Old 03-25-2015, 02:34 PM   #2535
tahdizzle
So elite I'm 1338
Drives: WRB Subaru BRZ
Originally Posted by renfield90 View Post
This. The problem is we have a rule saying "you can use any standard part" and a somewhat liberal definition for what a standard part is, but we don't have a rule saying explicitly "you can't change springs." If we were required to run the springs the car physically came with, this goes away.
The adage is "if it doesn't say you can, then you can't" but the definition of standard part lets you do a lot. There's good reasons for it being so open, but it might be worthwhile to explicitly pare this back.
Rules are not in question.
Classing is. You're essentially making a FR-S a release series minus the aero by changing the suspension components to that of a Release Series (which is a b street car).
B Street has the same rules as C Street, just different cars in that classification. So the question is in classing and not in ruling.
-Jack Burton
Old 03-25-2015, 02:37 PM   #2536
Shark_Bait88
Shark_Bait88's Avatar
Drives: 2013 Firestorm FR-S
Didn't realize it's rear sway bar only. No matter, should pair very nicely with my Hotchkis front bar.
What makes you think it's the RSB only? Here's the description from the letter @simpleisbest posted.
"•Kit includes:
◦20.6mm 4130 solid front sway bar
◦15.8mm 4130 solid rear sway bar
◦Polyurethane bushings, front and rear, that fit the OEM brackets**
◦Rear sub‐frame reinforcement brackets"
I've seen other descriptions and pictures that state/show that it's both bars as well. If it was just the picture in the letter that made you think that, I imagine it was simply a marketing thing to show the installed bar (easier to show a good shot of one installed than an underbody shot that shows both.
"Shark_Bait88, the man who’s spent the most money modding his stock FR-S and it’s still stock." -@jdnguyen
Shark_Bait88 is offline   Reply With Quote
Old 03-25-2015, 02:41 PM   #2537
tahdizzle
So elite I'm 1338
Originally Posted by 7thgear View Post
because a flat move of the FRS to BS under the assumption that every FRS owner will go out of their way to purchase a TRD Spring and Swaybar kit is just wrong.
I don't disagree; I like @coneracer30's idea.
This not only punishes those that decide to do this by throwing them in a class they have no business in, but also those that didn't do this by throwing them along with them.
The RS is in B Street. For better or for worse. People who decide to essentially make their car a Release Series FR-S are shooting themselves in the foot.
bulletin prohibiting this weaseling is much more sensible.
Also a very good option.
-Jack Burton
Old 03-25-2015, 02:48 PM   #2538
renfield90
The Stig's German cousin
"•Kit includes:
The letter had a typo initially.
Old 03-25-2015, 02:55 PM   #2539
Shark_Bait88
Ah ok.
I'm really curious to see how this plays out. If it looks like we can run these parts for at least a year and they seem to improve the performance, I'll likely do it. Would make the blog series I'm going to write about my season even more interesting.
Really, doing this sort of loophole modding within class is completely in the spirit of motorsports. Formula 1 is legendary for sneaky mods, engineering, and technology that very keenly exploited loopholes and vague language within the rules. Exploit it while you've got the chance, because they will find a way to calm the water. It really sucks for everyone else, but you can't really be mad at the FR-S owners who choose to install the TRD parts.
Old 03-25-2015, 02:57 PM   #2540
jdrxb9
jdrxb9's Avatar
Drives: ND2, formerly BRZ (MT/CBS)
Originally Posted by Cueman View Post
For sale: TRD Front Sway bar. Beautifully power coated red. Brand new never installed. Great for CStreet BRZ - $150.
For sale: Custom-valved Koni SA front struts and rear shocks. Fronts brand new and never installed, rears freshly serviced/painted and with less than one week street use. Should work great with TRD SPRING PKG, P/N: PTR07-18130 for CStreet FR-S! $offers!
( not really a joke )
jdrxb9 is offline   Reply With Quote
Old 03-25-2015, 03:05 PM   #2541
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
Originally Posted by Arigh View Post
Stock class includes contingencies for modification, and the classes are balanced on cars that are fully prepped. Without those modifications, you will not be as competitive at a national event.
This is the same idea.
except that the contingencies are for modifications done above stock trim, not modifications required to be performed just to get to stock trim.
Old 03-25-2015, 03:10 PM   #2542
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
The 370Z is in BS, it includes both the base model, and the go fast model with a LSD and a power bump. You need the higher model to be competitive.
That's horrible,. I did not know this, I suppose the base 370z should have stayed in CS.
Old 03-25-2015, 03:11 PM   #2543
renfield90
Seriously? Let's talk.
Old 03-25-2015, 03:16 PM   #2544
renfield90
I think we're talking past each other.
Here's the thing: you can move the base model FRS up to BS but that only fixes the base model FRS. What if Mazda pulls this trick next year with the MX-5? And yes, Mazda would do this on purpose, they've done it before in the past. Toyota has accidentally done this.
If you change the rules you can prevent this from happening again. I'm thinking really big picture here: how do you prevent revelations about port-installed options from blowing up your existing classing? You do that with rules.
The RS 1.0 was classed (buried) in BS due to limited numbers, the assumption being that the base model had no legal access to the juicy suspension bits. That assumption is blown wide open now, so classing is now strictly a question of performance potential. If the performance differential to the rest of CS is there, we're off to BS next year. That doesn't fix your root cause though, which is a liberal standard parts rule. See what I'm driving at?
Old 03-25-2015, 03:18 PM   #2545
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
See what I'm driving at.
... a Ford Focus RS for 2016?
Old 03-25-2015, 03:40 PM   #2546
G_Ride
G_Ride's Avatar
Drives: Some kind of Subaru
That's what I've been thinking about for a little while now
G_Ride is offline   Reply With Quote
Old 03-25-2015, 04:05 PM   #2547
SeanRTR
C-Street AutoX
SeanRTR's Avatar
double post
-2013 Scion FR-S C-Street
Gearhead Homes - Homes geared towards car enthusiasts: https://www.facebook.com/GearheadHomes.RealEstate
SeanRTR is offline   Reply With Quote
Old 03-25-2015, 04:06 PM   #2548
SeanRTR
C-Street AutoX
SeanRTR's Avatar
_______
That standard regular-ass CS 370Z covered the field in BS at nationals, despite running on the green course last year. I'm not sure you can say a regular 370Z can't be competitive, or no one has really build a Nismo 370Z in BS?
No, this car raped us with minimal prep (stock wheels, etc etc) It's a CS overdog, and seemingly much more competitive than the slightly heavier, and less powerful longer wheel base 350Z.
Local rink a dink bullshit autocross, a 370Z is no faster than a twin, a nationals style SCCA course, it's a big spread.
Cinco De Mayo SCCA SOLO Ryeong86 NY / NJ / CT / PA 0 04-23-2013 05:22 PM
Koni Sports in SCCA SOLO Ryeong86 Tracking / Autocross / HPDE / Drifting 4 04-22-2013 12:58 PM
2013 Preliminary SCCA SOLO and PRO SOLO National Schedule Scooby South Tracking / Autocross / HPDE / Drifting 13 12-05-2012 08:08 AM
Houston SCCA Solo #9 - 5 FRS, 1 BRZ hankster Tracking / Autocross / HPDE / Drifting 0 10-09-2012 01:35 PM
SCCA Solo Car Class for the FR-S/BRZ? MrVito Scion FR-S / Toyota 86 GT86 General Forum 31 06-15-2012 10:03 AM
