Old 03-19-2015, 11:34 PM   #1
Stewie
Stewie's Avatar
Drives: '15 - WRB Brz Limited
What tire pressures do you guys run?
What tire pressures (cold) are you guys running? I'm on stock wheels/tires and it feels like I'm understeering on 360* highway exits/entrances if I'm pushing it a little. I usually give it a bit more gas and angle to compensate and help the car rotate...but if I have to slow for other traffic, lifting results in a manageable bit of oversteer. I'm trying to get it a bit more neutral. {BRZ Limited}
Ps - i did search for this, but most of the results were in the autocross/hpde section and were old threads. This question relates more to daily driving as I have yet to autox/hpde the car. Thanks in advance.
2015 WRB Brz Limited 6MT
2001 BMW 540i 6MT M-Sport (sold)
2001 BMW 325ci 5MT (sold)
1988 Volvo 740 Turbo 4MT w/ electric OD/5th gear (sold)
Stewie is offline   Reply With Quote
Old 03-19-2015, 11:41 PM   #2
Burrcold
Drives: Subaru BRZ Limited
DD - 35 psi
The Following User Says Thank You to Burrcold For This Useful Post:
Stewie (03-19-2015)
Old 03-19-2015, 11:51 PM   #3
Stewie
Stewie's Avatar
Does it feel like the car pushes a bit more than you would like or are you happy with the feel?
Old 03-19-2015, 11:56 PM   #4
Burrcold
I'm happy with the feel but I also upgraded to MPSS's and that has helped (on stock rims). Could be just the nature of the OEM wheels that is messing with you.
Old 03-20-2015, 12:03 AM   #5
Stewie
Stewie's Avatar
Yeah that's a possibility.
Did you stick with the stock tire size or did you go 225?
Old 03-20-2015, 12:06 AM   #6
navanodd
Drives: 2013 BRZ Sport-tech WRB
I also run 35 psi. The nature of the BRZ suspension setup and front/rear balance is that at speed it will push a little bit, but is neutral enough that you should be able to control that easily enough with the throttle. The FRS (at least the 2013-14) was setup a little more tail happy, but unless you're on the throttle or inducing lift oversteer, the car will still push. When there is more weight over the front wheels, they need to do more work than the rears when turning.
navanodd is offline   Reply With Quote
The Following User Says Thank You to navanodd For This Useful Post:
Stewie (03-20-2015)
Old 03-20-2015, 12:06 AM   #7
Burrcold
215. I found that they run a bit wider compared to stock.
Stewie (03-20-2015)
Old 03-20-2015, 12:50 AM   #8
N1rve
N1rve's Avatar
Drives: 2019 BMW ///M4
I'm running 36 PSI Cold..which equates to about 39-40 PSI Hot.
If I'm pushing the car through a corner, I can feel the car yaw and slide.
N1rve
The Following User Says Thank You to N1rve For This Useful Post:
ntron1 (03-20-2015)
Old 03-20-2015, 12:54 AM   #9
Stewie
Stewie's Avatar
Square?
Old 03-20-2015, 01:01 AM   #10
N1rve
N1rve's Avatar
Square?
Yup. All around.
N1rve
Stewie (03-20-2015)
Old 03-20-2015, 07:35 AM   #11
ntron1
Sarcastic Bastard
Drives: '13 DGM BRZ, '13 Mini, 1999 Blazer
Yup, 36 cold on stock rubber and suspension.
ntron1 is offline   Reply With Quote
The Following User Says Thank You to ntron1 For This Useful Post:
Stewie (03-20-2015)
Old 03-20-2015, 09:28 AM   #12
BRZZZZZZZZZZ
Car Nut
BRZZZZZZZZZZ's Avatar
Drives: BMW 335d, Toyota Echo RS, FRS
I run -3 degrees of camber and 255s and I usually run about 32psi cold for daily driving and when I am at auto x closer to 27-28psi hot usually.
BRZZZZZZZZZZ is offline   Reply With Quote
The Following User Says Thank You to BRZZZZZZZZZZ For This Useful Post:
Stewie (03-20-2015)
Old 03-20-2015, 11:22 AM   #13
dp1
driving smoother faster
Drives: Sold
27-28psi hot or 37-38psi hot?
dp1 is offline   Reply With Quote
Old 03-20-2015, 11:55 AM   #14
BRZZZZZZZZZZ
Car Nut
27-28psi. Tires still don't roll over or make maximum contact. Always stuck filling them up again at the end of the day with a hand pump.
The Following 2 Users Say Thank You to BRZZZZZZZZZZ For This Useful Post:
dp1 (03-20-2015), Stewie (03-20-2015)
AX Tire Pressures RMP Tracking / Autocross / HPDE / Drifting 9 12-02-2014 09:19 PM
Tire Pressures mike the snake Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 04-21-2014 05:03 PM
Tire Pressures - What do YOU run? that_guy Tracking / Autocross / HPDE / Drifting 25 09-11-2013 12:20 AM
Stock tire pressures Ghost 86 Tracking / Autocross / HPDE / Drifting 10 05-16-2013 08:59 AM
Wheel Guys Chime In! Need advice on tire sizing Pure Automotive Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 12 01-17-2013 02:21 AM
