions 53 01-23-2010 09:58 PM
