Old 03-20-2015, 08:59 PM   #43
Gunman
Drives: 2019 Mazda Miata RF
Originally Posted by FRS Johnny View Post
I sort of wanted it above the mirror so no one can see it. I found a forum online that did a diy of one without suction cups. I'll try it tomorrow. Hopefully it works! Discovered 3M dual fasteners. or scotch outdoor fasteners. It holds 5 lbs!! It's basically velcro on steroids.
Can you share the DIY link?
Old 03-20-2015, 10:11 PM   #44
Chad86
DrivinginDreams...Cloud86
Chad86's Avatar
Drives: Toyota GT86
I am going to end up getting a Steelie. Hopefully this solution will work. Then when I want to use my sunshade, etc. I can easily remove my radar detector from the window.
Chad86 is offline   Reply With Quote
Old 06-04-2015, 08:43 AM   #45
solort
Drives: Series 10 FRS
How well does the suction cups stay on the dot matrix? Mine keeps falling off after driving. Right above the rear view mirror is perfect, but those dots don't work well for the suction cups. Any solutions anyone?
I have used clear packing tape over the black sunscreen dots to make the area smoother...
solort is offline   Reply With Quote
Old 06-09-2015, 01:12 PM   #46
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Thanks again for this DIY just "hardwired" in my escort passport and it works like a dream. Only took 30 minutes mostly because the stupid airbag cover had a hard time going back into place. Also rather than tucking in the cable through the gap near the glove box its way easier to pop open that side kick panel and just close the cable over it.
Sent from my A0001 using Tapatalk
Old 11-28-2015, 02:31 PM   #47
zkahle
zkahle's Avatar
Drives: 2013 Scion FRS Asphalt
So after days of being away from my car I decided that I would try this DIY. I own a valentine V1 and went to target to pick up a phone cord that was long enough to run from the glove box to my desired location. Long story short my V1 won't turn on any more. Both the center consol and the glove box electrical ports fail to start the radar. Tried my original cable to see if that was the issue and still no success. Any ideas y'all?
Hook Em'
zkahle is offline   Reply With Quote
Old 11-28-2015, 05:36 PM   #48
Chad86
Chad86's Avatar
Drives: Toyota GT86
Arrow
Most likely the fuse has blown in the V1 adapter. I have only had this happen once.
Old 11-29-2015, 11:46 AM   #49
zkahle
zkahle's Avatar
What could have caused the blown fuse? Was it the new phone cord or just by random chance. Id hate to swap out the fuse and plus the V1 back in to the new phone cord and have it blow again. And thanks for the help!
Hook Em'
Old 11-29-2015, 08:32 PM   #50
Chad86
Chad86's Avatar
Drives: Toyota GT86
My fuse just popped randomly from powering on I believe. Maybe a power surge can cause this, I'm not sure. I thought my Valentine 1 was shot initially, but then I checked the fuse and it was blown. Pull out the fuse and check to see if it is blown. The wire will be broken inside the fuse if this is the case. The fuse is located in the power plug adapter. My V1 has been running strong for approx. 10 years.
Old 12-03-2015, 11:08 PM   #51
mid_life_crisis
Drives: FR-S 10 #103 AT
You need to be careful with phone cables. They're reversed end to end by the standards, but they work for most phones even when they aren't. Sometimes they're wrong in the package, which could account for your problem.
“Sex is like Bridge. If you don't have a good partner, you'd better have a good hand.” - Mae West
Papa said, "son there's a lot of evil temptations out there. Best to try 'em all so you know which ones to avoid."
mid_life_crisis is offline   Reply With Quote
Old 03-27-2017, 03:09 PM   #52
p1l0t
p1l0t's Avatar
I didn't even know there was a lighter plug in the glove box WUT! Thanks for this.
soulreapersteve (03-27-2017)
Old 03-27-2017, 03:22 PM   #53
soulreapersteve
Contract? /人◕ ‿‿ ◕人\
soulreapersteve's Avatar
You learn something every day!
Also
lol
The Twins make me smile
The Following User Says Thank You to soulreapersteve For This Useful Post:
p1l0t (03-27-2017)
Radar L3P47 Electronics | Audio | NAV | Infotainment 31 05-15-2013 12:53 PM
radar detectors Touge_ninja Off-Topic Lounge [WARNING: NO POLITICS] 9 02-24-2013 02:27 PM
Radar Detectors swag BRZ First-Gen (2012+) — General Topics 28 01-31-2013 04:58 PM
Next mod: Radar dector jwbrocloud Scion FR-S / Toyota 86 GT86 General Forum 39 01-27-2013 01:04 PM
Has anyone done a good concealed Valentine One install? sikest Electronics | Audio | NAV | Infotainment 3 01-22-2013 06:37 PM
