Old 03-19-2015, 11:23 AM   #113
wparsons
wparsons's Avatar
Originally Posted by FT-86 SpeedFactory View Post
That's really it for cooling.
Vented hood? Running without the lower cover(s)?
flickr
wparsons is offline
Old 03-19-2015, 12:14 PM   #114
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
I would love to see a candor come out with a vented skid plate. That'd be nice.
cdrazic93 is offline
Old 03-19-2015, 11:29 PM   #115
FT-86 SpeedFactory
FT-86 SpeedFactory's Avatar
We ran the vortech kit with stock hood forever and raced it on tracks in Cali mid summer. It was a boosted solution and we saw no heat issues with that either.
We did add a vented hood as we went to our turbo kit, but that was for looks more than anything. We are running all stock under panels.
Everyone talks about heat issues on these cars. We're just not seeing it, from brakes, to the engine. We have two cars in house and neither car have heat issues on or off the track, even when we are in Cali mid summer.
FT-86 SpeedFactory is offline
The Following 2 Users Say Thank You to FT-86 SpeedFactory For This Useful Post:
CoopBRZ (03-19-2015), wparsons (03-20-2015)
Old 03-20-2015, 01:05 AM   #116
Pat
Pat's Avatar
Drives: 2023 BRZ
You guys don't have trouble keeping stock brakes from overheating? No brake mods at all? What tires and brake pads are you running?
Pat is offline
Old 03-20-2015, 06:53 AM   #117
2ndgenhachi
Drives: 2013 fr-s, sr20 180sx
So a couple questions... First would the base map be enough to run long term if I only wanted wastegate PSI? Seems like most base maps are intended to just get you to a tuner. Second if it's not suitable for the long haul any thoughts of getting a kit to delicious tuning to add it to the flash n go list? Third (sorry if I missed this elsewhere in the thread) what was the install time and does it require cutting the crash beam? Thanks in advance.
2ndgenhachi is offline
Old 03-20-2015, 07:23 AM   #118
xkalelx
xkalelx's Avatar
Drives: 2013 BRZ black
X2
xkalelx is offline
Old 03-20-2015, 09:59 AM   #119
FT86SF_tuner
Drives: FT86 turbo
For those that don't know, FT-86 Speedfactory has an in-house tuner (me). They pulled me in because I was local and have been tuning Subarus for years. I've been working with these cars since they were released and Ecutek provided their software. I have a good working relationship with Ecutek and help shape new features.
What we want to do with this kit is offer an included tune for spring pressure guys running on stock fueling. It will start with a safe base tune and I'll work with you remotely to dial it in perfectly. This will ensure the kit runs as designed and can troubleshoot any installation issues.
We are still working out details on the higher stages to go with this kit but I would love to package in tuning for people at all levels but of course leave the option to go to your own tuner if you already have one you prefer to use.
FT86SF_tuner is offline
The Following 6 Users Say Thank You to FT86SF_tuner For This Useful Post:
FT-86 SpeedFactory (03-20-2015), Koa (03-20-2015), Kwaziekeller (04-03-2015), Pen.suhl (06-22-2015), Porcupint (03-20-2015), xkalelx (03-20-2015)
Old 03-20-2015, 10:12 AM   #120
xkalelx
xkalelx's Avatar
That definitely boosts my confidence level in using the supplied tune. I hope you didnt take offense to the comments. Thanks for chiming in.
xkalelx is offline
Old 03-20-2015, 10:13 AM   #121
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
We beat the piss out of it on track last weekend at Road Atlanta zero issues.
Looked like you were running 0 deg AoA on that wing.
King Tut is offline
Old 03-20-2015, 10:57 AM   #122
FT86SF_tuner
Drives: FT86 turbo
No problem. I sure didn't. Tuning is VERY important on these cars and my preference is to handle each person individually to make sure the kit is working as it should on their car, in their environment using their fuel. We started on 91 to find the safest power we could on that blend. We will do testing with 93 and then testing at higher boost levels before moving onto E85. For those interested in flex-fuel, I've been working with a local customer on a turbo flex-fuel tune. The tune will handle everything based on the ethanol content, including boost targets and boost control using a boost control solenoid. I imagine you'll see this as an kit option in the near future.
The Following 2 Users Say Thank You to FT86SF_tuner For This Useful Post:
Koa (03-20-2015), Porcupint (03-20-2015)
Old 03-20-2015, 11:20 AM   #123
xkalelx
xkalelx's Avatar
Excellent. Glad to hear. Im flex and tuned with Delicious. E85 should be interesting with this EFR kit. @FT86SF_tuner Are you doing speed density tunes, MAF, or a combination of both? TIA
xkalelx is offline
Old 03-20-2015, 11:25 AM   #124
FT86SF_tuner
Drives: FT86 turbo
Cool, Bill is a great dude and excellent tuner. Can't go wrong with him either.
So far I've been doing everything blow-through MAF based and it works very well. Super smooth everywhere including idle and transition areas. Haven't found a need for Speed Density yet but when I have some time and access to one of the shop cars, I plan on getting it setup and dialed in for when it might be needed.
I use Cobb Speed Density for the higher power Subarus I tune (550 whp+) and its very useful on those. For the level of power that most BRZs might reach, I don't know if it will be needed unless a certain style of setup would benefit from it but again, I plan to explore it since it is available.
The Following User Says Thank You to FT86SF_tuner For This Useful Post:
Old 03-20-2015, 02:53 PM   #125
wparsons
wparsons's Avatar
Stock pads are useless on a track, worse with sticky tires.
Good pads on stock calipers/rotors with good fluid will do for most people. If you're running long sessions, or more experienced you're into BBK territory.
flickr
wparsons is offline
Old 03-20-2015, 03:17 PM   #126
Pat
Pat's Avatar
Drives: 2023 BRZ
I know that, but they claimed they don't have any issues with heat in their brakes. Sounded crazy to me.
Pat is offline
PTUNING FR-S/BRZ Turbo Testing @ VMP 4/21/2013 Events@Ptuning Tracking / Autocross / HPDE / Drifting 12 01-13-2014 10:22 AM
TyperRspec789's Full Blown Stage 1 Base Turbo & e85 Progress and Testing TyperRspec789 Forced Induction 63 12-31-2013 07:39 PM
FA20CLUB Turbo Kit 10 PSI Preliminary Testing FA20Club.com Forced Induction 161 07-27-2013 02:31 PM
N1 Concepts/Exotic Air - Turbo Development LSV8 Forced Induction 24 04-10-2013 09:48 PM
