| Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) Everything related to the mechanical maintenance of the FR-S and BRZ |
Changed Diff/MT Trans Fluid to Motul 300 and super low MPG
Just wondering if anyone else had effects such as this... I changed out both my MT fluid and differential to Motul 300, and went from 29 MPG to 23... Is this just due to a break in period of the new oil? Or just characteristic of this particular oil? Thanks!
#2 |
Drives: 2013 GBS BRZ Limited
I saw no change at all in mine. 30 MPG solid.
It's not the oil causing a 20% reduction in your gas mileage |
| The Following User Says Thank You to stugray For This Useful Post: | AZP Installs (03-27-2015) |
#3 |
Drives: Asphalt FR-S
Tire pressure, driving habits, bad fuel, different weather can all change your MPG, but a bit of oil certainly wont! :P
#4 |
Just curious, I just checked tire pressures, I did bump up to 8 inch wide wheels and 255-40 tires... But doubt that's going to do that either... And I actually have been driving more conservatively
#5 | |
Drives: 13 FRS Satin
If you're running something else, you've found your problem. The Primacy HPs are low rolling resistance tires. 'Usually' going to a thinner MTF fluid will increase fuel economy. |
#6 |
Drives: JAWS
Heavier wheel and tire combo can definitely affect MPG...and a non LRR tire too.
#7 | |
Drives: '13 Nissan Frontier (4.0L 6spd 2WD)
That's like someone saying they switched from Exxon to Shell fuel and noticed a decrease in the fuel mileage...then later posting "Oh yeah I also installed a turbocharger system with higher capacity/flow injectors at the same time...." LOL
Had a '13 FR-S Asphalt 6spd manual (bought new 5/25/12, sold 6/10/20) but needed to let her go... she will be missed.
#8 |
Except looking back, I did my wheels and tires first, and hadn't noticed a difference but had been driving highway only... then did the fluids change and have been driving local+highway... only noticing it greatly now... I am currently on 17x8 Enkei RP03 wrapped in 245**-40-17 Dunlop ZIIs... not LRR, but lighter combo than oem setup.
#9 | |
| The Following 2 Users Say Thank You to Mad1723 For This Useful Post: | 8R6 (03-23-2015), continuecrushing (03-23-2015) |
#10 |
Drives: 2013 WRB Subaru BRZ 6MT
It's the tires. Going from the Michelin Primacys to Bridgestone RE11As brought me down to about 23-24 as well.
| The Following User Says Thank You to n8dog11914 For This Useful Post: | FT86Z (01-19-2016) |
#11 | |
| The Following User Says Thank You to Vracer111 For This Useful Post: | jfg5067 (03-24-2015) |
#12 |
Drives: Nevermorange FRS
You added unsprung weight and increased your rolling resistance.
Result is too be expected. As least you can sleep well knowing nothing is wrong.
SCCA T4 - FRS
#13 |
Mentat
Drives: 2013 Scion FRS 6MT
I noticed there are difference between different brand of gas. I am getting much better fuel economy with Shell V powaaaah.
#14 |
Tires and wheels over stock will make a HUGE difference. Therein lies your issue.
-mike |
| Pentosin Trans Fluid Swap | Motul 300 Diff Swap | Impressions | Dezoris | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 15 | 06-06-2017 11:54 PM |
| Have you changed your tranny fluid of your AUTO BRZ/FRS | ScionFR-S | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 20 | 01-14-2017 02:14 AM |
| Trans/diff fluid recommendations: Motul Gear 300, Extra-S, or.. | B-R-Z | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 1 | 07-03-2014 09:06 PM |
| Replacing Trans & Diff Fluid, Hot vs Cold | BRZNutt | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 8 | 12-22-2013 10:04 PM |
| Trans/Diff Fluid. | DanoFA20 | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 18 | 01-11-2013 04:11 PM |
