Old 03-25-2015, 02:44 PM   #1
Eazid
Eazid's Avatar
LH License Plate Light Not getting power
I've been searching for a solution to this issue before I let Subaru deal with it.
The driver side license plate bulb isn't getting power. I've checked the bulbs (they're good). As far as I can tell there aren't separate fuses for each side of the plate. Also, I don't have an awesome wiring diagram for just the trunk. If anyone has any advice, detailed diagrams, or anything constructive please let me know.
//Eazid - 1990 Honda CRX - 2013 Subaru BRZ Limited
Eazid is offline   Reply With Quote
Old 03-25-2015, 03:23 PM   #2
Bergen23
Drives: '15 Halo FR-S
Have you checked with a multimeter to know that for sure you aren't getting power?
Edit: I know it's silly, but if they're LED lights, did you put them in the socket the correct way?
Bergen23 is offline   Reply With Quote
The Following User Says Thank You to Bergen23 For This Useful Post:
Koa (03-25-2015)
Old 03-26-2015, 08:25 PM   #3
Eazid
Eazid's Avatar
I have to try the meter. And no that's not silly but valid. The polarity is correct. tried multiple bulbs just to be sure I didn't have a couple bad ones. I'll report back on the multimeter findings.
Old 03-26-2015, 09:51 PM   #4
Bergen23
Yeah, the meter is going to be the best way to check. Have you looked inside the socket to make sure that it's all good in there and the bulbs would be making contact with it? If that's good, start making your way back through the wiring harness to ensure everything is good to go
Eazid (03-27-2015)
Old 03-27-2015, 01:10 AM   #5
Eazid
Eazid's Avatar
So.... Second time is the charm? I doubled checked the pins on the bulb and the socket. Individually they seemed fine. But comparing them to the side that worked I saw that they were both a bit off. I bent the pings with spring pressure closer together in the socket and adjusted the pins on the bulb. All good now. Thanks again. The lesson here is "check again."
The Following User Says Thank You to Eazid For This Useful Post:
Bergen23 (03-27-2015)
bulb, fuses, license plate, wiring
---Autolismo.com, Vancouver Canada--- Samsung LED License Plate Light autolismo Exterior Parts - Lighting 312 11-16-2017 11:18 AM
Back up camera integrated with license plate light brianlo622 Electronics | Audio | NAV | Infotainment 10 05-26-2014 09:04 PM
License plate light crooked? (diode dynamics) Vincenttam Cosmetic Modification (Interior/Exterior/Lighting) 7 01-07-2014 11:17 PM
Odd question: License plate light? Double4Free Scion FR-S / Toyota 86 GT86 General Forum 23 02-20-2012 08:29 PM
