Old 03-25-2015, 01:11 PM   #2521
simpleisbest
Senior Citizen
Drives: Scion FR-S
Originally Posted by simpleisbest View Post
Just needed to get to a computer.
Please find attached the pdf copy of an official publication from Toyota's accessories group. Big thanks to Jason I. and Steve M. to help clarify this situation for all.
This letter hereby confirms that the TRD Spring and Sway bar packages have been available as port options for all year FR-Ss to date.
Enjoy!
EDIT: 3/25/15 to update new letter from Toyota.
Please note I just received an update from Toyota.
So nice to see a manufacturer with management that actually listens to their customers
Enjoy!
simpleisbest is offline   Reply With Quote
Old 03-25-2015, 01:27 PM   #2522
renfield90
The Stig's German cousin
This should clarify things:
I see someone is ready for El Toro.
You won't be alone.
Old 03-25-2015, 01:38 PM   #2523
Cueman
Cueman's Avatar
Drives: In Perfect Control At All Times
Originally Posted by 7thgear View Post
"spring bumper"
Cueman is offline   Reply With Quote
Old 03-25-2015, 01:59 PM   #2524
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
You won't be alone.
I expect pax wins from the lot of you.
also, I propose a separate thread on the TRD springset to document your impressions.
Old 03-25-2015, 02:09 PM   #2525
coneracer30
Drives: 2013 Fiestorm FR-S
Watching this with interest. Not sure if I should be excited or not. I don't really expect it to totally transform the car into an overdog. I would probably only do the springs. I don't generally like big rear bars without a proper limited slip dif.
coneracer30 is offline   Reply With Quote
Old 03-25-2015, 02:12 PM   #2526
tahdizzle
So elite I'm 1338
Drives: WRB Subaru BRZ
... so you are all debating on the TRD stuff on a non RS FR-S and classing in Solo.
Well if the RS is a B Street car. and You are all planning on putting parts from a B Street Car because of a document that says they are port installed parts on all models of FR-S.
Then the most logical thing to assume is: FR-S's will probably be moved to B Street.
end debate.
-Jack Burton
Old 03-25-2015, 02:19 PM   #2527
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
well.. no... that would be an extremely hamfisted solution, not logical at all.
Old 03-25-2015, 02:20 PM   #2528
coneracer30
I think the easiest thing to do rules wise is make frs with the TRD parts run BS with the special editions. As much as I'd like to upgrade springs, it doesn't make sense to screw the brz's and upset the apple cart.
Unless.....the ND ends up in CS and is perceived as a possible over dog.
Old 03-25-2015, 02:22 PM   #2529
tahdizzle
So elite I'm 1338
Why would you asume that?
The only way the RS really differs from any other FR-S is the springs, sways, and aero.
So everyone adding everthing but the Aero from a RS wouldn't prompt the SEB to consider bumping a FR-S to B Street, but instead moving numerous cars around to accomodate the FR-S remaining in C Street?
Edit:
Or the other option of maintaining the status quo, and essentially allowing a RS in C-Street.
-Jack Burton
Old 03-25-2015, 02:24 PM   #2530
TrqlessWonder
Drives: 2014 FR-S
This is street class autocross. Logic is a far from guaranteed.
-Mike
#24 CS/CSR
TrqlessWonder is offline   Reply With Quote
Old 03-25-2015, 02:24 PM   #2531
renfield90
I feel you. I intend to test with OEM and TRD rear bar.
If you have a stiff enough front bar (i.e. Hotchkis, which I have) you may be able to get away with more rear bar.
If you spend the money on these, make sure you're OK with this being a one year deal. Don't be surprised if the SEB takes your ball away next year.
Old 03-25-2015, 02:27 PM   #2532
simpleisbest
Senior Citizen
Drives: Scion FR-S
That would work. Then all you would need is just to have 2 coilover sets ready and a stock rear bar, paint mark your toe settings, and BAMM! Be ready jump classes to farm contingency.
Its common practice for SP guys to jump to SM, depending on competition. Never heard of it in Stock classes, but there is always a first, right?
Old 03-25-2015, 02:31 PM   #2533
renfield90
So adding everyone adding everthing but the Aero from a RS wouldn't prompt the SEB to consider bumping a FR-S to B Street, but instead moving numerous cars around to accomodate the FR-S remaining in C Street?
Edit:
This. The problem is we have a rule saying "you can use any standard part" and a somewhat liberal definition for what a standard part is, but we don't have a rule saying explicitly "you can't change springs." If we were required to run the springs the car physically came with, this goes away.
The adage is "if it doesn't say you can, then you can't" but the definition of standard part lets you do a lot. There's good reasons for it being so open, but it might be worthwhile to explicitly pare this back.
Old 03-25-2015, 02:34 PM   #2534
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
because a flat move of the FRS to BS under the assumption that every FRS owner will go out of their way to purchase a TRD Spring and Swaybar kit is just wrong.
This not only punishes those that decide to do this by throwing them in a class they have no business in, but also those that didn't do this by throwing them along with them.
bulletin prohibiting this weaseling is much more sensible.
Cinco De Mayo SCCA SOLO Ryeong86 NY / NJ / CT / PA 0 04-23-2013 05:22 PM
Koni Sports in SCCA SOLO Ryeong86 Tracking / Autocross / HPDE / Drifting 4 04-22-2013 12:58 PM
2013 Preliminary SCCA SOLO and PRO SOLO National Schedule Scooby South Tracking / Autocross / HPDE / Drifting 13 12-05-2012 08:08 AM
Houston SCCA Solo #9 - 5 FRS, 1 BRZ hankster Tracking / Autocross / HPDE / Drifting 0 10-09-2012 01:35 PM
SCCA Solo Car Class for the FR-S/BRZ? MrVito Scion FR-S / Toyota 86 GT86 General Forum 31 06-15-2012 10:03 AM
