Old 03-23-2015, 03:30 PM   #1
JS + BRZ
Drives: 2010 MS3
Best phone mount?
I have a 2013 BRZ Limited. What's the best phone mount? Trying to find something that's very sturdy so I can use it at the track.
Thank you!
Old 03-23-2015, 04:02 PM   #2
dp1
driving smoother faster
Drives: Sold
I use this at the track, mounted to the right of the stereo: Nite Ize STCK-11-R8 Steelie Car Mount Kit for Cellphones
dp1 is offline   Reply With Quote
Old 03-23-2015, 08:23 PM   #3
JS + BRZ
Drives: 2010 MS3
Wow, I've never seen that one before. Guess it's sturdy enough to be used at the track!? Did you buy it from Ebay? Can you post your set up if you don't mind? Just curious!
http://www.ebay.com/itm/Nite-Ize-STC...-/310939963700
Old 03-23-2015, 08:42 PM   #4
lastexile1987
lastexile1987's Avatar
Drives: Lightning Red '13 Limited BRZ
Beatsonic phone mount. Pricey but it attaches BEHIND the dash trim so that's pretty much guaranteed to stay. You actually pull the trim off, pretty easy to do, fit the mount on and put the trim back on.
lastexile1987 is offline   Reply With Quote
Old 03-23-2015, 08:46 PM   #5
JS + BRZ
Drives: 2010 MS3
I've seen that one! Is it pretty sturdy?
Old 03-23-2015, 08:48 PM   #6
Lelantas
Lelantas's Avatar
Drives: '15 BRZ ISM
Here's a good thread to get you started. From what I've seen, if money's not really an issue, ProClip and RAM Mount both seem to be very sturdy options.
Lelantas is offline   Reply With Quote
The Following User Says Thank You to Lelantas For This Useful Post:
JS + BRZ (03-23-2015)
Old 03-23-2015, 08:56 PM   #7
Raven604
I have the beat sonic, worth kt
Raven604 is offline   Reply With Quote
Old 03-23-2015, 09:08 PM   #8
dp1
Drives: Sold
It's too dark now to take pics. Got it from Amazon. I stuck the ball piece right around the middle of that 3" (or so) plastic section between the stereo and the airbag cover. The phone piece (with "steelie" print on your pic) is attached to a hard case (not the phone). Just don't get a case with a pattern (or the 3M may not stick well) and don't hold your wallet/credit cards against the magnetic phone piece.
I use this iPhone 6 case: http://www.amazon.com/LUVVITT%C2%AE-...NTY-Absorbing/
The magnets are strong enough to hold the phone in place. I always have the charging cable plugged in when I'm driving (Waze app running), but even without cable it didn't move at all. I track and ax and daily drive my car and I never had it fall or noticeably change position. Easy access to radio and glove compartment. Tried a few different things...this one stays.
Can't record videos with Harry's Lap Timer when phone is mounted this way, but you can run HLT to record data in this position (and monitor lap time) while using GoPro with a RAM suction cup mount attached to the middle of the rear window (to capture the track, your steering, shifts), then merge data and video later to get something like this
[ame="https://www.youtube.com/watch?v=ZqXcT4oElek"]NJMP Lightning 2014-07-20 NASA HPDE 2 Run 3 Scion FR-S SC - YouTube[/ame]
(me driving slow at the track)
The Following User Says Thank You to dp1 For This Useful Post:
Old 03-24-2015, 06:03 AM   #9
Books
Books's Avatar
Drives: Ultramarine FR-S (MT)
I've been very happy with my Ram mount. It's very sturdy.
Books is offline   Reply With Quote
Old 03-24-2015, 09:02 AM   #10
jknakes
Drives: 2006 stage 2 sti and 2013 brz
http://www.theairdock.com/
i have one of these. it's great. phone sticks to it with no issue and it charges while on there. i have the standard mount suctioned to the right of the head unit. in great perfect location to use and see easily.
jknakes is offline   Reply With Quote
Custom phone mount so26 DIY (Do-It-Yourself) Guides 20 11-07-2016 04:15 PM
Ideas for a hidden magnetic phone-mount. MmmDieselFumes Cosmetic Modification (Interior/Exterior/Lighting) 40 05-09-2016 01:14 PM
Kenu Airframe phone mount review radroach Electronics | Audio | NAV | Infotainment 12 06-07-2015 12:19 AM
ProClip custom phone mount seanyboy Interior Parts (Incl. Lighting) 1 03-27-2014 11:46 AM
DIY phone mount GaDgeT Electronics | Audio | NAV | Infotainment 2 07-05-2013 10:18 PM
