Old 03-20-2015, 02:35 PM   #43
TennisHsu
TennisHsu's Avatar
Drives: 2013 Whiteout MT Scion FR-S
http://www.ft86club.com/forums/showp...6&postcount=22
TennisHsu is offline   Reply With Quote
Old 03-20-2015, 03:01 PM   #44
HunterGreene
Hail Magnet
HunterGreene's Avatar
Originally Posted by phobos512 View Post
Scosche Magic Mount. "Permanent" mount to the right of the radio, plate on the back of my phone (well, actually in between my phone and its TPU case). Also have a suction cup version that I use for when I travel and to mount my OFT when I datalog. I have a charging cable routed from the glovebox where I have a dual-port 4.2A Scosche car charger...One port cabled up for my LG G3 and the other cabled up for my girlfriend's iPhone.
http://www.scosche.com/magic-mount-c...r-tablet-mount
http://www.scosche.com/chargers/usb-...rger-dual-port
Originally Posted by Synack View Post
Scosche Magic Mount
/thread
$15 at Walmart/Amazon - http://www.walmart.com/ip/magicMOUNT...Mount/37551986
It's basically a strong magnet that DOES NOT mess up your internal components because it uses the special type of rare metal that you see on the back of my phone. It's very minimal on the phone and in the car. Holds very strong. Allows for full use of all buttons. The metal piece can be stuck easily in a case. I've seen people stick it inside their Galaxy S4 and S5 after removing the back battery door cover. It's very thin.
How does this mount to the car? Sticky?
It has priests in it?
Old 03-20-2015, 03:07 PM   #45
phobos512
phobos512's Avatar
Drives: 2014 FR-S 6MT Whiteout
3M adhesive back. The ones that we both showed has a flexible base to conform to flat or variously curved surfaces. So on a warm day (or get your hair dryer out) you flex the tabs on the thing, hold it in place, count to 30, 60, 90 seconds (however long) and away you go. To remove, fishing line and Goo Gone.
And as I mentioned, I also have a suction cup version also that I use for my OFT. I mount it to the windshield right above the driver's side vent and run the cable underneath the dash and up and it works great for datalogging.
Matt | '14 FR-S 6MT Whiteout | '13 Sonata Hybrid | '11 CBR1000RR
phobos512 is offline   Reply With Quote
The Following User Says Thank You to phobos512 For This Useful Post:
HunterGreene (03-20-2015)
Old 03-20-2015, 03:18 PM   #46
wheelhaus
wheelhaus's Avatar
I made one from CF and integrated a ball detent to rotate it 90° for GPS. I'll post pics later.
I wanted something with an integrated lightning connector that I could just drop the phone on and let it charge/sync with my stereo without having to fumble with cables.
Old 03-20-2015, 03:44 PM   #47
HunterGreene
Hail Magnet
for the record, I have the iOttie mount directly mounted to the dash above the vents--it doesnt really block my view, it sits over the vents which provide backup cooling for it during the summer, and its a natural position for me to use it.
Old 03-20-2015, 03:59 PM   #48
Synack
Boosted
Synack's Avatar
Drives: Sideways
Yes it's just a standard adhesive on the back. It takes up little room and is very stable. This is the first mount that I don't mind leaving on my car forever and not caring about it. Usually I have to remove a mount for various reasons.
Nismo 370Z 300whp -> FR-S Turbo 450whp on E85 -> Z06 Corvette 500whp
Synack is offline   Reply With Quote
Old 03-20-2015, 04:23 PM   #49
MokSpeed
Granny Shifter
MokSpeed's Avatar
Drives: 2014 FR-S
cup holder
MokSpeed is offline   Reply With Quote
Old 03-21-2015, 05:05 AM   #50
weave17
Drives: Subaru BRZ
Hey, you might want to have a look at the imagnet... pretty sleek if you ask me...
weave17 is offline   Reply With Quote
The Following User Says Thank You to weave17 For This Useful Post:
brandonblt2 (03-23-2015)
Old 03-23-2015, 12:15 PM   #51
HunterGreene
Hail Magnet
Got the "Scoche" mount this weekend, love the ease of mounting. Magnet is alot stronger than I thought. My daughter, who is two and rides in the back seat, kept saying "I see out of the front now!" and "Where daddy's phone?" I didn't realize how much it blocked her view. Loving it.
Old 03-23-2015, 02:15 PM   #52
mtdang
Originally Posted by OverSpent View Post
Here's mine.
  • Proclip FR-S mount
    Bracketron holder
    StarTech coiled cable
Which length cable is that?
mtdang is offline   Reply With Quote
Old 03-23-2015, 02:31 PM   #53
OverSpent
OverSpent's Avatar
Drives: 2013 Argento FR-S
It's the 1ft length. They count the length as if it was fully stretched out. Here's the one I picked up:
[ame="http://www.amazon.ca/dp/B00FZM2VTG"]http://www.amazon.ca/dp/B00FZM2VTG[/ame]
StarTech.com USBCLT30CMB 1-Feet Coiled Apple 8-Pin Lightning to USB Cable for iPhone iPod iPad 3/4, Black
OverSpent is offline   Reply With Quote
Old 03-23-2015, 04:07 PM   #54
mtdang
Thanks! I wasn't sure if the 1ft would be a stretch.
Old 03-23-2015, 07:27 PM   #55
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
best phone mount (borrowed from Miwa san's photo)
It was on the concept convertiable car
The Following User Says Thank You to chaoskaze For This Useful Post:
tato.valverde (03-24-2015)
Old 03-23-2015, 08:34 PM   #56
brandonblt2
The Stig's African Cousin
brandonblt2's Avatar
Drives: 2014 wrb brz
I have the same one heres where I have mine mounted I also have a phone charger running through the headliner so I can charge and use the gps
brandonblt2 is offline   Reply With Quote
Phone holder Tim_Asphalt_FRS Cosmetic Modification (Interior/Exterior/Lighting) 79 04-02-2016 04:28 PM
Is it possible to use a phone as a BRZ key? Killianti Electronics | Audio | NAV | Infotainment 19 08-13-2014 05:55 PM
Window weld motor mounts (poor man's solid mounts) unsurety Engine, Exhaust, Transmission 8 06-05-2014 03:36 AM
Let's talk phone mounts l0aded Electronics | Audio | NAV | Infotainment 41 06-14-2013 01:53 PM
Phone app. DanoFA20 Site Announcements / Questions / Issues 6 10-23-2012 12:55 AM
