Old 03-22-2015, 02:13 PM   #57
Originally Posted by extrashaky View Post
Seeing the pic there reminds me of the video below. It's rather dry and a little long, but I think it's very good for newer drivers of manual transmission cars to watch the first several minutes of it to understand what's happening underneath. You don't actually have to watch the whole thing to get the benefit of it.
I remember when you first shared that. It's an excellent video. Thanks for the repost.
Old 03-22-2015, 02:52 PM   #58
Dezoris
Dezoris's Avatar
Its a mechanical assembly, and with wear and break in the feel will change. If you have a "good" gearbox shifts should always be smooth with two finger effort to change gears on this car. I have been in 86s with great gearboxes where clutch, gear feel rivaled some of the best manual cars. And others that chattered and were hesitant to engage gears.
Its a combination of experience (seat time) with manual transmissions and understanding that certain factors like, temp, gear oil, driving style and what is normal helps to make a better driving experience.
Personally if you have a good gearbox on this car there is absolutely zero reason to change anything in pedal travel, etc. I had 24k miles of rev matching every downshift, engine broke to every stop, but never gear skipped up shifts or down shifts (see S2000 problems). I never had one grind even after track miles. But this takes understanding more than just getting in and banging gears.
The Following 3 Users Say Thank You to Dezoris For This Useful Post:
Caspeed (03-22-2015), strat61caster (03-22-2015), Tcoat (03-22-2015)
Old 03-22-2015, 03:58 PM   #59
Caspeed
Caspeed's Avatar
Drives: FRS-RS1, Triumph Speed Triple, Lola
I'm willing to bet that many of those gear boxes that were "bad" are victlms of being slammed into gears or other such mis-behaviour.
The real danger in skipping gears while downshifting is if you do it at too high a speed. In our cars there are safeguards against over reving but they have no effect in this kind of over rev.
Caspeed is offline   Reply With Quote
The Following 2 Users Say Thank You to Caspeed For This Useful Post:
Koa (03-22-2015), Tcoat (03-22-2015)
Old 03-22-2015, 04:00 PM   #60
Koa
^ seriously
with the high tolerances of these things, it's VERY unlikely we are going to often run into a "golden egg vs lame duck" scenario with these transmissions... user error/neglect 99% probably cause here
The Following 2 Users Say Thank You to Koa For This Useful Post:
Caspeed (03-22-2015), Tcoat (03-22-2015)
Old 03-23-2015, 01:22 AM   #61
M12Power
M12Power's Avatar
Drives: 2015 Firestorm Scion FR-S 6MT
With my FR-S, it's difficult not to grind the gears going from 1st to 2nd as well as 2nd to 3rd. It's as though the gearbox has no synchros. I'm not sure how these synchros were designed, but there should not be noticeable grinding with synchros (that's the whole point of having synchros). It's just frustrating at times. Often times I think it would be far better if they just put a real racing gearbox with straight-cut dog rings in this car, since it tries to behave like one except it's got some supposed "synchros" to get in the way!
Anyway, what works for me to not grind the gears and making relatively smooth shifts is to wait about half a second to a second before engaging 2nd or 3rd. The problem with this of course is that fast shifts are not possible (i.e., the gears would grind if I try to shift very fast). Another unwanted side effect is that by the time I manage to put it into 2nd or 3rd without grinding, the revs would have dropped too much, therefore I have to add more gas in order to make the shifts smooth.
With that said, I should point out that I've now put more than 2,000 miles on the car, and with the weather getting warmer, shifts seem to have gotten better. Either that or the gearbox has definitely "loosen up" due to the abuse...
M12Power is offline   Reply With Quote
Old 03-23-2015, 11:59 AM   #62
Dezoris
Dezoris's Avatar
That is absolutely not normal. What is normal is hesitent 1-3rd in very cold weather on oem trans fluid. And not shifting to 2nd or 3rd in cold above 2500RPM is required on stock fluid for first few minutes.
The gear box should never grind unless it has mechanical issues, low on fluid or mis-use, slamming gears, shifting hard or at higher rpms at low temps/operational temps.
