Old 08-19-2013, 04:31 PM   #1
JACK 8URT0N
Black Blood of the Earth
JACK 8URT0N's Avatar
Drives: The Porkchop Express
Clunking noise after installing springs
Installed RS*R Superdowns on the BRZ this weekend, and I'm getting a clunking noise all around the car in low gear at slow speeds. There are no noises at high speed on the highway, everything is smooth. After noticing the noise, we jacked the car back up and double checked everything, and nothing was loose. Drove the car all weekend hoping the noise would settle, but it hasn't. It's not better or worse, just clunky on bumpy roads and road divets, like something is loose. NOT a metal on metal sound. I'm taking it to my friend's shop this weekend to put it on a lift, and check the suspension. Has anyone else had something similar happen when lowering on springs?
It's all in the reflexes.
JACK 8URT0N is offline   Reply With Quote
Old 08-19-2013, 04:48 PM   #2
KONVERTER
KONVERTER's Avatar
Do those springs have rubber spring silencers where the springs compress?
Sent from my Nexus 4 using Tapatalk 4
KONVERTER is offline   Reply With Quote
Old 08-19-2013, 04:55 PM   #3
DAEMANO
Time Traveller
Many others have installed springs and ended up with a CLUNK noise, the answer may be in one of the many threads about it. If after you've triple checked everything, then contact RS*R USA.
Rear end clunk after H&R Super Sport Spring Install
http://www.ft86club.com/forums/showt...ighlight=clunk
Clanking sound after Eibach pro install
Suspension Review: Race Comp Yellow Springs
http://www.ft86club.com/forums/showt...unk#post456900
Clunk sound from rear suspension
Old 08-19-2013, 04:55 PM   #4
JACK 8URT0N
No.
http://www.frs86.com/suspension/rs-r...s-for-brz.html
Old 08-20-2013, 10:30 AM   #5
f0rge
head of infinite swagger
Drives: 2013 FR-S 6MT
I had 2 separate noise issues when I did my springs and then LCAs 2 weeks later. The 2 culprits were the top hats (or mounts) not being tightened properly in the rear and then the sway bar end link bolt that attaches to the LCA was stripped and didn't tighten properly.
Triple check everything to make sure you have no play.
2019 Golf R 6MT - current daily...I need another coupe
2008 Civic Si - winter beater
2000 Silverstone M5 6MT - SOLD
2013 Ultramarine FR-S 6MT - Car Journal - SOLD
2004 AlpineWhite M3 6MT - SOLD
f0rge is offline   Reply With Quote
Old 03-22-2015, 12:33 PM   #6
exE36M3
Try the upper mount nuts - especially on front struts. People tend to think all they need to do it tighten the nut, they forget that the inner shaft will spin. So they have to hold the shaft while they torque the nut to 41lbs. Try that.
exE36M3 is offline   Reply With Quote
Old 03-25-2015, 12:44 AM   #7
norcal_brz
Drives: 04 Evo 8 SSL, 13 Brz Limited
Make sure to torque it to the recommended specs since I had that issue with my st coilovers
norcal_brz is offline   Reply With Quote
Old 03-25-2015, 01:26 PM   #8
Hyper4mance2k
Alexandrino_Auto
Hyper4mance2k's Avatar
Drives: series.Blue
You guys are answering a 2 year old post...
The Shadetree Project: I turn wrenches
Hyper4mance2k is offline   Reply With Quote
Old 03-25-2015, 01:55 PM   #9
Koa
noobs
by the way this is wrong.. most people blow their stock struts if they allow the shaft to spin while "torquing" the nut down, or trying to disassemble, or any combination of the two.
Old 03-28-2015, 03:37 PM   #10
exE36M3
Originally Posted by Koa View Post
noobs
Except in my case, it worked.
I got a bad clanking from a loose upper strut nut because the dealer tech didn't torque it down to spec.
clunking, noise, springs, suspension
E-Brake issue "clunking noise" when pulling the e-brake while rolling. Kinzo Suspension | Chassis | Brakes -- Sponsored by 949 Racing 55 06-20-2018 10:14 PM
Replacing Struts and Installing Coil Springs DarrenDriven DIY (Do-It-Yourself) Guides 195 04-26-2017 04:15 PM
rear rattling/clunking suspension noise ceebo Scion FR-S / Toyota 86 GT86 General Forum 8 04-25-2014 10:00 PM
Transmission Clunking (A/T) Mr. J Issues | Warranty | Recalls / TSB 6 01-01-2013 07:11 PM
How necessary is alignment after installing new springs? switchlanez Suspension | Chassis | Brakes -- Sponsored by 949 Racing 47 11-22-2012 11:52 AM
