Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > FT86CLUB Shared Forum > Regional Forums > AFRICA
Old 03-20-2015, 02:26 AM   #15
Freedom
Freedom's Avatar
Drives: PEARL WHITE GT86 TRD
Originally Posted by Ryliko View Post
Ah I apologise, I didn't notice it was your post Freedom. Thank you as well. I'm a car guy in nature but unfortunately not in theory, so I'll just be honest here and ask can you specifically point out where to look?
Yes, I'm still under warranty... though I can see a massive dispute coming as right after I installed the brz exhaust, my dealer from Market Toyota Cape Town sent his "regards" and stated that my car will be void of warranty (before I bought the car he even said powerflow' were allowed). I know technically they cannot just void it based on an exhaust which brings about a neglible effect on the engine... but that is another matter anf I don't want to derail this thread.
First of all they cannot void the entire warranty of your car. The exhaust will not be covered, that is all.
The fuse box is under the hood, in front of the battery. But I don't know which to look for.
Freedom is offline   Reply With Quote
Old 03-20-2015, 02:36 AM   #16
Ryliko
Ryliko's Avatar
Drives: '15 Toyota 86
Oh my.......... it was the one terminal of the battery that wasn't tightened from factory. The one bolt was so loose that a simple rocking of the car/ignition must've made it loose contact. As soon as the positive battery cover was lifted up, she came back to life! It's also an error on my part for not checking or not having the wisdom to have checked. I guess the silver lining is I don't have to deal with the dealership today.
Ryliko is offline   Reply With Quote
Old 03-20-2015, 02:46 AM   #17
Ryliko
Ryliko's Avatar
And I was still so aggravated by feeling tricked into the sale by my dealer that I haven't exactly responded to his last email about the warranty issue. However, what he basically inferred was the entire warranty (bull$hit I know) and not just the exhaust.
I'll open a separate thread regarding the exhaust warranty issue as I don't want to derail this thread any further.
Thank you so much for both of your inputs, even though I feel like a tool for not knowing any better to check the battery myself
Old 03-20-2015, 03:05 AM   #18
Dammod
Dammod's Avatar
Drives: .
Aah, thats how we learn bud. At least you know the first thing to check if it ever happens again.
Pleasure man. Maybe you could expand on what you mean by "tricked into the sale" in your thread you going to make.
"Some will follow your footsteps, easier than they will your advice."
Dammod is offline   Reply With Quote
Old 03-20-2015, 03:14 AM   #19
GeeTee86
86 Nut
GeeTee86's Avatar
Drives: 86 Satin 6MT High
the pre delivery process should have highlighted the loose terminal, bad dealer.
GeeTee86 is offline   Reply With Quote
Old 03-20-2015, 03:27 AM   #20
Ryliko
Ryliko's Avatar
It wouldn't really be tricked, per say, but it (the fact that I was under the presumption that the car could be reasonably modded - wheels, exhaust) did play a factor in influencing my decision to purchase. I'll touch base on this in the separate thread.
@GeeTee86, bad dealer but unfortunately theres only two options of dealers in Cape Town: foreshore and somerset west. I don't exactly stay near Somerset west
The Following User Says Thank You to Ryliko For This Useful Post:
Dammod (03-20-2015)
Old 04-07-2015, 07:35 AM   #21
Scarl3t
Scarl3t's Avatar
Drives: Hachi-Roku
confirmed working on STD 86,
thanks for the tip!!!!
Scarl3t is offline   Reply With Quote
The Following 2 Users Say Thank You to Scarl3t For This Useful Post:
Dammod (04-07-2015), FT_86_SM_GP (04-07-2015)
Old 04-07-2015, 07:37 AM   #22
Dammod
Dammod's Avatar
Drives: .
Thanks bud!
Regards,
Damien
The Following User Says Thank You to Dammod For This Useful Post:
Scarl3t (04-08-2015)
Old 04-08-2015, 10:16 AM   #23
Wepeel
Drives: '13 BRZ Ltd
How does this eliminate the cold (loud) high idle? Do you need to let it crank for a while to eliminate the cold high idle or can you just tap it for a bit and then the next start will be normal idle?
Wepeel is offline   Reply With Quote
Old 04-09-2015, 01:44 AM   #24
Scarl3t
Scarl3t's Avatar
Drives: Hachi-Roku
The idea behind cranking the motor is to get it lubed up before you start it,
don't think it's ment to eliminate the high idle upon start.
but i may be wrong, anyone have other thoughts on this?
Old 04-09-2015, 01:51 AM   #25
edeekeos
edeekeos's Avatar
Drives: 2014 Pearl BRZ Limited
The 'high idle' start is based on the temperature of the coolant. This will not affect that.
| OFT & Stg2 e85 Tune | Perrin Intake Tube & High Flow Filter | Perrin Lightweight Crank Pully |
| Tomei UEL Header/Overpipe | HFC/Perrin Catback | Tom's Tails | Enkei RPF1's | RS*R SuperDowns |
edeekeos is offline   Reply With Quote
The Following 3 Users Say Thank You to edeekeos For This Useful Post:
qbzee007 (04-09-2015), Scarl3t (04-09-2015), Vic_RSA (04-09-2015)
Old 04-09-2015, 02:12 AM   #26
Dammod
Dammod's Avatar
Drives: .
Like @Scarl3t said, the main idea behind this is to lube the motor up, however:
I have found that by simply letting it turn over for a few seconds (5?) using the above mentioned method, the car starts with a less "severe" the high idle.
Just my personal observation I thought I'd mentioned. You welcome to give it a go to see for yourself.
Old 04-09-2015, 09:22 AM   #27
Wepeel
Drives: '13 BRZ Ltd
Thanks guys. That makes sense. Nonetheless a good tip - maybe not a bad idea after an oil change.
The Following User Says Thank You to Wepeel For This Useful Post:
Dammod (04-09-2015)
Old 04-09-2015, 09:32 AM   #28
Dammod
Dammod's Avatar
Drives: .
Also true! Good idea.
Random squeak from Heater when cold?? BRZnut Issues | Warranty | Recalls / TSB 0 01-18-2015 12:57 PM
jerky starts goshem BRZ First-Gen (2012+) — General Topics 14 01-19-2014 11:21 PM
White Smoke cold start up in Cold Weather (turbo cars) whitefrs Forced Induction 17 09-25-2013 05:05 PM
Cold morning starts coldy CANADA 43 04-23-2013 02:30 PM
Issue: Cold starts jesseps CANADA 7 11-24-2012 11:26 AM