Old 03-23-2015, 08:54 PM   #63
86Tony
Drives: 2015 AOZORA EDITION
So I just test drove my brother in law new 15 brz and he has no noise or anything goin to 1-2 shit is buttery smooth. So I'm going to take mines in because my a 15.and I heard the thunk since day 1
86Tony is offline   Reply With Quote
Old 03-23-2015, 11:10 PM   #64
Teseo
Drives: frs
Ask your bro if he or the dealer changed the trans fluid
Old 03-25-2015, 12:14 AM   #65
86Tony
No it's was brand new only had like 25 miles when I drove it
Old 03-26-2015, 08:57 PM   #66
MaudDib
Drives: White, Toyota
I am thinking about purchasing a FRS and I am looking at a 13 as I don't see enough difference to go with a brand new 15.
Anyway, would you have any worries about purchasing a used manual trans? You just never know how someone has treated it or if they just learned how to drive one. I know there is a good chance the car has been driven hard, I just don't want excessive wear on the clutch.
Is there any good tests to know how much wear is on the clutch? Or is it just seeing where it engages, the stiffness (or lack of), that kind of thing.
Appreciate any insight.
MaudDib is offline   Reply With Quote
Old 03-26-2015, 09:18 PM   #67
billwot
Drives: '11 Cayman , '14 Camry, '11 Tacoma
I taught 3 daughters and a (middle-age) wife to drive MTs...none of them ever did any damage.
And when I was younger, I pretty seriously abused a lot of MT vehicles, but never broke any of them.
I'm always amazed how so many people seem to think manual trannys/clutches are somehow fragile. The truth is, its nearly impossible to break one. And the only clutch I ever fried was in a small-block powered Model A.
billwot is offline   Reply With Quote
The Following 3 Users Say Thank You to billwot For This Useful Post:
strat61caster (03-27-2015), Teseo (03-27-2015), Ultramaroon (03-26-2015)
Old 03-26-2015, 11:22 PM   #68
Own a manual for any length of time and a clutch job is inevitable. I wouldn't sweat it.
There's no way to tell with these cars or any with a hydraulic self-adjusting mechanism. Eventually the clutch will start slipping when goosing it in the taller gears.
If you do the work yourself here's some advice I learned the hard way many moons ago. Never ever cheap out on a rebuilt/remanufactured pressure plate. Always go with a new one.
Tcoat (03-27-2015)
Old 03-27-2015, 08:26 AM   #69
This^.
The very nature of modern clutch systems that make them so effective also does a great job of hiding problems until they suddenly just don't work anymore.
Also, don't think that there is a problem because the shifter feels notchy. These cars have a pretty precise gear gating set up and are not all loosey, goosey like some. This is a good thing not a bad one.
Ultramaroon (03-27-2015)
Old 03-27-2015, 08:53 AM   #70
PHLonomenal
PHLonomenal's Avatar
Drives: Whiteout 2014 Scion FR-S
MT Questions
The only time I have ANY problem is in the rare occasion my car is left outside on a cold day/night. Shifting this car cold feels as if you're going to break something until warmed up. Then all is well again. I like the trans overall even with this affliction. It's a very minor inconvenience in the grand scheme.
Sent from my StarTrek communicator using Tapatalk
I had an M3 once...and barely missed it. Barely
"what I'm driving here...is an ending." Jeremy Clarkson
PHLonomenal is offline   Reply With Quote
FRS/BRZ Questions, I am new. Reason22 FR-S / BRZ vs.... 14 08-14-2014 11:42 AM
Wax Sealant Pad Questions / Care Questions l0aded Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 3 03-25-2014 11:19 AM
HID / LED questions RealShkillz Cosmetic Modification (Interior/Exterior/Lighting) 7 06-01-2013 05:15 AM
Questions about a MT official_george Scion FR-S / Toyota 86 GT86 General Forum 18 05-20-2013 10:36 PM
E85 questions Grishbok Engine, Exhaust, Transmission 17 08-08-2012 10:49 PM
