| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
Drives: Raven FR-S
Tire size question on 18 x 9.5 all around wheels.
Hey guys I have a set of 18 x 9.5 +30 offset all around. I am debating on what tires I should get. I am going to be running BC Racing coil overs with 10k Swift springs. I want to be a functional low, Im just not sure on what tires to get. I was thinking maybe 225/40 Front and 245/40 Rear. Thoughts? Thanks.
#2 | |
Drives: Fast
245/35 is as low as I'd go on 18 X 9.5. 255's give it a meatier fit with no stretch at all. 225's will leave your rim sticking out a half an inch, maybe more. 40 sidewall may be a bit much on 18's, but doable. |
#3 |
Drives: Raven FR-S
I wont have any rubbing issues with 255/35? I just don't want to rub, thats my main concern.
#4 | |
Drives: Fast
I personally run 245/35 squared on 18X9.5 +38 to keep my speedometer close to what it was stock, but 255's will fit 9.5" width the best. You can check some of the tire fitment calculators on the web just to be sure, but I'm positive you will not have issues. |
#5 |
Drives: brz
depends how low you want to go, if you want to tuck the wheels and be really low do a 215. if you want to be low but not slammed don't go bigger than 225. if you want low but a little wheel gap go with a 235. if you don't want to go low and want a time attack "racecar" stance 245-255
also don't run staggered tires on non staggered wheels. it just looks weird, really weird |
| The Following User Says Thank You to adamg For This Useful Post: | swarb (03-23-2015) |
#6 |
Drives: 2014 GT86
18x9.5J +38 is pretty much the "all around" set-up for these cars. Most people in the category run 245/35 Front and 255/35 Rear
#7 | |
Drives: Raven FR-S
#8 | |
Drives: Raven FR-S
#9 |
Drives: Raven FR-S
#11 |
Drives: Raven FR-S
#12 |
Drives: Asphalt FR-S 6MT
You'll probably have to roll your fenders. It's super easy though.
| The Following User Says Thank You to JustBoostin For This Useful Post: | 8six_frs (03-23-2015) |
#14 |
Drives:
I think 225 front and 245 rear would work. This is about 2-2.5in drop with 18x9.5 +34 with 235/40 tires square
They fit with no fender mods and very little rubbing. |
| Tags |
| coilovers, fitment, lowered, wheels |
| Tire Brand & Size Question | ExxelDistributions | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 6 | 10-23-2014 05:03 PM |
| tire size question | Frs32907 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 8 | 04-22-2014 12:04 AM |
| Tire size question..? | Yamajee | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 9 | 11-18-2013 05:21 PM |
| Tire Size and Ecutek Tune - Stupid question | Pokeguyjai | Software Tuning | 5 | 10-04-2013 11:43 AM |
| QUESTION: Rim & Tire Size at NJ & NY | Figo | NY / NJ / CT / PA | 6 | 07-17-2013 02:21 PM |
